05-07-2013, 08:10 AM | #76 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
Ride height shouldn't have anything to do with the front wheel bearings (unless they're bottoming out hard repeatedly.. and I have a lot of confidence in Element that they aren't doing that).
If anything, it's probably brake heat + lots of grip or a factory defect. Are the front bearings press-in or bolt on? I forget.
05-07-2013, 08:37 AM | #77 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
Correct on the front, ride height shouldn't stress the bearing but camber could. I think it's just a bad factory build and there is no way to tighten it up (no axle nut).
It just bolts in from the back side as a hub assembly. |
05-07-2013, 09:14 AM | #78 |
Member#: 44501
NWIC
If a bearing is going to fail, I'll take a bolt-on over a press-in any day.
05-07-2013, 10:22 AM | #79 | |
Member#: 143129
South East
Vehicle:2013 BRZ World Rally Blue |
05-07-2013, 07:10 PM | #80 |
Member#: 54918
It ended up being the studs in the adapter spacer. When I pulled the wheel off last time to check that they weren't bad enough for me to notice but this time all the studs were loose. Unfortunately they are pressed in so it's trashed.
I'm not sure if this was just a defect or maybe I'm running too much torque on the lug nuts. I tend to run at 85 ft/lbs as it what seems to be required to keep my wheels from coming loose on the race track. I may have to back that down a little with the adapters. |
05-07-2013, 09:02 PM | #81 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
FYI Hardrace has 5x114.3 bolt in hubs now although I don't think I've seen anyone in the US selling them. There are a couple shops in AUS that seem to be selling them though.
http://www.hard-race.com.au/index.ph...product_id=413 Edit: Actually emailed Hardrace last week and finally got a response. They are $895 shipped, just have to call them up or email [email protected]. Last edited by dwx; 05-07-2013 at 09:43 PM. |
05-07-2013, 09:58 PM | #82 |
Member#: 54918
Buy up the Toyota hubs before they catch on....only $30 for the front. Some Arp and get a machinst to redrill. I think in the end this only makes sense if you have a lot of 5x114 race wheels that you can't use. 08+ Sti hubs bolt in the rear from what I understand.
Good 5x100 wheel options are now available so it won't make sense to go 5x114 unless you are also getting the better/larger bearings. Only time will tell if these bearings will suffer the same fate they do on WRX track cars. |
05-08-2013, 12:27 AM | #83 | |
Member#: 54918
Now if someone is local to us so I can be involved with the tuning, they can get an early release. Last edited by Element Tuning; 05-08-2013 at 12:51 AM. |
05-08-2013, 12:42 AM | #84 | |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
05-08-2013, 08:33 AM | #85 |
Member#: 54918
Ha ha if I buy a turbo kit (most likely) vs. building my own it will be on my car for tuning I'm just tryi g to decide if I want to work first with a supercharger kit or go straight to turbocharged.
05-08-2013, 02:58 PM | #86 |
Member#: 143129
South East
Turbocharged makes a cooler BOV sound.
05-15-2013, 04:05 PM | #87 |
Member#: 54918
Formula Drift/Global Time Attack Atlanta
Hydra EMS on E85 and some street tires and I was off to battle test and punish the Hydra powered FRS.
It's been a really long time since I raced anything but a true slick tire so it took a couple sessions to get used to the huge slip angles I was getting with the Hankook RS-3s. Still pretty amazing grip from these 275s! Our custom valved BC Suspension with Hydra EMS power had us leading our class. I absolutely punished this car and this tune to make sure I could use this E85 road race map as a base map for our customers. Camber looking good! It looks like it could use a touch more negative on the front but honestly front grip wasn't the issue. The rear of this car is just too light without the muffler and junk in the trunk. We'll need to work on this with aero. We ended up wining our class by a little over 4 seconds to another FRS so it was good to compare how the Hydra EMS, BC Suspension, and exhaust compared to the other cars mods. Meister watches for the winners Thanks, Phil Grabow |
05-16-2013, 01:26 PM | #88 |
Member#: 54918
Nice shot from Southrnfresh. |
FS : 19x10.5 +21 Volk GTMs and 18x9.5 +12 Varristoen 2.2.2 | Bad Wagon | Wheels/Tires | 6 | 05-17-2012 03:45 PM |
FS : JIC Magic J-Force: 18x8.5 and 18x9.5 CONCAVE BLING! 5x114 | SoCalSilvia | SCIC Private Classifieds | 10 | 08-28-2010 02:22 PM |
FS : JIC Magic J-Force: 18x8.5 and 18x9.5 CONCAVE BLING! SoCal | SoCalSilvia | Wheels/Tires | 11 | 08-28-2010 05:56 AM |
