Welcome to the North American Subaru Impreza Owners Club Thursday April 9, 2020
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 04-25-2018, 12:51 PM   #1
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Default Air/Oil Separation - Starting at $339
The goal of this product is simple, the removal of oil (in liquid or vapor form) from the vented crankcase gasses.
This is accomplished by using a design that has no restrictions; media or baffles, to reduce the flow potential of the crankcase and head vents. Our air oil separator differs from any other on the market. We use centrifugal force to pull oil and liquid vapors out of crankcase gases. This will insure the best possible separation available. Like a tornado, our system pulls vacuum from the center of the separator with the pressured gasses from the crankcase entering an obstruction free path maintaining the most velocity. This caused the heavy vapors to fall out of suspension. It functions with a vacuum source from the turbo inlet. Drain back design assures that any oil accumulation ends up in the oil pan, providing a consistent oil supply to the engine.
Six stainless steel bolts on the top, make it quick and easy for inspection and cleaning. It is not heated, and we see no reason to add unnecessary cooling/heating (weight, complexity, increased install time, and increase probability of something leaking). The Killer B Motorsport Air/Oil Separator should meet and exceeds your expectations of form and function. Our Air/Oil Separator is a product that enthusiasts have been waiting for.
__________________
vs.
FA20 WRX Ultimate Oil Pickup, Now Available! Improving Pressure Consistency and AVCS Synchronization
KillerBMotorsport is online now   Reply With Quote
Old 08-29-2019, 12:46 PM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Fitment announcement. We now have 05 to 09 Legacy GT fitment For our AOS.
__________________
vs.
Old 10-29-2019, 04:28 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
And now SG5 and SG9 Forester fitment
__________________
vs.
Old 03-04-2020, 02:49 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
__________________
vs.
Old 03-05-2020, 12:08 PM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Color choices coming soon :P
__________________
vs.
Old 03-07-2020, 10:19 PM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
And here it is in black...
__________________
vs.
Old 03-25-2020, 04:48 PM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
New Pricing announced today, starting at $339
__________________
vs.
Old 04-01-2020, 01:20 PM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
TIG master Levi chipping away at the AOS backorder list!
Starting at $339
__________________
vs.
Old 04-07-2020, 06:21 PM   #9
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I've had some questions about the temperature of the unit in regards to condensation collecting on the inside of the unit. Is there more condensation because the unit isn't heated? No.
Our AOS internal temperature is generally ~240* during daily driving conditions; blowby gasses are H-O-T. Anyone want to guess what coolant temperatures are going into a "heated" AOS?
__________________
vs.
Old Today, 03:24 PM   #10
2020SeriesWhiteSTi
Member#: 513289
Lightbulb
Always thought a heated can would be better.. until you made the point about blow-by gasses. Coolant shouldn't ever be much above 215 degrees F. Definitely questioning the need for coolant to an air oil separator now...
2020SeriesWhiteSTi is offline   Reply With Quote
Old Today, 04:29 PM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We ran other AOS units for YEARS (heated and not) before we decided to make one of our own. We tested on 3 cars for over a year each before even talking about it to the public. We learned a LOT in that time.
If a heated unit is fed off the turbo coolant line (after it goes to the turbo), the coolant will be hotter than what you see for 'normal' coolant temps, but still not as high as the hotter blow-by gasses. So if that's true... A 'heated' unit is actually cooling the AOS which is counter to alllllll the marketing out there
__________________
vs.
