Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 01-09-2017, 02:30 PM   #1976
rallyfan98
Member#: 450501
1998 Outback Sport
White & Gray
Originally Posted by n00dl View Post
Is it possible to get a link to the intake pipe you all are using for the hybrid setup? I like the pipe Roke, rallyfan98, and fallrisk show in their pictures. I believe I'm a little too direct in my google searches
Thanks for the help guys! First time on the forum, it was a highly recommended search from a VW buddy of mine who even name dropped williaty. Your work is well known and the appreciation is real.
http://www.ebay.com/itm/231556329866 this is who I bought mine from. He is good seller and fast shipper.
rallyfan98 is offline   Reply With Quote
Old 01-09-2017, 03:09 PM   #1977
rallyfan98
Member#: 450501
1998 Outback Sport
White & Gray
He's not the only seller either. As long as the intake is the same as he is selling. Your good.
Then depending on what year you have will effect how you modify the tube. The most important thing is to leave everything from the maf down factory.
This is what mine looks like.
Old 05-06-2017, 06:06 PM   #1978
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
Anyone here wtiah a 2008-2011 EL header lying around?
ssssssantimonio is offline   Reply With Quote
Old 05-07-2017, 12:10 AM   #1979
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
This is a thread about intakes, why are you asking about exhausts for sale?
Old 05-07-2017, 12:11 AM   #1980
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
My bad. Late night browsing.
Old 05-14-2017, 06:48 PM   #1981
hunterdms
Member#: 443766
2005 Hybrid WRX STI
Pearl White
I have a stock 08 impreza header if that'll help you out..
hunterdms is offline   Reply With Quote
Old 05-14-2017, 06:53 PM   #1982
hunterdms
Member#: 443766
2005 Hybrid WRX STI
Pearl White
Anybody have any experience with Cosmo racing intakes on the 08+ na imprezas? They have both a short ram and a cold air and I'm curious to see if anybody has experience with running one, or if anybody has a solid 08 2.5i intake set up
Old 05-14-2017, 08:48 PM   #1983
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
Well. I just need to measure all the diameters of the ports.. could you do it?
Old 05-14-2017, 08:49 PM   #1984
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
You did not read the rest of.this.thread.did you?
Old 05-14-2017, 08:50 PM   #1985
hunterdms
Member#: 443766
2005 Hybrid WRX STI
Pearl White
Sure, exactly what dimensions are you looking for
Old 05-14-2017, 08:52 PM   #1986
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
Just the inside diameters of the pipes. Both primaries and collector end.
Old 05-17-2017, 10:09 PM   #1987
Davy_Baby9
Member#: 467637
I just picked up a 2008 2.5i for a daily and it came with a Spectre CAI already on it with no air box. I just noticed today that the intake pops when I blip the throttle at a light so I need to replace this thing asap.
Davy_Baby9 is offline   Reply With Quote
Old 05-21-2017, 03:50 PM   #1988
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
Are you going for the hybrid or stock?
Old 05-22-2017, 09:55 PM   #1989
Davy_Baby9
Member#: 467637
I'm going to run a hybrid since it already has a nice tube. Looks like I'm going to have to order some parts from Subaru because I can't find all of it on ebay.
Old 06-09-2017, 01:44 PM   #1990
ScoobieDoBDo
Member#: 252102
03 WRB WRX Bugeye
Mazda Miata
Originally Posted by Turn in Concepts View Post
OK, Ty (williaty) here. As some of you know, Turn In Concepts has me run testing and research on stuff Clint and Tony don't have time to touch. One of the things they wanted me to look at was intakes for the RS. The first thing that came out of this was the Hybrid Intake Coupler Kit. The next thing was me getting time, resources, and a test car to try to work something out to safely use CAIs/SRIs on the MAF-based NA Imprezas. After a number of hours of knocking my head against the wall, I cracked it.
Using a portion of the ECU logic not normally associated with intake tuning at all, I have managed to "tune out" the negative effects of the MAFv spike. The resonance still occurs, the MAFv still spikes, however, I have figured out how to trick the ECU into ignoring the MAFv signal in that range. The result of this is that the car doesn't go stupid rich, doesn't belch black smoke, doesn't buck, and doesn't bog. Is it perfect? No, there's a limit to how much I can abuse the ECU's programming. There's still a small error that ranges between 5 and 10%. Thankfully, it's still on the rich side, so it results in the car running about 0.5 to 1.0 AFR richer than called for in the fueling targets. When driving with a tuned car in Open Loop, you can no longer feel the problem at all. When driving a tuned car that happens to still be in Closed Loop in the problem area, the AF Correction #1 (aka Short Term Fuel Trim) is able to completely handle it and keep the car at stoich.
Summation: I figured out how to safely run a CAI/SRI on a MAF-based NA and TiC is the one who owns the knowledge.
Ty (williaty)
Is there any chance anyone knows this secret so others can tune with it? Would tuning with speed density help eliminate this issue?
ScoobieDoBDo is offline   Reply With Quote
Old 06-29-2017, 09:57 AM   #1991
MarekB
Member#: 470127
Default *
Thank You for Your explanation. I am new to the forum and a 2012 Subaru Impreza owner (purchased 5 mts ago).
MarekB is offline   Reply With Quote
Old 10-10-2017, 09:44 AM   #1992
Subi89
Member#: 475857
Defimatly gonna give this a try!
Subi89 is offline   Reply With Quote
Old 01-25-2018, 09:49 AM   #1993
bbivens
Member#: 478854
Thank you for the link... As I was going through this thread I was losing hope and thinking I was going to have to shell out $150 for the Cosmo to build the hybrid. This is ordered and on the way.
Did you get yours installed? Any pitfalls to avoid?
bbivens is offline   Reply With Quote
Old 02-02-2018, 01:48 PM   #1994
bbivens
Member#: 478854
What did you do for vacuum hoses?
Old 02-25-2018, 02:34 AM   #1995
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
Siliconintakes has.vacuum hoses
Old 04-01-2018, 08:25 PM   #1996
OpFox
Member#: 447104
2011 Impreza 2.5i
Spark Silver Metallic
Some work in progress. new hoses and fittings soon.
OpFox is offline   Reply With Quote
Old 07-09-2018, 04:49 AM   #1997
d0ublethink
Member#: 457162
Default thank you
Oh man, wow. So clear now
d0ublethink is offline   Reply With Quote
CAIs, SRIs, and dynos Bluefoton General Community 10 04-09-2008 08:27 PM
problems with 04' sti into an 01' RS help! Imbaru25rs Subaru Conversions 7 02-18-2006 02:40 AM
Any problems with your STI and with SOA? bbbwrx STi Forum Archive 3 08-27-2003 04:32 PM
LOTS of Problems with SOA, Dealer, and MYSUBARU.com saleen90181 Newbies & FAQs 11 11-26-2002 01:37 PM
Anyone with CAI, Unichip and stock turbo? Dougeefresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2002 12:13 PM
