Welcome to the North American Subaru Impreza Owners Club Tuesday November 20, 2018
Old 12-03-2000, 10:26 PM   #1
Otaku64
Member#: 2971
Post How do you clean your car?
hey, i was just wondering the best way to clean my car. it is red, and it leaves the thin spider webs all over. what is the best way and best products?
salvatore
Otaku64 is offline   Reply With Quote
Old 12-03-2000, 10:32 PM   #2
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
I would also like to hear that. I have a silver Impreza and a black Forester. My Impreza is one of the cleanest silver scooby's I have ever seen and I am not just saying that. My Forester looks horrible. Swirl marks are all over the place. I need help with cleaning the exterior of the black car.
Imprezer is offline   Reply With Quote
Old 12-03-2000, 10:43 PM   #3
Bankheist
Member#: 2237
2000 GC8 STi
2015 Ford Mustang GT
Thumbs up
I have this special stuff calle "waterless car wash" which really should be title "soapless"
Anyway, you wax this stuff on...then when it gets dirty hose it down at the jet wash, sometimes thats not enough....theats when i break out the cloth and bucket and hand wash it.... if you want your car really clean wash it panel by panel
clean a panel then dry it, then repeat on the next panel... then wax if you feel necessary
Mine is the cleanest BRP!
Then I ues eagle one wheel shine for the tires, and I put it on the underskirt as well, makes it sparkle...oooooo pwetty (light hurt eyes, but so pwetty!)
-Kevin
Bankheist is offline   Reply With Quote
Old 12-03-2000, 10:54 PM   #4
DEVO
Member#: 1939
Post
otaku's "spider-web" = swirls ?
swirls suck, don't know how to get rid of them since i own a silver car ..hehe
but try some auto polish(not wax), those should fill up SOME tiny scratch marks/swirls
as for washing/cleaning the car..
I put on a polish right after the first time i washed my car. I don't think what kind of carwash makes any difference. I kept applying the layer of polish/protectant on every-so-often, to make sure it's still doing its job.
i hardly wash my car, i wipe my car with wet cloth mostly, since it's too cold to be outside spaying water.
DEVO is offline   Reply With Quote
Old 12-03-2000, 11:46 PM   #5
Lifino
Member#: 2787
01 RS Black
I like to eat ants.
Post
you might check out over at VWvortex, they have a whole forum set up for car care tips.
I think I've found my winter solution. I had a ton of salt on my car(black), looked cool for a while, then it had to go. It was like 9:00 at night and very cold, so I figured the self serve spray stall thingy would be totaly empty and unattended. I took a bucket and sponge over there and went to work. Pressure wash, Pressure soap, Pressure wash into bucket for water then Soap brush for suds, Sponge down car, Pressure Spray. Drive home... The car had a great shine the next morning, my neighbor even mentioned something about it... I've been stopping back every two days or so to give it another quick Pressure Spray. I'll probably need to sponge it next weekend.
-Silas
Lifino is offline   Reply With Quote
Old 12-04-2000, 06:06 AM   #6
JDM5LugHatch
Member#: 1312
'06 Integra Type S
Magnesium
Post
I have found a way to get rid of the swirls or at least a very large portion of them. First use 2 to 3 buckets to wash your car. I use 3 buckets. Next rinse the car off fill up the bucket and use a good quality wash and wash mit, do not use a sponge as it traps dirt and causes swirls. Then you can start to wash. I use the first bucket to wash the hood, trunk, roof and upper side body panels. Then I switch to the 2nd bucket and use it to wash the bumpers and the bottom areas of the car. After you have washed the car I use the 3rd bucket to wash the wheels this is the only part I use a sponge for cleaning. Then dry off the car I prefer a synthetic chamois over a real leather one. Now is the time to get the swirls out. First evaluate your paint. You may need to use a clay bar on your car. I did and highly recommend doing so. If you decided to clay your car then you can start on the second step now. If you decided to skip the claying start here. Use a good polish ( I recommend safe cut by the wax shop ). You need to work it into the area good and allow it to slightly haze then wipe the rest off. Its also very important that you use good quality towels for this. Target seems to have the best towels for this in their auto department. You might want to apply the polish a couple of times. I applied it 2 times. Then after you have used a good polish use some 3M Imperial hand glaze . This will hide any imperfections and give the car a very nice shine although it does not protect. Once you have finished applying the hand glaze you are ready to wax. I also recommend a very high quality wax. I would also recommend that you use Meguirs yellow paste wax so you get a good wax coat. I have used practically all of waxes on the market and they seem to cause this cheap subaru paint to swirl. This however is the only wax that does not seem to cause swirls. So if you have decided to do all this work on your car then I know you have spent a lot of hours on it so you might want to put 2 to 3 coats of wax on it to protect it. I would also recommend rewaxing every 2 weeks to keep it nice and clean. You can get the wax shops safe cut from pep boys or online at www.waxdepot.com . This worked on my car so if worked on mine I see absolutely see no reason why it wont work on yours. Its all about nice looking cars.
