Welcome to the North American Subaru Impreza Owners Club Monday February 19, 2018
Old 11-10-2006, 04:47 PM   #1
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Default How To: Install Supertones
EDIT (1/13/09):
DO I NEED A RELAY? This question has been asked over and over again, now we have conclusive testing done ...
Go HERE for testing results: http://forums.nasioc.com/forums/show...&postcount=361
Thank you to forum member Mike Costin for providing an excellent test and documented results.
-CvD
Reason why I'm posting this is because I couldn't find a complete "how to" on installing Supertones. Sure, there's a few threads on there, but I had to look at 3-4 different ones to get the complete picture.
So, here's the complete installation and everything you'll need to do it. I hope it's helpful.
Supplies Needed:
1. Electrical Tape or Shrink Tube
2. Wire strippers
3. 14G Wire
4. 14G Male Connectors
5. 14G Female Connector
6. 20 AMP In-Line Fuse Terminal
7. 20 AMP Fuse
8. Zip Ties
9. Sime Wire Loom (if you want)
10. Small nuts, bolts & washers
11. 14G In-Line Wire Connectors
12. Vampire Clips
Tools Needed:
1. Screwdrivers
2. Wrenches (for small nuts and bolts)
3. 10mm Wrench
4. Wire Strippers
5. Pliers
What to do:
1. Remove the front grill. And figure out how you're going to mount the horns. I used two existing holes in the radiator support that centered both horns between the side of the grill and the Subaru emblem (see pictures).
2. Disconnect one of the factory horns (or both if you desire). Don't cut the connectors, you will need to use one of them later.
3. Look at the relay that came with the horns. The terminals are numbered, this is what those numbers mean:
87 - (+) Lead for the supertones.
86 - Where the stock horn wire conects.
85 - Relay ground wire.
30 - (+) Power wire, connects to the battery with a fuse.
4. Figure out where you want the relay, because that's going to decide on how you run the wires. Once you have that figured out ...
5. Use your 14G wire to make a harness for the #87 to go to the horns. I ran one 14G wire to one horn, then spliced the second horn with a vampire clip. At all three ends, I used 14G female connectors.
6. Take some 14G wire and crimp a 14G male connector on it. Plug this into one of your disconnected factory horn wires. Then put a female connector on the other end and plug it into terminal #86 on the relay.
7. Find a suitable ground and wire up #85 on the relay. I used a stock ground location next to the batery (see pictures).
8. Now, you need to ground the horns. I ran the ground to the passenger side ground location (see pics). I also made the exact same kind of wiring harness for the ground wire as I did with the (+) lead from the relay.
9. Last is making the connection to the battery. I used a ring terminal and conencted it right to the battery and ran the wire through the protective cover for a clean look. This is where you need to use a 20A fuse terminal.
10. Install your fuse into the fuse terminal and test your horns.
Some things to note:
1. On the horns, the copper connection is (+) to the relay. The silver connecion is (-) to the ground.
2. These mofo's are LOUD.
3. Safedrives kicks ass. Thanks Charles! Buy your supertones there!
Tools and connectors needed:
'Wiring Harness' - I made two of these, one for (+) and one for (-) to the horns: Note that the vampire clip is not taped/shring wrapped yet. Make sure you wrap or tape it.
Battery connection with fuse:
Relay ground location:
Relay all wired up:
Ground for horns:
The final product:
Enjoy! Let me know if I misstated anything, I just did the install, so it should all be accurate.
~CvD
Car vs. Driver is offline   Reply With Quote
Old 11-10-2006, 05:03 PM   #2
Daishi00
Member#: 78952
2005 WRX
CGM
nice, but this should be in the "electrical and lighting" forum
Daishi00 is offline   Reply With Quote
Old 11-10-2006, 05:32 PM   #3
Cre8ive
Member#: 15617
2007 WRX STi OBP
'02 WRX v8 207
Thanks for the write-up and pics. I am wiring up my horn this weekend, and your post saved me from searching on how to do this. And the pics help with my lack of reading comprehension.
Cre8ive is offline   Reply With Quote
Old 11-10-2006, 05:55 PM   #4
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Indeed ... posted in the wrong forum!
Old 11-10-2006, 06:01 PM   #5
scrwrx
Member#: 101523
Bookmarked! I was thinking of ordering them soon and I might do it sooner now
Edit - How long did it take you to do this?
scrwrx is offline   Reply With Quote
Old 11-10-2006, 06:36 PM   #6
Safe Drives
Member#: 75146
1998 Impreza Wagon
Wow! Nice write up!
Best regards,
Charles Buren
safedrives.com
877-739-1713 Toll Free
cburen at safedrives.com
Safe Drives is offline   Reply With Quote
Old 11-10-2006, 06:47 PM   #7
WRXedUSA
Member#: 26833
'07 Bugatti Veyron
'03 Chevy Silverado
Those clip 3-way junctions are junk.
use a butt-end connector to join the 3 power wires.
WRXedUSA is offline   Reply With Quote
Old 11-10-2006, 08:24 PM   #8
Turbo20VJetta
Member#: 46004
05 Saabaru
Stage 2
Very nice write up! I can't wait to hear them!
Turbo20VJetta is offline   Reply With Quote
Old 11-10-2006, 09:09 PM   #9
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
About 2 hours, including a trip to radio shack and taking pics of the install.
I agree that those three way junctions aren't the best option, but in this case they're perfectly acceptable in my mind.
