12-19-2005, 11:25 AM | #1 |
Member#: 25227
Vehicle:2012 Escape Black |
Must vent: frickin' car dead this morning
Put a new battery in about three months ago. Definitely was starting slow and the new battery was clearly needed. Been starting strongly ever since even in all the cold weather. Just went to a concert in downtown Philly on Saturday night and it started up right up, drove home, and it sat in my garage all day Sunday. Wake up this morning to go to work, turn the key and get "click"-nothing. It wasn't even a full click, just "cli-" and then kaput. After that, wouldn't even click, all power gone.
Gotta be the alternator, right? If it was the starter, I'd have acc power, just no crank. But how would the battery drain so completely so fast? I checked and didn't see any lights left on. What sucks is, I just noticed a real small oil leak (very tiny) and was going to call my mechanic to check it out (a quick look by me revealed nothing). I also noticed an acc belt that looked like it might be cracking. I was all prepared to put a little money into it for my inter checkup but was otherwise JUST telling a buddy of mine how great my car has been and was thinking it may be solid enough that I could begin thinking about a third car for fun. Now I'm bracing myself for a huge bill and now you get into that, "how much do I spend on a car worth about $7K" argument. Oh, and we JUST spent yesterday finally doing all our Christmas shopping, so the money will be just FLYING out..... gawddamit
12-19-2005, 11:28 AM | #2 |
Member#: 31719
NWIC
alt is fine. sounds like you have a short somewhere.
See below for specifics... |
12-19-2005, 11:28 AM | #3 |
Member#: 64632
Prolly a battery cable is loose
12-19-2005, 11:30 AM | #4 | |
Member#: 25227
12-19-2005, 11:36 AM | #5 | |
Member#: 64632
12-19-2005, 11:41 AM | #6 |
Member#: 62428
NWIC
Vehicle:2002 WRX Wagon SRP stage deuce |
do you have a aftermarket stereo in your car? Power cable connected to your batter? Those are things to check. Also make sure everything is completley turning off. I had a car once that when I turned off the headlights the Daytime running headlights would turn on but I would not notice because they are dimmer. Turned out to be a loose wire in the steering column.
But, sounds to me like you have a short/grounding problem. Honda's are known to have some corrosion problems so make sure you have good cables and they are not corroded out. |
12-19-2005, 11:50 AM | #7 |
Member#: 25227
I do have an amkt stereo, but it's been installed for - shoot - like a year and never any problems. When I put the new battery in, I cleaned up all the crap and cleaned off the connectors. I gave them a little wiggle and they didn't budge (I did have them get just a little loose once, you're right, it doesn't take much).
I really hope it's something easy. It needs prolly new plugs, new belts and whatever is causing the oil leak (maybe just a gasket somewhere?). I just don't want the $3,000 bill 'cuz they started digging and found all kinds of problems. I'm REALLY jonesing for a new car (when I say 'new,' I mean 'new to me' - I'd probably buy used) - we shoulnd't spend the money on another car, but it'd be really hard to swallow a bill that big on this car when I could use it as a down pmt on something else. I really hate this: I haven't spent much on this car at all - maybe even a $3K bill would be the only thing it would require for another five years, but you never know. When is a large repair bill a "sign to drop it like it's hot" and when is it simply "the cost of owning a used car." I bought this car for its reliability, so I hate to dump it but I hate to miss the beginnings of a money pit, too.... |
12-19-2005, 11:52 AM | #8 |
Member#: 25227
oh, power for amkt radio is not connected to battery. Brand-specific harness adapter uses stock connections
12-19-2005, 11:53 AM | #9 | |
Member#: 64632
Dude, you gotta focus on the symptoms and not go chasing after oil leaks and worn belts. The most significant symptom is lack of power everywhere in your car; no lights, etc. That meas either the battery is totally dead, or there's an interruption in your wiring somewhere (e.g. blown fuse). Since the car ran fin yesterday and it's a 3 month-old battery, the most logical place to look is to the fusebox and/or loose or grounded wiring. Don't waste your time and money chasing after other things until you fix this first! |
12-19-2005, 11:55 AM | #10 | |
Member#: 31719
NWIC
12-19-2005, 11:59 AM | #11 | |
Member#: 25227
I know, I need to breathe. Power is the issue BUT the fact is, I have been meaning for it to go in and get onced-over. When that little oil leak popped up, it told me I had to get it in soon. In fact, I was going to call today for the appt. Now, after this morning, I'm calling with: * do the check-up * oh, this little oil leak popped up, check that out * oh, btw, you'll need to figure out how to get it started, too! The whole thing just went from 0-warp overnight........ |
12-19-2005, 12:17 PM | #12 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
Batteries are upredictable. Was it below freezing all day sunday, battery could have froze.
If its only 3 months old its still should be under warranty, take it back to where you bought it if you have the reciept, they will test and it and if it bad, give you a new one. Best part is you wont have to spend any money! Jay |
12-19-2005, 12:26 PM | #13 |
Member#: 41713
NESIC
Vehicle:. sprayfinishing supplies.com |
did you cross the jumper cables when you tried to jump the last battery?
if so the main fuse is prolly blown, check there |
12-19-2005, 12:44 PM | #14 | |
Member#: 25227
12-19-2005, 12:47 PM | #15 | |
Member#: 34978
NESIC
Vehicle:2006 WRX Gray |
You never checked the battery cable? *points and laughs* |
12-19-2005, 01:09 PM | #16 | |||
Member#: 25227
Post #4 Quote:
12-19-2005, 01:18 PM | #17 | |
Member#: 64632
12-19-2005, 01:23 PM | #18 | |
Member#: 25227
* how come when I gave them a wiggle, they didn't budge, AND * how did they just go loose after months since I replaced the battery and many, many miles? I don't recall hitting any potholes or any unusual driving Saturday night that was any different than what it's seen lately |
12-19-2005, 01:35 PM | #19 | |
Member#: 64632
I've had that happen before too. |
12-19-2005, 01:37 PM | #20 |
Member#: 11056
TXIC
Vehicle:2012 MB C250 CPO Black on Tan |
Sounds like a loose battery cable to me. I would check that first.
12-19-2005, 01:40 PM | #21 | ||
Member#: 25227
Any Dead Car Batteries This Morning? | FriedIceCream | Texas Impreza Club Forum -- TXIC | 20 | 05-08-2008 11:44 AM |
Tony Dungee's son found Dead this morning... | 4x4GGG | Off-Topic | 5 | 12-22-2005 10:46 AM |
Car stalled this Morning. | SubaruImpreza_power | Normally Aspirated Powertrain | 17 | 12-20-2004 10:12 PM |
got into a car accident this morning | T-rexx | Tri-State Area Forum | 9 | 11-12-2004 06:57 PM |
Got car accident this morning .... | PKduck | Bay Area Impreza Club Forum -- BAIC | 11 | 07-04-2001 08:18 PM |
