Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Closed Thread
Old 02-14-2018, 04:10 PM   #1
cerbomark
Member#: 475983
2018 WRX Limited
Default weighted shift knobs concern
Does anyone have any knowledge/experience whether a weighted aftermarket shift knob can cause any damage as stated in an ad from an OEM part seller...
"If you have a shift knob that is too heavy then you could be adding too much stress and strain to the shifter components which can cause miss shifts, or these ridiculous shift knobs can cause premature wear to the synchros of your transmissions.
cerbomark is offline
Old 02-14-2018, 04:22 PM   #2
rtv900
Member#: 428511
2016 STI
^that right there is what is ridiculous
I wonder if they have an agenda?
I have one, it's solid copper, weighs about 10x's what the plastic factory one weighed.
Shifts much smoother to be honest.
I can't think of any legitimate reason a heavier knob would cause wear on linkage parts or synchros.
I've been running it for about 50,000 miles so far and I don't expect to ever have major transmission issues, or at least not related to the stupid knob.
rtv900 is online now
Old 02-14-2018, 04:28 PM   #3
anarekist
Member#: 468117
2017 WRX
DMG
if it's crazy heavy, it can wear out the shift forks in your transmission, it's like holding your hand on the shiftknob.
anarekist is offline
Old 02-14-2018, 04:52 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I "believe" Subaru, and other MFR's, state that you should keep your hand off the shifter unless shifting. A heavy shifter knob could be the same......
5 Things You Should Never Do In A Manual Transmission Vehicle - YouTube
Agreed.....YMMV......your trans, your decision.....
Charlie-III is offline
Old 02-14-2018, 04:57 PM   #5
mishapopa
Member#: 393629
2015 WRX
won't be an issue for the 2015+ wrx as it uses cable link. wouldn't really be a concern for direct linkages either really so long as you're not resting your hand on the shifter all the time. i've had a weighted shift knob for almost the whole life of the car, i do however have the kartboy short shift linkage mod which requires more force to get it into gear.
mishapopa is offline
Old 02-14-2018, 05:00 PM   #6
cerbomark
Member#: 475983
2018 WRX Limited
I don t know cause I m the one asking but it seems that resting your hand is heavier and also may pull in a direction as it probably won t be straight down force. So a heavy LONG shifter can produce that same leverage in a direction. But a few hundred grams of low position weight????
Old 02-14-2018, 05:02 PM   #7
cerbomark
Member#: 475983
2018 WRX Limited
Ahhh, that s what I was told by Anarchy. Thanks for that info.
Old 02-15-2018, 12:34 AM   #8
humpthebobcat
Member#: 443793
2016 WRX m6 ISM
2005 F-150 FX4
better to just go to the gym and not have girly arms
humpthebobcat is offline
Old 02-15-2018, 10:13 PM   #9
vladd
Member#: 158185
17 WRX
CWP
Can you explain why a heavy shift knob matters on direct linkage, but not on cable? Both are just two different ways to do the same thing.
vladd is offline
Old 02-16-2018, 06:26 AM   #10
rtv900
Member#: 428511
2016 STI
it's not an issue for either, that statement is a bunch of bologna from someone with an agenda.
That tiny weight practically straight up puts barely any measureable force front to back.
it's moronic
Old 02-16-2018, 09:41 AM   #11
mishapopa
Member#: 393629
2015 WRX
cables have slack, direct linkages do not. also i clearly said it's not a concern for direct linkages either but resting your hand on the shifter is.
Old 02-16-2018, 05:43 PM   #12
cpittsy29
Member#: 428898
2016 WRX Limited
Dark Grey Metallic
Have a Nice Day? 4th gear chatter
I have a weighted shift knob on my 2016 WRX, and I also agree that it makes shifting much smoother, however, I have noticed that when the vehicle is placed in 4th gear, there is a terrible chatter that resonates on the knob. Anyone have a similar issue, and should I be concerned of this?
cpittsy29 is offline
Old 02-16-2018, 05:53 PM   #13
2015Sapper
Member#: 440929
2016 WRX Premium
ISM
I have about 35k on my Boomba shift plate/short shifter along with a Raceseng Topology shift knob (2016 WRX). Over 50k total on the car, have Mobil 1 gear oil in it and it shifts beautifully. I've put a short shifter and weighted knobs on every vehicle I've owned since the 1990s without ever having a problem.
