Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 05-18-2021, 03:13 AM   #5626
Lminette
Member#: 138923
2000 2.5RS Coupe
F8 Green
Thanks man!
Lminette is offline   Reply With Quote
Old 07-15-2021, 07:27 AM   #5627
93JDMGF8
Member#: 501290
1993 Impreza WRX Wag
Originally Posted by Lminette View Post
That color is stunning. Nice work going with something different!
93JDMGF8 is offline   Reply With Quote
Old 07-19-2021, 01:35 PM   #5628
Lminette
Member#: 138923
2000 2.5RS Coupe
F8 Green
Thanks!
Old 08-08-2021, 01:29 AM   #5629
um2
Member#: 357673
2013 WRX STi
Dark Grey Metallic
Default ADF lifted
um2 is offline   Reply With Quote
Old 08-09-2021, 02:05 PM   #5630
Shanaru242
Member#: 344828
2014 WRX hatch
Originally Posted by um2 View Post
[img]
[img]
Looks good! What kit did you go with? 1.5"?
Shanaru242 is offline   Reply With Quote
Old 08-12-2021, 05:43 PM   #5631
um2
Member#: 357673
2013 WRX STi
Dark Grey Metallic
Thanks!
Anderson Design Fabrication
2" front
2 3/8" rear
Old 08-17-2021, 06:05 PM   #5632
H4yduk3
Member#: 521629
Hi, All.
I've done quite a bit of searching the forums, and this seems to be the closest thread to what I'm looking for.
I'm looking to value engineer my stock 2015 wrx for daily driving gravel, dirt, slickrock and a variety of snow conditions from soft powder to slush and ice. Temperature in the climates I drive in literally ranges from -40 to 116 f. These days, I'm more frequently in the higher end of the temperature spectrum.
I'm looking to increase the height and travel of the suspension via springs and shocks/struts in the most cost effective way possible. However, anything I install needs to be an upgrade and not a downgrade.
I'm planning on replacing the factory 17x8 wheels with 16x7's.
I'm not looking for a shopping list- I'd rather learn how to fish.
Any guidance would be appreciated.
Thank You.
H4yduk3 is offline   Reply With Quote
Old 08-17-2021, 06:06 PM   #5633
H4yduk3
Member#: 521629
Hi, All.
Thank You.
Old 09-06-2021, 03:24 PM   #5634
Jim.mEh
Member#: 84517
05' Imprezilla
CruiseControl Warrior
Default Not lifted, yet Wheels specs 15x7 et +15 the ko2s are 215/75/r15
Im not lifted. but the Fozzy in the back has a 2inch lift with King Springs
My wheel specs are 15x7 et +15 the ko2s are 215/75/r15 which equals out to about 27.7 inch tires
jinjin
Jim.mEh is offline   Reply With Quote
Old 11-29-2021, 06:00 PM   #5635
2018_WRX_LMTD
Member#: 510701
2018 WRX LMTD
CWP
Vehicle - 2018 Subaru WRX Lmtd. (non-STi)
Wheels - test fit Method MR502 16x7 +30mm offset, max load rating 1850 lbs, 5x114.3 lug pattern
Weight- 19.2 lbs each! (verified with a scale)
Fitment- direct fit, no spacers needed and/or extended wheel studs needed, clears front OEM clunky calipers, plenty of space back side of wheel lip vs spindle/upper most strut bolt mounting point, no rubbing issues, and almost flush having +30mm offsets with the front fenders. (+45mm or +48mm offset is ideal but the wheel size choices are limited unless I went with 15's plus a front brake caliper swap which I'm not ready to do just yet...)
Tires- (pending) 205/60r/16 92v Michelin CrossClimate2, 640BA Treadwear rating, 3PMSF rated!, weight 22 lbs each! (per Tire Rack)
Goal- Grassroots rallying all the way but still completely driveable as a daily! With that said, I'm going for the least amount of unsprung weight therefore it would be counter-intuitive to put a chunky & heavy A/T tire with a tall aspect ratio of 70 (65 would be my maximum as they are even found on VT cars and many other rally vehicles 205/65/15 to be exact).
https://flic.kr/p/2mMM9D2
https://flic.kr/p/2mMMtVg
https://flic.kr/p/2mMNPXv
https://flic.kr/p/2mMPbRL
2018_WRX_LMTD is offline   Reply With Quote
Old 11-30-2021, 01:10 PM   #5636
2018_WRX_LMTD
Member#: 510701
2018 WRX LMTD
CWP
Originally Posted by H4yduk3 View Post
Hi, All.
Thank You.