Chris www.hometown.aol.com/awdimprezars
JDM5LugHatch is offline   Reply With Quote
Old 12-04-2000, 08:35 AM   #7
rjones
Member#: 1477
2003 wrx wagon
Post
I have a black MY99 and have been fighting swirls for the life of the car. Chris' post is pretty much spot on, although at first bluch its eems excessive. With the rather poor durability of Subaru's clear coat, there is no substitute for sveral steps and hard work. I've found that simple two-step process is pretty good- a high quality polish and then a mild carnuba wax. If you really are swirly, you might be able to replace the clay bar step with 3m's swirl remover. I hear it does wonders.
rj
rjones is offline   Reply With Quote
Old 12-04-2000, 08:46 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
kill spider webs... use detail clay!!!
i swear by that stuff.... look... my car goes off road all the time... ALL THE TIME... but you cant tell cuz i baby the paint!!
detail clay
polish
cleaner
wax
and ya are done!!! it's beauuutiful!!!
j.
Old 12-04-2000, 10:13 AM   #9
01 Black RS
Member#: 2770
Post
I have a black coupe and I am very careful on how I wash and dry a car. First off I use a mild sope from Zymol also Griots make great products and advice check them out http://www.griotsgarage.com/index.jsp. I let the soap drip on the car and lightly pat it with a cotton wash mit (always use 100% cotton). Rinse off with warm water, then I lightly pat the car with a 100% cotton towel. Never drag the towel across the paint, thats how you get the spider web effect in your car. If you want to get the swirl marks out, and not hide them, I would get the Machine polish 1, 2 and 3 from Griots. If you have any questions you can PM me.
01 Black RS is offline   Reply With Quote
Old 12-04-2000, 10:27 AM   #10
shimstock
Member#: 3002
Post
i have a question about the swirl marks everyone is talking about. After i got my RS this summer i washed and waxed it with McQuires gold and ended up with swirl marks. Now the swirl marks i've got are only noticeable when looking at the side of the car from an angle. they almost look like greasy marks. So apon noticing this i took the car to the dealer body shop where i paid them $100 to get rid of the swirls. They couldn't get rid of the swirls but they did manage to make them less appearent. So if the dealer couldn't get them out, is there any hope that i'll be able to? here's what they told me they did. stripped wax, cleaned car, glazed and rewaxed.
[This message has been edited by shimstock (edited December 04, 2000).]
shimstock is offline   Reply With Quote
Old 12-04-2000, 10:58 AM   #11
rjones
Member#: 1477
2003 wrx wagon
Post
Your car should have come back perfect. If it came back with swirls, my bet is that they didn't do a true cut/cleaning with either by clay or cutting compund.
What do you guys think? I think you could get them out yourself with some elbow grease.
Old 12-04-2000, 11:07 AM   #12
01 Black RS
Member#: 2770
Post
shimstock the dealer just basically re-waxed your car. Compound will get out the web effect. But I recomend www.griotsgarage.com and get the Machine polish 1 2 and 3. It will remove the swirl or web instead of hiding it.
Old 12-04-2000, 07:40 PM   #13
STORER
Member#: 2253
2000 2.5 RS
Red
Post
The best thing I found is "The BIG Blue Sponge" It holds a lot of water, which minimizes swirl marks and scratches. Also use a seperact sponge on your wheels.
STORER is offline   Reply With Quote
Old 12-04-2000, 08:22 PM   #14
Overtime
Member#: 1346
Thumbs up
I can't say enough about the 3M glaze and finish restorer. Both will get out most of the visible swirl marks in your car if you wax regularly. I get 3M stuff occasionally on the cheap, but when I have to buy it, it costs. $8-10 or so a bottle. Worth it for my car, though.
Another tip is to get rid of crappy shammies which have accumulated dirt. I have a synth shammy I use. I definitely prefer that over the real ones.
