Welcome to the North American Subaru Impreza Owners Club Saturday November 27, 2021
Old 08-10-2021, 03:55 AM   #26
alexmartynyuk
Member#: 191967
2005 EVO VIII
instagram @boost_reality
Some measurements
alexmartynyuk is offline   Reply With Quote
Old 08-10-2021, 04:01 AM   #27
alexmartynyuk
Member#: 191967
2005 EVO VIII
Some more
Old 08-10-2021, 04:08 AM   #28
alexmartynyuk
Member#: 191967
2005 EVO VIII
More pics
Hard to tell by the pics but the short side radius on the exhaust side can definitely use some work.
Old 10-29-2021, 01:16 PM   #29
alexmartynyuk
Member#: 191967
2005 EVO VIII
Been a while since I updated this thread. Machinist finished up with the block and I should be able to go pick it up soon. Iíll post pics when itís in the garage but this is what I have for now
Tq plate honing with the 14mm head studs torqued to 145 ft/lbs
Line boring with tq plates installed
Old 10-29-2021, 01:39 PM   #30
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
What are your power goals/plans for the eng?
Old 10-29-2021, 04:30 PM   #31
alexmartynyuk
Member#: 191967
2005 EVO VIII
That hasnít been determined yet lol. Hoping for 7-800whp. The internals are capable of holding a lot more but Iím more worried about the sleeves shifting horizontally under high cylinder pressures so not sure if we will blow a head gasket at higher power than 800.
Old 10-30-2021, 10:15 PM   #32
alexmartynyuk
Member#: 191967
2005 EVO VIII
Well after my balls have finally reached the correct weightsnd size to grind on heads I have finally started the process of porting a spare D25 head before I do the W25 heads for this build.
Headgames burr ready to eat
After some porting
I have about an hour into this head so far. Had to stop for the day. Will finish it up hopefully by next weekend and post pics of the finished head.
Old 11-02-2021, 03:26 AM   #33
alexmartynyuk
Member#: 191967
2005 EVO VIII
Picked up the block today. Will post more pics detailed pics later but here it is. Lubricated the sleeves to keep them for getting surface rust and bagged the case halves.
Old 11-02-2021, 03:29 AM   #34
alexmartynyuk
Member#: 191967
2005 EVO VIII
Was able to grind away some more on the head today. Really time consuming, but Iím definitely not rushing it. I would consider myself halfway done on just the intake side of one of the heads.
Old 11-16-2021, 02:51 AM   #35
alexmartynyuk
Member#: 191967
2005 EVO VIII
Basically done with the intake side of the head.
Old 11-23-2021, 03:24 AM   #36
alexmartynyuk
Member#: 191967
2005 EVO VIII
I keep telling myself that Iíll finish this project eventually.
Some more head work
Old 11-23-2021, 10:08 AM   #37
BlackFighter
Member#: 193940
2004 WRX STI Black
very nice, good job.
Old 11-24-2021, 07:35 PM   #38
alexmartynyuk
Member#: 191967
2005 EVO VIII
Thanks. I certainly am trying my best!
Old 11-25-2021, 12:02 AM   #39
BlackFighter
Member#: 193940
2004 WRX STI Black
I remember doing my own TGV delete and porting with a dremel back in the day, have a write up thread on here somewhere. When you start grinding away on some aluminum, it's not as bad as you would think. It's making the decision to start grinding/porting that is the hard part.
Will have a extra set of B25 head sometime soon, might just do the same thing.
Old 11-25-2021, 12:02 PM   #40
alexmartynyuk
Member#: 191967
2005 EVO VIII
You are correct. It took forever to gather myself and actually start grinding. Yeah aluminum is definitely a lot easier than cast iron. My biggest concern was to make sure I can get the ports consistent. Itís not easy, but somehow Iím pulling it off. I guess I see why itís so expensive to get a set of heads done, very labor intensive and time consuming.
Old 11-25-2021, 12:07 PM   #41
alexmartynyuk
Member#: 191967
2005 EVO VIII
I would also like to add that although aluminum is easy to work with, it takes the right set of tools. Over the past decade I have accrued all kinds of burrs, but not all are the same and if you started with a poor quality tool it will definitely put you off. I ordered another burr from headgames because I like my first one so much! Literally cuts through aluminum like butter(ish), doesnít dig in and get caught like some of my other burrs and leaves a super smooth finish. They may seem expensive but I think theyíre worth every penny.
