Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 10-03-2002, 04:09 AM   #1
Ken C
Vendor
Member#: 6605
Default EcuTek Delta ECU - calling all DDash users
We are shortly to be starting mapping of the WRX using the new EcuTeK programming software.
To assist us with this we would like your help.
We need as many log files from around the country from WRXs as possible.
The best way to log is in 3rd or 4th gear at 1000rpm then open the throttle fully and log to the rev limiter! This gives a clean wide open throttle log. You can include some transient logs if you want.
Channels to log are:
RPM
MRP (Manifold Relative Pressure (Boost)
Injector Duty
Ignition
Knock correction
Throttle Opening Angle
Primary wastage duty cycle
Exhaust gas temperature
Air Fuel sensor #1
Don't forget to download the latest version of DeltaDash from the boys in the UK, www.ecutek.com
This will be a big help to us and we will make this log data available to all other EcuTeK tuners, so you will be helping your own tuner even if you are not a customer of ours.
Please do not forget to write a note of exact specification of your car (for example, de-cat up-pipe, full de-cat system, APS induction kit etc)
If any other tuners out there have data they are willing to share then please do.
Please email your logs to [email protected]
Sincerely,
Ken Cole
Rally Performance
Ken C is offline   Reply With Quote
FS- EcuTek Delta Dash with all 3 licenses available Mulder Tri-State Area Private Classifieds 13 01-15-2009 05:11 AM
FS: Ecutek Delta Dash **NEW** All keys are open! phlegmon Engine/Power/Exhaust 1 12-02-2006 12:10 AM
calling all coilovers user bearbearbear Brakes, Steering & Suspension 5 03-02-2004 02:47 AM
Calling all Mac Users pittspilot Off-Topic 54 05-15-2003 11:05 PM
Calling all intake users (kindof) mike270 Normally Aspirated Powertrain 3 01-06-2002 08:49 PM
