#1 |
Member#: 17256
South East
Vehicle:18 Outback on the road.... |
![]() I plan to have my stock manifold (#3 cyl) drilled and tapped for the Defi EGT probe. I have heard that there can be problems with the probe seizing in the cast-iron manifold over time. Is there something (like NeverSeize) that can be applied to the threads that will prevent this, and will hold up to the heat?
#2 |
Member#: 60324
Vehicle:1998 RS |
![]() The probe is screwed into a bung, bung is stainless steel, the bung is tapped into the manifold and not removed.
#3 |
Member#: 17256
South East
![]() So the Defi EGT probe will come with a stainless steel bung that is threaded to install in a drilled/tapped hole in the cast iron manifold?
#4 |
Member#: 17256
South East
![]() The SS bungs that I have seen were all the type that you welded on to a tubular (not cast iron) manifold.
#5 | |
Member#: 60324
Vehicle:1998 RS |
![]() Quote:
there are both available. . .i don't know about the defi. |
#6 |
Member#: 17256
South East
![]() hondaeater69: I have been unable to source such a "screw in adapter" for use with cast iron. Do you know of a source?
#7 |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
![]() Every bung I've ever had that was meant for installing into a tapped port was made of brass and yes, you can use antiseize on the threads to prevent it from seizing.
If your sender didn't come with the bung adapter (what kind of hokey gauge kit doesn't?), get new ones from www.egauges.com |
#8 |
Member#: 17256
South East
![]() Thank you! I expect my Defi will come with what I need!
#9 |
Member#: 57318
![]() the defi gauge will come with a threaded bung to screw into the manifold. I drilled and tapped the cast manifold. It works fine with no sign of leaks
Remove EGT Probe from Iron Manifold when Hot/Cold? | whtlegacy | Service & Maintenance | 4 | 10-27-2008 12:13 AM |
EGT probe in uppipe or manifold? | andygold | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 18 | 08-23-2006 04:06 PM |
is there an EGT probe in stock STI uppipe? | RossWRX | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 01-14-2006 06:51 PM |
egt probe in up-pipe or manifold?? | Jerry Seagreaves | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 01-24-2003 12:26 AM |
Anybody Local with EGT probe in Manifold? | jamz | New England Impreza Club Forum -- NESIC | 3 | 02-08-2002 11:17 AM |