Since you're on a budget (as most of us are unless you're rich &/or sponsored) for the lift get shocks and springs (e.g.- Bilsteins and King springs), spacer kit (size depends on how high of a lift), sources: get-primitive, awdadventure, rallitek, lpaventure, etc. If you have more cash to spend go with flatoutsuspension but you'll pay over $2k for their adjustable coilover setup (but I highly recommend using their products, this is route I am taking). And with deeper pockets get Reiger's (German made custom coilovers for competition but very expensive & what VT cars use on their STi's)
Wheels- Method MR502s 16x7 +30mm offset (direct fit no mods needed) -or- Sparco Terras 16x7 +45mm offset 1" wheel spacer needed + longer wheel studs (e.g.- ARP studs) + open end lug nuts). Not sure of other wheels in a 16x7 unless you go upscale with Braids, Evo Corse because they custom cater to your needs.
Tires- you can go several ways with this. But again, given the fact you want to "value" build your WRX start w/ cheap snow tires- a lot of tire manufacturers make these, do a search and you'll get my drift. Authentic rally tires are not made to daily so you'll be wasting your money unless you're serious about competing in actual rally races & want to swap out your rally wheel/tire set up everytime you hit the dirt, snow, trails.
For my purpose, I am going with Michelin CrossClimate2 2 so I'll be able to drive on them daily and go off-road (not "offroading" as this term can be misconstrued by readers who don't know any better, per se) at times. 640 treadwear rating plus 3PMSF rated as well.
I get some inspiration from VT cars, peruse their website and get ideas. These are the guys responsible for building WRX/STi's for Bucky Lasek, Scott Speed, Ken Block, Travis Pastrana.
Hope that helps!
Old 11-30-2021, 03:57 PM   #5637
2018_WRX_LMTD
Member#: 510701
2018 WRX LMTD
CWP
Originally Posted by Reverend_ View Post
Wrapped up the NRSCCA Rallycross season with a great event in November! Secured my overall class win for the third season in a row, too! STI did awesome
http://allwelldrive.blogspot.com/201...n-wrap-up.html
Looking good in the dirt!
Stock suspension or modified, if so what has been done?
Old 11-30-2021, 04:15 PM   #5638
2018_WRX_LMTD
Member#: 510701
2018 WRX LMTD
CWP
Originally Posted by Longitude View Post
This thread really inspires me. Just got 2018 Forester XT but bummed I cannot use my 16" Speedline Corse rally wheels on it, doesn't clear its brakes.
Someone buy these wheels so I can source larger diameter for my future rally FXT?
I'm leaning towards Sparco Terra, OZ rally wheels, or Method MR502
What's the offset for the Corse's?
Old 11-30-2021, 04:18 PM   #5639
2018_WRX_LMTD
Member#: 510701
2018 WRX LMTD
CWP
Old 12-24-2021, 02:17 AM   #5640
Enphenate
Member#: 179301
Had to replace an axle and get an alignment so I used it as an excuse to lift and swap out the wheels that came with the car!
07 2.5i Wagon on Forester AGX struts, Impreza Kings lifting springs, Fifteen52 17" 5x100 ET38 wheels & Geolander 225/65/17 tires. Rubbing slightly but hoping it will eventually go away.
After the lift but still on the old 18" OZ Racing Supperlegerras that came with the car when I purchased it.
After the lift + wheel & tire swap
Enphenate is offline   Reply With Quote
Old 12-27-2021, 01:00 PM   #5641
nitroracer
Member#: 347178
Using all that suspension travel at the local rallycross.
nitroracer is offline   Reply With Quote
Old 01-04-2022, 05:59 PM   #5642
Kostamojen
Member#: 2272
2019 Macan 4cyl
1993 Impreza FWD WRX swap
New TV show Firebite stars a somewhat off road prepped bugeye...
Old 03-03-2022, 06:11 PM   #5643
2018_WRX_LMTD
Member#: 510701
2018 WRX LMTD
CWP
Finally, got the Method 502's 16x7 +30mm (19.2 lbs each!) w/ Michelin CrossClimate2 92v rated 205/60/16 (22 lbs each!) installed for my daily's (heavy 18" OEM Enkei's are spares). At first I had to test fit this size to be sure everything cleared. As soon as it looked good I mounted the tires on.
https://app.photobucket.com/u/foreve...d-9b4a12a6f47c
https://app.photobucket.com/u/foreve...4-6620fbc203a0
https://app.photobucket.com/u/foreve...0-702976b402b1
https://app.photobucket.com/u/foreve...d-8f176354cf0d
Gave them a test run in some back roads..
https://app.photobucket.com/u/foreve...6-d801c16022f1
Also recently installed Project Mu Sports Inner Brake shoes. These lock up the rears nicely and eliminates the need to install a hydraulic handbrake (a grip more of parts, lines, etc. & of course a more optimal way to go about it but way more work, more time).
