Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
View Poll Results: In what order do you clean your teeth?
Brush, Floss, Mouthwash 7 7.22%
Brush, Mouthwash, Floss 2 2.06%
Floss, Brush, Mouthwash 6 6.19%
Floss, Mouthwash, Brush 5 5.15%
Mouthwash, Brush, Floss 1 1.03%
Mouthwash, Floss, Brush 1 1.03%
Brush and Floss only 11 11.34%
Brush and Mouthwash only 15 15.46%
Brush only 47 48.45%
Fixodent and forget 'em! 2 2.06%
Voters: 97. You may not vote on this poll
Old 04-16-2004, 01:32 PM   #1
Spheris
Member#: 45392
Default How do you clean your teeth?
In what order do you clean them?
Spheris is offline   Reply With Quote
Old 04-16-2004, 01:36 PM   #2
imprezton
Member#: 22958
2017 Forester 2.5 Li
Copenhagen
imprezton is offline   Reply With Quote
Old 04-16-2004, 01:39 PM   #3
Montanaflash
Member#: 22529
'02 Specialized
Enduro Expert
Sonicare Elite...mmmm....power tools...
Montanaflash is offline   Reply With Quote
Old 04-16-2004, 01:46 PM   #4
sadbanker
Visiting NASIOC Timeout
Member#: 21643
2002 I RIDE Your MOM
Midnight Black Pearl
TOOTHPICK
sadbanker is offline   Reply With Quote
Old 04-16-2004, 01:49 PM   #5
gongzero
Member#: 25040
Up with skirts,
down with pants!
I scrub with a chewed-on sugarcane, then rinse.
-A
gongzero is offline   Reply With Quote
Old 04-16-2004, 01:49 PM   #6
Sloth
Member#: 4052
I am Sloth and
I approve this message
Sloth is offline   Reply With Quote
Old 04-16-2004, 01:53 PM   #7
poison
Member#: 37678
Sonicare rules
poison is online now   Reply With Quote
Old 04-16-2004, 01:57 PM   #8
MrBlue
Member#: 34978
2006 WRX
Gray
I dont clean my teeth. they're green and hairy. wanna make out?
MrBlue is offline   Reply With Quote
Old 04-16-2004, 10:56 PM   #9
subiebill
Member#: 24931
I just brush and use the whitening gum...
subiebill is offline   Reply With Quote
Old 04-16-2004, 10:57 PM   #10
FunkerVogt
Member#: 4585
Floss first, since it can cause the gums to bleed a little bit. Then rinse with Listerine to kill the bacteria and stop any bleeding. Then brush.
FunkerVogt is offline   Reply With Quote
Old 04-16-2004, 11:03 PM   #11
shandra
Member#: 57797
2012 X5 Diesel
sonicare!
shandra is offline   Reply With Quote
Old 04-16-2004, 11:05 PM   #12
Thumper23
Member#: 11571
ditto on the sonicare
Thumper23 is offline   Reply With Quote
Old 04-16-2004, 11:06 PM   #13
shandra
Member#: 57797
2012 X5 Diesel
that is the best 75$ spent!!
Old 04-16-2004, 11:08 PM   #14
Thumper23
Member#: 11571
indeed
had an exciting day just last week. went on and got a replacement head. much better now
and yes, that can be taken multiple ways, so there
Old 04-16-2004, 11:12 PM   #15
gusto
Member#: 58323
floss first to get inbetween and clean
brush next to get rid of junk cleaned from flossing
mouthwash to rinse it all
bad breath is the NASTIEST stuff ever.
go in that order and youll be AOK
gusto is offline   Reply With Quote
Old 04-16-2004, 11:51 PM   #16
fliz
Member#: 30342
Generally brush only...but if I do all three it's floss, brush then minty mouthwash for the ultra fresh breath.
fliz is online now   Reply With Quote
Old 04-16-2004, 11:55 PM   #17
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
brush only with el cheapo-- yet extremely effective-- ultra brite with baking soda.
squeaky clean, literally.
ColinL is offline   Reply With Quote
Old 04-16-2004, 11:56 PM   #18
eurojax
Review Crew
Member#: 34269
Only marginally
funny.
I brush once a month.
eurojax is offline   Reply With Quote
Old 04-17-2004, 01:00 AM   #19
NJSILVERSTREAK
Member#: 40228
2003 wrx
with my snap on1" drive impact gun and a grinder
NJSILVERSTREAK is offline   Reply With Quote
Old 04-17-2004, 01:01 AM   #20
incorporeal
Guest
Member#:
Brush for 2 mins, then listerine for 1 min.
FTW
Old 04-17-2004, 01:22 AM   #21
aod
Member#: 7121
Well, having fairly bad teeth and seeing a periodontist, I have learned the best practice of how to make sure that you get rid of almost all plaque and how to keep yourself from having any gum disease. This is my regiment nightly, and it's really not too hard to do. This will insure that you keep your teeth and gums as clean as you can possibly get them.
Floss first. Press the floss tightly against the gumline/tooth and push the floss away from the gumline and up or down the tooth. The "sawing" motion does nothing to remove plaque.
Use a good sonic type toothbrush like a sonicare or an oralb 3d excel. Brush the gumlines first (both inside and out), then the tops of the teeth. You should use the toothbrush roughly in the same motion that you are using the floss. Do the motions a few times per tooth to dislodge any stuck plaque/food. After you do your whole mouth, the standard 2 minute brushing should be finished.
Use a proxabrush type handle and dip the brush portion of the handle in mouth wash (listerine works well). Push the brush through your teeth. You generally only need to use this brush on your molars. I was amazed at the amount of food that was stuck between my molars after flossing/brushing that these things get out! Ewww.
After you are done with the proxabrush, rinse mouth with mouthwash. Again, listerine is the best.
It seems like a huge hassle, but it quickly becomes routine. It only takes about 10-15 minutes to do it all. I wish I knew how to properly take care of my teeth and gums when I was growing up to avoid the condition my teeth are in now. However, my gums are more healthy now than they ever have been after doing this. My kid(s) will definitly learn early on how to take care of their teeth properly.
[Edit: The periodontist also told me to floss first, then brush. Flossing first breaks up the plaque better, then brushing afterwards brushes it away.]
aod is offline   Reply With Quote
Old 04-17-2004, 01:41 AM   #22
tbert
Member#: 43357
2004 Smug 46MPG
2006 Clown Car also zoom3
Nobody said anything about cleaning it
tbert
tbert is offline   Reply With Quote
Old 04-17-2004, 01:44 AM   #23
Scrappy2006
Member#: 54917
1996 Impreza Lx
bLUE
brush then water pick
Scrappy2006 is offline   Reply With Quote
Old 04-17-2004, 01:45 AM   #24
aod
Member#: 7121
tbert
Que?
Old 04-17-2004, 01:46 AM   #25
sarahrockswhoa
Member#: 49340
Brush only, and I've never had a cavity in my life!
sarahrockswhoa is offline   Reply With Quote
How do you clean your buffing pads???? HpiRally Off-Topic 9 05-28-2007 12:52 PM
How do you clean your tips? AKSubie Interior & Exterior Modification 16 03-05-2002 04:04 PM
How do you clean your engine? DoubleS7 Service & Maintenance 24 12-26-2001 04:32 PM
How do you clean your car? Otaku64 Interior & Exterior Modification 19 12-05-2000 10:01 PM