I don't use clay. I did a while back, but it was pretty wretched-looking. Maybe I was doing something wrong, but I didn't notice any improvement compared to the amount of work I put into it.
I use terry cloth towels, but I pulverize em and wet em and dry em before using them. Just standard terry cloth will do-the key is to get them soft and smooth.
Typically, I'll take a Sunday and do everything on my car. My steps:
1) Rinse off the car with low-pressure water.
2) Sponge bath the car once with dirty hand sponge and low-qual soap (I used Simoniz). Scrub off some of wheels, some of plastic, etc.
3) Rinse and give it a real wash with detailer-grade mitt and Mothers' soap. Clean everything. I like Mothers' products the best. YMMV.
4) Rinse and dry using a synthetic chammy.
5) Apply one layer of 3M hand glaze.
6) Go over any scratches, marks, etc. with some rubbing compound (though this stuff is bad karma for your paint, I use it anyway. if you get lots of scratches, it beats the hell out of body shop prices.) Use eraser, wet newspaper, trim/plastic cleaner, etc.
6) Apply full three stage wax. Use two coats of glaze.
7) Dry off and put on the tire cleaner/shiner stuff (I use Eagle 1) and then the wheel cleaner/shiner stuff. I scrub the tire and wheel stuff. Spray and rinse doesn't do it for me.
8) Go over any plastic trim again.
9) Clean interior. I use UV2 to go over the dash and I clean everywhere.
10) Vacuum out interior. I take special care to not vacuum up any important documents (phone numbers ) lying around.
11) Shampoo carpets. I only do this about every 6 months, when I put on that stage 1 of the three stage wax job.
12) Admire your car, grab a drink, and relax.
I used to do about 6 steps twice a week. Now I just do steps 1-4 once or twice a week. Once a month I do the whole shebang. It takes me forever, but I enjoy taking some time out to do this sort of thing.
Overtime is offline   Reply With Quote
Old 12-04-2000, 10:24 PM   #15
FreaK
Member#: 3153
Talking
I don't clean my car.
FreaK
FreaK is offline   Reply With Quote
Old 12-05-2000, 01:00 AM   #16
Andrew
Member#: 1170
2005 STi
Thumbs up
Just as a note, not sure if it has been said yet, but a VERY nice wax that I recently got is called Zymoil (spelling?). Not only does it smell like shampoo but it does a very nice job of protecting that paint. My dad and I were very impressed with the wax when we were done. Please give it a try!
Andrew is offline   Reply With Quote
Old 12-05-2000, 01:08 AM   #17
wrxman555
Member#: 2677
2001 Lexus IS300
Post
Lets face it people, the stock paint SUCKS! Just repaint your car like I plan to. I'll post pics when it's complete. BTW, pretty much decided on the ELECTRIC BLUE that is found on the BMW M3 Roadster.
wrxman555 is offline   Reply With Quote
Old 12-05-2000, 03:15 AM   #18
gs9k
Member#: 2477
Post
anyone use The Absorber to dry their car? i got one at kragen's sale. it seems to clear away huge areas of puddles fast. there have always been swirl marks and i can't tell if its from The absober or sponge. works for me though. that is, until i can prove it's actually damaging my finish. -g
gs9k is offline   Reply With Quote
Old 12-05-2000, 02:13 PM   #19
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
I use a hose (no sprayer nozle), car specific wash, a terricloth wash mit, or natural sea sponge,rinse too often (never let soap dry on your car) chamois dry, wax with McGuires paste wax (twice) and enjoy........It looks good, check out my pics in the members section (I am the Shawn In Chesterfield Missouri)
STiShawn is offline   Reply With Quote
Old 12-05-2000, 10:01 PM   #20
JDM5LugHatch
Member#: 1312
'06 Integra Type S
Magnesium
Post
From what I have always been told and heard a sea sponge is definitely not something you want to use on your car. The reason being because it contains sand particles that scratch your paints surface. No matter how much you rinse them or wash them out you will never get out all the sand particles.
How do you keep your car clean??? ToddZ199 Mid West Subaru Owners Club Forum -- MWSOC 23 12-03-2004 07:18 PM
How do you clean your teeth? Spheris Off-Topic 40 04-18-2004 10:25 PM
How do you clean your tips? AKSubie Interior & Exterior Modification 16 03-05-2002 04:04 PM
How do you clean your engine? DoubleS7 Service & Maintenance 24 12-26-2001 04:32 PM
