Welcome to the North American Subaru Impreza Owners Club Friday December 14, 2018
Old 02-22-2006, 07:39 PM   #1
Rex Booster
Member#: 101700
WR Blue
Default Check Engine light turns on when I Redline
So if I redline it, which isn't very often, my check engine light turns on sometimes. It usually turns off after about 12-24 hours. Any reason for this?
Rex Booster is offline   Reply With Quote
Old 02-22-2006, 07:44 PM   #2
pityr
Member#: 31719
Get the code pulled as soon as it happens again. Do you have any mods? Crank pully?
pityr is offline   Reply With Quote
Old 02-22-2006, 07:49 PM   #3
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Mine did that once at the track when I slipped the clutch and hit the rev limiter (yeah I know...dumb thing to do). I had the code pulled, and I can't remember it exactly, but it had something to do with a cam sensor. Like yours, the CEL went off by itself, and hasn't been a problem since.
J
thrasher is offline   Reply With Quote
Old 02-23-2006, 10:35 AM   #4
Rex Booster
Member#: 101700
WR Blue
I'm planning on getting the code when I can but it always turns off the next day (So far it's only happened at night). If it comes on during the day I'll deffinately get it checked.
Old 02-23-2006, 11:27 AM   #5
hondaeater69
Member#: 60324
1998 RS
what type of EM?
Old 02-23-2006, 12:16 PM   #6
living4surf
Member#: 85216
mine was doing that and it was the cam position sensor
living4surf is offline   Reply With Quote
Old 02-23-2006, 01:09 PM   #7
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
could be misfire....
-Kevlar- is offline   Reply With Quote
Old 02-23-2006, 01:35 PM   #8
comradeboris
Member#: 33280
2005 STi
yea mine does that now and then? does the CEL flash for a while and then turn off? that could be some misfiring going on...
comradeboris is offline   Reply With Quote
Old 02-23-2006, 01:52 PM   #9
UM-WRXer
Member#: 44623
as long as you didnt reset the ecu via unplugging the battery, the codes should still be stored. Id go to autozone and get them pulled to see what the ecu is trying to communicate.
UM-WRXer is offline   Reply With Quote
Old 02-23-2006, 06:21 PM   #10
Rex Booster
Member#: 101700
WR Blue
It doesnt flash, it just turns on and stays on for a bit. I dont have EM yet, I do have a full exhaust system, as well as a boost controller and intake. My mods are a little out of order (Courtesy of the previous owner) and EM is my next step.
Old 02-23-2006, 08:32 PM   #11
Jon [in CT]
Member#: 2992
02 WRX Sedan
Yet more waste of bandwidth. WHAT WAS THE TROUBLE CODE?
Jon [in CT] is offline   Reply With Quote
Old 02-24-2006, 02:06 AM   #12
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
I am using Utec + built block + jun cam and rev it to 8000 RPM. As u know Utec can adjust the rev limit but when I drive the car for the first 5-10 minutes (after warm up the engine) and rev it pass stock rev limit which is at about 7300 RPM ... the CEL will light up.
The code is faulty cam sensor, the code number is PO 113 if I am not wrong. When I turn off the engine and restart, the CEL will off but the code going into memory that can be read later using scanner.
AFAIK .. it doesn't effect anything, only as reminder that we have overrev the engine. My car still run great after got that code many times because I rev the engine too soon .... If I drive like 15-20 minutes and rev it to 8000RPM .. no CEL come up. Very strange ..
WRX-Blue-Mica is offline   Reply With Quote
Old 02-24-2006, 01:49 PM   #13
Rex Booster
Member#: 101700
WR Blue
Old 02-24-2006, 01:52 PM   #14
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The code remains in memory regardless of whether the light stays on or goes off, as long as you haven't disconnected the battery or cleared it with a scan tool. So, you can go and get it read at any time after the light has come on even if it's gone off in the interim.
Old 02-25-2006, 04:29 AM   #15
WejR20X
Member#: 58101
i've had this problem too but not anymore as i dont drive my car as hard. i pulled it as soon as it came on at autozone and checked it out online and found out that it was the front O2 sensor.
WejR20X is offline   Reply With Quote
Old 02-25-2006, 04:57 AM   #16
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
As far as std management goes,......if you hit rev limit BELOW 55 Kmh, the engine light will illuminate, (to tell us tech's that you've been thrashing it!! ).
This is normally only an issue with manual vehicles....:d
can't remember the code, but it's not cam sensor....
Cheers PPL
Sixpack
sixpack subaru is offline   Reply With Quote
Dash, hvac, and corner lights turn on when brakes are pressed 08sniper Electrical & Lighting 1 09-21-2009 06:06 AM
Check engine light flashing (UTEC) when miss shift? drdome99 Engine Management & Tuning 5 11-19-2005 01:03 AM
Anybody elses brake light turn on when driving? druxboyz Electrical & Lighting 4 10-05-2005 01:27 PM
does the check engine light come on when u need to go in for maintenance? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-11-2004 08:14 AM
Why did the Check engine light comes on when i install the Blitz Intake? Boosted Wagon STi Forum Archive 17 06-20-2003 10:08 AM