A. Don't shift like you're some D-bag in a Fast n Furious movie
B. Change the gear oil according to manufacturer's recs with a high quality spec product
C. Don't shift like you're some D-bag in a Fast n Furious movie
Unfortunately the majority of the WRX owners I see fall under A and C. Flat bill, rev their stupid muffler delete catless Depot Racing J pipe engine when they pass me douche nozzles. It's easy to see why the WRX has an image of being unreliable.
2015Sapper is offline
Old 02-18-2018, 05:41 PM   #14
curiousfish
Member#: 89283
2017 WRX Premium
ISM
hahahaha, all too true. They also help drive up the cost of insurance. Thank you!
To be more on topic, most adult arms weigh more than weighted shift knobs offered in the aftermarket.
curiousfish is offline
Old 02-19-2018, 07:46 AM   #15
vladd
Member#: 158185
17 WRX
CWP
But these adult arms aren’t resting on the shifter the entire time the car is on, so how’s that relevant?
vladd is offline
Old 02-24-2018, 12:38 AM   #16
APVersion1
Member#: 55207
2018 WRX Base
I have a Raceseng Slammer on my 2018 WRX that has this 4th gear clatter too. If I gently shift it into 4th, no audible clatter but I do feel it in the shifter sometimes.
APVersion1 is offline
Old 02-26-2018, 03:32 PM   #17
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
I think it is a valid concern and yes, a heavier weight on the end of the shift lever will increase wear, albeit to a degree you cannot measure. Most people won't own a car long enough to notice a difference in wear.
car_freak85 is offline
Old 02-26-2018, 03:43 PM   #18
Zcypot
Member#: 372777
2014 WRX Sedan Lmtd
I've been using a 525gram Brass knob for about 2 years now
Zcypot is offline
Old 02-28-2018, 12:31 PM   #19
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
I would not be concerned with any of the available weighted knobs causing issues, even if I believe the main purpose of a weighted knob is to enrich the seller.
Hoon Goon is offline
Old 02-28-2018, 01:52 PM   #20
Jack
Add Lightness
Member#: 13699
not my president
(From General)
People spend $200 on titanium lug nuts to save weight and then get a lead shift knob.
I don't get it. I come from the Colin Chapman school of car stuff. Add lightness. I'd be drilling holes in the stock plastic knob to make it even lighter.
Jack is offline
Old 02-28-2018, 02:04 PM   #21
Zanna-K
Member#: 457525
2017 WRX Limited
I can't speak to the titanium lugs (actually the ones I've looked up are even more expensive than that...) since that's not something I'd personally ever pay for, but in for most people real-world driving is more about a balance of performance, comfort, and fun. I mean, yeah if a shelled out car with a roll-cage and no heat/AC/Radio/sound dampening/plastic windows/etc. and a carbon-fiber tub for a seat is the way you enjoy driving it all the time then more power to you.
Zanna-K is offline
Old 02-28-2018, 03:25 PM   #22
myrt1987
Member#: 323103
2018 WRX
Pure der
Speaking of weighted shift knobs, anyone else waiting 12+ weeks for a knob from Anarchy Motive??
Hoping I didn't get scammed lol
myrt1987 is offline
Old 02-28-2018, 03:36 PM   #23
D-rock240
Member#: 284221
2011 WRX GV SSM
01 Legacy/03 Outback wgns
I've had an Anarchy motive knob on my wrx for probably 5 years now. Other than some paint flaking when I originally got it, it's been fine. It helps make the shifting smoother with the Kartboy SS kit.
D-rock240 is offline
Old 02-28-2018, 04:00 PM   #24
myrt1987
Member#: 323103
2018 WRX
Pure der
I just hope they didn't go out of business. Havent updated their facebook in some time, didn't respond to my email yet.
I know they've had issues with lead time but 12 weeks for a block of metal ... sheesh
myrt1987 is offline
Old 02-28-2018, 05:31 PM   #25
cerbomark
Member#: 475983
2018 WRX Limited
I spoke to someone on phone, so they are there, for now, LOL....
I thought they said 8 weeks? I was hoping that s the long end and it will come sooner.
Closed Thread