The VA chassis WRX utilizes the exact same rear brake shoe/disc brake setup as the BRZ, vice versa. Hence the part # is for a BRZ (vendor did not stock them for the VA).
https://app.photobucket.com/u/foreve...f-8110257b83e6
https://app.photobucket.com/u/foreve...e-324a777fe5c0
https://app.photobucket.com/u/foreve...2-7c4d813c07ff
https://app.photobucket.com/u/foreve...e-6afd32aa3306
Old 03-07-2022, 12:51 PM   #5644
Shanaru242
Member#: 344828
2014 WRX hatch
Newly lifted with KYB Excel-Gs and King springs.
Old 06-07-2022, 08:52 AM   #5645
Ferretts
Member#: 416087
2015 WRX & Forester
Blue & Black
2" ADF lift
16x7 +35 RPF1s
235/70/16 Firestone Destination AT2s
Ferretts is offline   Reply With Quote
Old 07-29-2022, 07:00 PM   #5646
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
Your photo links didn't work for me, but it all sounds like a good setup!
I realized I completely missed your response back in November! ::yikes... I need to check NASIOC more often::
I'm on a warpath updating all of my older build threads and such scattered across the internets and THIS is my first stop. Damn, I miss forums. Facebook is CRAP!
As to your question, my suspension was all stock for that season, and it served me well. I have since lowered the car with RCE Yellows and didn't have clearance issues on our course. Took it out for a spin a month or so ago and it was a blast! Gave me a chance to get the new wing dirty, too.
Reverend_ is offline   Reply With Quote
Old 08-08-2022, 10:31 PM   #5647
2018_WRX_LMTD
Member#: 510701
2018 WRX LMTD
CWP
Thumbs up
Very nice! No worries man.. wow, by spending $5k plus on a cf-wing (esp from VSC) I'd think you would be going for more of a lifted coilover setup as opposed to just buying a new set of lowering springs with factory struts?
Since you're into Rally-X would definitely recommend getting a decent set of gravel coilovers. I am assuming this is already something you've looked into? If not, is there a reason you are choosing not to go that route? Curious...
Dirt track looks super fun; that's what I'm talkin' about! No elevation changes and or jumps?! We are in Subaru's (esp. the WRX/STi line) and this is what they're meant for!! Not low and show, but whatever to each their own.
Old 08-23-2022, 08:36 PM   #5648
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
I had knowledge of this wing being available long before they announced it, so I started saving up. The VSC wing isn't a Wallet Flex for me, I don't have a ton of extra funds to wrap up in my car. But I really wanted to make it happen given that it's a "Celebration Car" commemorating the rally career for David Higgins & Craig Drew. There honestly isn't much advantage with this in a local rallycross situation, as the speeds rarely reach a level that would make the wing useful. I have been slowly assembling parts to be able to reliably take this car to the track where higher speeds would come into play.
Honestly factory struts are more than capable of handling the conditions my local rallycross venue has provided over the years. Unfortunately that's all about to change as the race track is getting sold (not likely to continue as a track under new owners) and the alternative track for my area would be a car killer for my STI even with stock suspension. They'd need to grade the new site or decrease the severity of the elevation changes for me to even consider doing rallycross there, so I'm kind of waiting to see what happens.
I had thought about doing something like that, but as I mentioned before the future of our local rallycross program is sorta up in the air. I'd rather not focus it solely on Rallycross without knowing and there's a very active Autocross program here... so it may be shifting to that even though I do still prefer sliding around in the dirt.
In the meantime I did manage to get a few quick shots playing around on a dirt road while trying to test out an Auto-Follow feature on the gimble I just picked up. It didn't work as well as I had hoped but I couldn't not do something fun with the footage I managed to get.
Old 09-14-2022, 03:17 PM   #5649
2018_WRX_LMTD
Member#: 510701
2018 WRX LMTD
CWP
A "Celebration Car"? What does this mean, exactly? Never heard of the term, is it new or just something you call your STi.. I get you're commemorating Higgins. Should change it to McRae instead!! That's just me
https://youtu.be/kA-9KJbnQBE
Old 11-03-2022, 12:22 PM   #5650
torque stable
Member#: 531998
Default Love the color
Originally Posted by I Like It Sideways View Post
Ground Control sleeves, mated to KYB AGX's
10 inch springs
225lb front
200lb rear
On the 205/55R16 A/S's
With the 205/60R16 winterforces and A/S's for comparison
Fender liners stayed
No subframe spacers used
Fantastic color and chassis, always wanted to try driving one of those.
torque stable is offline   Reply With Quote
Chamois, or just plain Sham? Lifino Interior & Exterior Modification 8 10-02-2013 08:01 PM
SOA gotta love 'em or just plain hate 'em kalbo-1 Warranty Issues & SOA Problems 1 01-19-2004 08:29 PM
Hot or Not or Just Plain Ok.... n20x3whitewrx Member's Car Gallery 28 07-29-2002 10:05 AM
McRae: Dedicated or just plain nuts? SubaruStu Motorsports 2 03-20-2002 09:55 AM
Jinxed? Or just Plain UnLucky??!! silverSurfer General Forum Archive 6 06-30-2000 10:27 PM
