Welcome to the North American Subaru Impreza Owners Club Friday February 26, 2021
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 01-12-2021, 11:16 PM   #1
maverpl
Member#: 519850
2019 Wrx
CWP
Default High AF Correction?
Hey guys, quick question. Is AF correction 1 -20 to +35 normal? AF Learnin 1 -15% to +18. I have seen it pooped out couple times on my AP when driving to work, occasional -1.41,-2.81 knock. I feel like the car jerks a little when driving in traffic, AFR looks fine, no DAM drops. I have been dyno tuned since couple weeks.
GS EBCS, CHARGEPIPE, TMIC, INTAKE, JPIPE
Perrin turbo inlet, IAG TGV deletes, P&L EGR delete.
93octane.
Are those AF correction and learing numbers fine? Should i be concerned about this?
maverpl is offline   Reply With Quote
Old 01-13-2021, 12:34 AM   #2
dpetro1
Member#: 487500
2018 WRX
Are you quoting min/max values or are you getting those values while cruising? Under load?
Take a datalog to post up so we can take a look at what is going on.
dpetro1 is offline   Reply With Quote
Old 01-13-2021, 01:34 AM   #3
maverpl
Member#: 519850
2019 Wrx
CWP
Theses are the min and max values i saw when cruising not sure when they happend. Will get a log tomorrow.
Old 01-13-2021, 01:39 AM   #4
dpetro1
Member#: 487500
2018 WRX
Ok. My understanding is that Min/max is mostly irrelavant. When you are on decel or just barely tipping into the throttle some funky values can register. AF correction should be +/-5 while cruising and under light load.
Old 01-13-2021, 10:04 AM   #5
maverpl
Member#: 519850
2019 Wrx
CWP
I have recorded 3 logs, im gonna post them later after work. I noticed that one spike up to 30 was when the car was idling at gas station, oil temp was around 140 so it was still warming up.
Old 01-13-2021, 04:21 PM   #6
scotte30m3
Member#: 409636
2015 WRX
https://phatbottituning.com/buy-an-e...roubleshooting
read this... it will answer your questions and give you direction.
#phatbotti
scotte30m3 is offline   Reply With Quote
Old 01-13-2021, 05:40 PM   #7
maverpl
Member#: 519850
2019 Wrx
CWP
#phatbotti
Thanks, i guess nothing is wrong with my car and im overreacting. Car runs completely fine, was just worried about those high af correction numbers being high but i see now that it’s normal i certain situations.
Old 01-13-2021, 06:15 PM   #8
WMTwrx15
Member#: 501927
I agree with it being normal, after warm up reset the min max on ap and see what it does
Just for your piece of mind
Good ol’ anxietyport
WMTwrx15 is offline   Reply With Quote
Old 01-15-2021, 09:45 PM   #9
maverpl
Member#: 519850
2019 Wrx
CWP
Here are the logs if someone with more knowledge would take a look at them i would be grateful.
https://datazap.me/u/maverpl/af?log=2&data=
https://datazap.me/u/maverpl/af?log=1&data=
https://datazap.me/u/maverpl/af?log=0&data=
First log is after i cleaned the map sensor.
thanks
Old 01-22-2021, 12:23 PM   #10
dpetro1
Member#: 487500
2018 WRX
thanks
I only see 4 parameters on the log? It would be hard to give any feedback since we cant see rpm, engine load, boost/vac, etc
Old 01-23-2021, 01:05 PM   #11
maverpl
Member#: 519850
2019 Wrx
CWP
Hmm that is weird since i got all the monitors set on the main screen.
Anyway i cleaned my maf and mas sensors and checked for any boost leaks, didnt find any. Af learning 1 looks better now but i still see numbers above -10 and -14 especialy when cruising on highway. AF correction looks normal, sometimes shoots up to 30% for a quick second but from what i know it's normal, especialy when letting of the throttle and coasting to a stop.
Still trying to figure out af learning and get those numbers as perfect as possible. Can a tune play a role in those numbers? I have been dyno tuned by a JR so im not sure. I'll get some new logs after cleaning those sensors.
Old 01-24-2021, 11:14 AM   #12
dpetro1
Member#: 487500
2018 WRX
I think you are fine. If you had a tune done by a competent tuner then trust that and don't worry about the numbers too much. If you are really worried, then ask the tuner to confirm or check your log.
I don't even have my accesport plugged in all the time. When I do, I don't even monitor AF learning. Its a long term ecu determined value. I'm sure the tune map affects it but its a closed loop correction that really doesn't matter all that much to me.
AF correction should be within +/- 5% though. Again, min/max doesn't matter but while cruising and light throttle the ecu shouldn't have to make a lot of correction.
