Welcome to the North American Subaru Impreza Owners Club Monday October 15, 2018
Old 11-22-2000, 12:03 AM   #1
Mike Smith
Member#: 744
00 BRP RS Coupe
02 Forester, 00 S-10,
Question 12 VDC impact wrenches - any good?
I'm thinking of buying one for changing from summer tires to snows and back. I don't have an air compressor, so I thought this would be the way to go. I might also use it to change over from street ot auto-x rubber. Any opinions?
Mike Smith is offline
Old 11-22-2000, 12:11 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I was thinking about this as well (though I'm thinking about air tools now too), but I saw one on Harbor Freight's site for like $35-40 just last week. Sounds interesting, but not sure it has the torque. Anyone?
8Complex is offline
Old 11-22-2000, 12:17 AM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I've seen quite a few guys using em at autoxes. Still would be best to tighten with a torque wrench anyway, so it doesn't need to provide so much torque.
It should be able to do wheels, not sure about suspension bits.
RidinLow is offline
Old 11-22-2000, 12:46 AM   #4
RS ING
Member#: 2928
Post
what brand/model? What the max torque rating?
RS ING is offline
Old 11-22-2000, 01:21 AM   #5
Mike Smith
Member#: 744
00 BRP RS Coupe
Cool
So far the only one I've seen is from JC Whitney:
REVERSIBLE 1/2"DRIVE 12-VOLT IMPACT WRENCH KIT
Delivers up to 250 ft.-lbs. of torque, yet is so much easier to use than a lug wrench
Built-in light for night use
Perfect for road emergencies…simply plugs into cigarette lighter receptacle or clamps directly to 12-volt battery
Tool loosens/tightens each lug nut in seconds. Also great for shop jobs—rotating tires, inspecting brakes, removing bolts, etc. Unique torquing action allows 12-volt impact wrench to generate the torque and power of an air-powered wrench! Motor spins until it reaches maximum speed, then internal clutch automatically engages and nut is tightened/loosened. Industrial-grade plastic housing. Easy-grip handle with trigger switch. Weighs less than 5 lbs. Kit includes 13-ft. power cord with lighter plug, battery adapter with alligator clips, sockets to fit all sizes of lug nuts, gloves, molded plastic carrying case and instructions.
12-volt Impact Wrench Kit WAS $64.99 Kit 49.99
Copyright © 1999, J.C. Whitney, Inc.
Old 11-22-2000, 04:49 AM   #6
RS ING
Member#: 2928
Post
Good price. Quality?? But if you keep it for just the occasional use it would do. Good find Jeebs.
RS ING is offline
Old 11-22-2000, 07:48 AM   #7
Mike Smith
Member#: 744
00 BRP RS Coupe
Cool
Problem is shipping gonna be another 15 bucks or so, so I'd like to find one at a local store. AutoZone didn't have any - maybe WalMart or NAPA
Old 11-22-2000, 07:53 AM   #8
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Post
The cheap ones (that run off your cigarette lighter) suck. I got one from Brookstone for $50-60. It's like an impact wrench with about 1 sec between each feeble impact. Unusable.
However, if you're serious, spend [edit: make that $180] on one from Makita that uses a NiMH battery. All the WRC teams use them, so they must work pretty well.
[This message has been edited by Jon Bogert (edited November 22, 2000).]
Jon Bogert is offline
Old 11-22-2000, 08:31 AM   #9
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Wow, that Makita looks pretty sweet compared to the cigarette lighter models. I'll have to see about getting one...
RidinLow is offline
Old 11-22-2000, 08:40 AM   #10
Ben
Member#: 423
2002 WRX wagon
Post
I just brough one in Canadian Tire (I'm Canadian) last month, it is a wall plug impact gun, it works fine and it use as the same as Snap-on design. (1/2" Impact Wrench, AC/DC 7.5 amps, max. torque 240 lb.ft.)
It cost about $130 cad.
After you buy the gun, all you needs is get yourself a set of Deep impact sockets!!
Ben is offline
HTML code is On
Husky Torque Wrench, any good? yo14jman Newbies & FAQs 6 11-18-2009 10:29 PM
Impact Wrench and Impact Socket Set Andrew Non-Subaru Stuff 3 07-13-2007 06:13 PM
Is VDC any good? Are front and rear LSD (sti) better? d4d4d4d4 General Community 21 01-04-2004 03:21 PM
Is VDC any good? Are front and rear LSD better? d4d4d4d4 Transmission (AT/MT) & Driveline 2 12-30-2003 02:16 AM
Good, cheap impact wrench? Snowphun Off-Topic 3 08-16-2003 12:59 AM
