Welcome to the North American Subaru Impreza Owners Club Tuesday October 16, 2018
Old 03-11-2002, 12:25 PM   #1
megatron
Member#: 4212
2002 Impreza WRX
Default Impact wrench OK with locking security lug nuts?
Just picked up one of those cheapo electric impact wrenches (my brother has one and it is quite powerful) on ebay:
http://cgi.ebay.com/ebaymotors/aw-cg...tem=1808541102
Just wondering if there will be a problem using it with those Subaru security lugs. They look a little fragile, and I was wondering if the force from an impact wrench would damage the key.
Thanks,
Andy
megatron is offline   Reply With Quote
Old 03-11-2002, 01:00 PM   #2
melfammy
Member#: 15530
2002 WRX Wagon
Midnight Black
pm'd you
melfammy is offline   Reply With Quote
Old 03-11-2002, 01:15 PM   #3
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Don't use an impact wrench to install any of your lugs, period. You should always torque them by hand using a torque wrench. I suppose an impact wrench is OK to remove regular lugs, but I definitely wouldn't use it on the security lug.
AllWheelDrift is offline   Reply With Quote
Old 03-11-2002, 03:22 PM   #4
megatron
Member#: 4212
2002 Impreza WRX
Yep, sorry I should've been clearer. I was only going to use it to remove the lugs. Sounds like it might strip apart the security key thing though.
THanks,
Andy
Old 03-11-2002, 04:17 PM   #5
Aprilia Jon
Member#: 13394
2001 GC8 Coupe
Impacts trash those little weak locking nuts, then again so does a regular lug wrench. Be very careful and do it by hand. The others you can pop on and off with an impact if you know you are not over torquing. I always pop em on with my impact and then go hand torque later.
Aprilia Jon is offline   Reply With Quote
Old 03-11-2002, 06:56 PM   #6
SubaruStu
Member#: 8972
2003 WRX Wagon
You can use an impact to tighten if (and only if) you get a set of
torque sockets (don't know the exact name). They are fixed
torque impact socket extensions that are used by (reputable)
mechanics to tighten wheels. They aren't cheap, but not really
expensive either. Sold by Snap-On and others.
Or, you be like me a nd have a lame-ass compressor that can't
flow enough air to get more than about 70lb-ft of torque out of
an impact wrench
As far as impact wrenches and lock nuts, it's a bad idea as others
have pointed out.
Stu
SubaruStu is offline   Reply With Quote
WI/IL: Subaru wheel locks, Muteki lug nuts, and lug nuts to replace wheel locks JWA Wheels/Tires 7 03-22-2010 04:52 PM
Broke security lug nut Brock31 Tire & Wheel 9 02-12-2007 12:15 PM
FS:’02 wrx factory wheel locks with key and lug nuts gforce MAIC Private Classifieds 2 02-09-2007 09:59 AM
What size torque wrench for STi wheels and lug nuts essogas Tire & Wheel 3 10-14-2003 02:33 PM
Locking/Security lugs on Limix Linea? TampaWRX Brakes, Steering & Suspension 10 12-10-2001 07:37 AM
