09-12-2010, 04:01 PM | #1 |
Member#: 244382
RMIC
license plate scratching paint
not sure if this is the right section, but here goes:
Anyone who has their license plates mounted with just screws might want to adjust the mounting method. I only had two screws in the rear plate, and it rattled around a lot. It has worn through the paint. I have since used washers to keep the plate away from the car, and two more screws to make it more secure. also on the front: anyone else have this problem? I haven't seen any posts about this yet. |
09-12-2010, 04:06 PM | #2 |
Member#: 241673
TXIC
Vehicle:2011 WRX Spark Silver |
Yes I recently discovered I'm experiencing the same thing
09-12-2010, 05:11 PM | #3 |
Member#: 198861
SCIC
Vehicle:2004 WRX PSM |
get a plate frame? its almost inevitable to avoid those scratches you'll have to learn to just live with it. its hidden anyways.
09-12-2010, 05:46 PM | #4 |
Member#: 88939
Vehicle:2011 WRX STi Hatch World Rally Blue |
I put a glob of 'Shoo Goo' on the four back corners of the plate, and let it dry before mountng. It seems to stabilize things (no rocking or vibrating) and prevent scratching/rubbing.
Frank |
09-12-2010, 05:51 PM | #5 |
Member#: 169211
International
Vehicle:into a gearhead." Goin' Back Old Skool |
^ This except i cut little rubber pads that go on the bottom of dining room in half and they were the perfect contour of the plate corners, and they are self adhesive.
09-12-2010, 06:25 PM | #6 |
Member#: 172917
Vehicle:2004 WRX WRB |
I don't want to sound like an a-hole, but who cares? It's under the place all the time anyway and it's not going to cause rust issue because the bumpers are plastic.
09-12-2010, 09:34 PM | #7 |
Member#: 244382
RMIC
I just wish I would have known when I bought my car since it's so easily avoidable. Plus the one on the back of the newer generation is metal
Similar Threads | ||||
painting license plate area on the rear?? | Unrealgtx | Interior & Exterior Modification | 30 | 07-07-2009 12:59 PM |
Carbign Craft Dry Carbon Rear License Plate Backing plate | Haven | Exterior/Styling | 13 | 10-19-2007 09:52 PM |
Front License plate mini-plate? | Nixlimited | Interior & Exterior Modification | 5 | 07-02-2007 07:20 PM |
front license plate delete plate | suBerSam | Interior & Exterior Modification | 10 | 01-12-2007 07:48 PM |