Old 11-11-2006, 08:34 PM   #10
USAF_Pignose
Member#: 127908
1999 Forester Stb
sound clip of the actual horn i havent been able to find 1 i know they are MUCH louder but i dont want the tone of a mack truck or the high pitch honk of a ferrari.
USAF_Pignose is offline   Reply With Quote
Old 11-11-2006, 09:51 PM   #11
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
Damn, what a clean job.
I think I'll redo my crap job. haha.
Works just like it should, I was just sloppy.
edit... Yeah, I'm definitely going to redo mine. I think I'll paint 'em flat black, too.
bl_easy is offline   Reply With Quote
Old 11-11-2006, 09:59 PM   #12
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Thanks man, I wanted the install to look as close to stock as possible. I'm actually kinda bent that I couldn't find a black fuse terminal
Old 11-11-2006, 10:00 PM   #13
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
^--- hahahah ... quoted you too soon. I actually really like how they look. I can't lie, it's probalby the main reason why I go them (I'm rice).
Old 11-13-2006, 09:15 AM   #14
bl_easy
Member#: 91407
BRetty green
Haha, I got them because the single stock horn on the MY97 sucks.
Old 11-13-2006, 11:44 AM   #15
carrman
Member#: 69137
2007 2.5i Outback
1966 Chrysler 300
Hey Mulder, should this be a sticky?
carrman is offline   Reply With Quote
Old 12-12-2006, 02:14 AM   #16
dudley123
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
sweet dood, I was worried that i was gonna have to fab some brackets and drill holes and such.. COol I have my supertones sitting here on my desk staring at me. Guess the 06 is gettin the supertone treatment tomorrow.
Chris
dudley123 is offline   Reply With Quote
Old 12-12-2006, 05:08 AM   #17
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Ya the 06 fit is great. Just need a few nuts, bolts, and the stuff listed.
THey have good radiator clearance too.
aboothman is offline   Reply With Quote
Old 12-12-2006, 10:17 PM   #18
matt5frenzy
Member#: 120162
2006 WRX Limited
San Remo Red
thanks! excellent write up... think this will be my next mod
matt5frenzy is offline   Reply With Quote
Old 12-12-2006, 11:22 PM   #19
theicewall
Member#: 70532
2004 WRX
Nice job. I wouldnt mind a set, but my hella driving light wiring is a sloppy job as it is and im thinking I would have to redo that first and then do this.. perhaps a good summer project after I install my winter batch of parts.
theicewall is offline   Reply With Quote
Old 12-24-2006, 06:59 PM   #20
gaewsky1
Member#: 32017
2011 Outback
From someone who has no electrical/wiring experience at all, this write up is great. I got all my parts from Radio Shack and took about an hour to install everything. The horns have a strange sound but they are loud. I suggest if you try them after the install either open the garage door or move the car out otherwise its too loud .
One bad thing is that my grill didn't fit correctly and I broke a tab off of it and had to use a zip tie to tighten it. I guess I'll search for a new grill now.
gaewsky1 is offline   Reply With Quote
Old 12-26-2006, 11:51 AM   #21
Psydotek
Member#: 44168
2017 Silver Forester
with not enough lights...
I'll add this:
An excellent way to not have to use a vampire tap to power the horns is to use a relay with dual #87 pins. That way you can run a separate wire for each horn which can make for a safer/cleaner wiring job.
[actually, i thought the Hella Supertone kit came with a relay that had dual #87 pins... i'm think mine did... but they're cheap, about $6 i think.]
Psydotek is offline   Reply With Quote
Old 01-02-2007, 06:12 PM   #22
kamil212
Member#: 90596
2009 Scrambler
Bitches love Scramblers
Just ordered a set, taking your word on Safedrives.
Now I have to decide on what color to paint them. I have a Sedona Red car so the regular red doesn't go well, so I'm thinking either the Sedona Red which I have a can of, or the bumper gold which I have to figure out and order. I'm leaning toward the gold. Any opinions? Thanks
Also, now I'm afraid to put them on. I checked the decibel chart and these are rated at 118dB. The chart puts a train horn at 120dB
kamil212 is offline   Reply With Quote
Old 01-02-2007, 06:20 PM   #23
Psydotek
Member#: 44168
Don't worry, they're not that loud... At least while you're inside the car...
I say paint 'em black unless you really want to "show them off".
Old 01-02-2007, 06:39 PM   #24
kamil212
Member#: 90596
2009 Scrambler
Thanks, the reason I was afraid is cuz I live in Chicago
The reason that I finally decided to get these is that the other day there was a moron in front of me that had a green right turn light and just stood there till it turned red 10 seconds later. I was about to get out of the car and....
The reason I wanted to paint them is that I have the replica genome grill which is pretty empty so I wanted to put something in there but not too flashy
Old 01-03-2007, 07:18 PM   #25
culturedetox
Member#: 92204
2005 hybrid swap
paint chips and dirt
I wish I had this writeup when I installed mine... infact.. I have not idea how mine are working at all because of the crap job I did
culturedetox is offline   Reply With Quote
How to: Install Alpine HU-Currently Have Sony gtwagon941 Car Audio, Video & Security 13 02-15-2006 02:35 AM
How to: install Megan coilovers? spooledwrx Interior & Exterior Modification 12 01-20-2006 01:14 AM
How to: Install a new clutch no_rex_yet Off-Topic 11 11-12-2004 03:45 PM
How To: Install WRX Turbo/IC on a 2.2L Pepo Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-08-2004 12:18 PM
how to: install rear trailing arm bushings Scott F. Williams Brakes, Steering & Suspension 4 11-06-2002 12:37 PM
