Welcome to the North American Subaru Impreza Owners Club Monday April 23, 2018
Old 09-14-2009, 04:17 AM   #1
WReXd
Member#: 114101
93 Impreza L Swap
Default v6 cluster & HVAC in 02 WRX
I want to install a v6 sti cluster and HVAC into my 93 L. The bulkhead wiring harness is from an 02 wrx (I was going to do a GD dash swap). Anyone done this?
WReXd is offline   Reply With Quote
Old 09-15-2009, 09:02 AM   #2
rockle3
Member#: 167573
09 spec B
1) sti never came with a 6 cyl?
2) subarus dont make v6s
rockle3 is offline   Reply With Quote
Old 09-15-2009, 09:34 AM   #3
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Wat
when the wiring merge is done you can merge in the stock connectors for the V6 cluster. it will require you to have the wiring from the 98+ impreza.
I dont believe the V6 cluster will fit correctly with the GD dash, you will have to pick one or the other.
jnorth85 is offline   Reply With Quote
Old 09-15-2009, 10:01 AM   #4
rockle3
Member#: 167573
09 spec B
ahahaha my bad i thought he meant it as the engine..not version :[
Old 09-15-2009, 10:31 AM   #5
WReXd
Member#: 114101
93 Impreza L Swap
Sorry, I should have been clearer. When I said "I was going to do a GD dash swap" what I meant was, "I was going to do a GD dash swap, but I decided to get an RS dash instead." I know the v6 cluster will not fit in the GD dash.
I was able to find some pinouts for the clusters, but not the HVAC so that is my biggest concern now.
Old 09-15-2009, 10:36 AM   #6
jnorth85
Member#: 76785
SRP
the HVAC should be no issue you will either use the Impreza wiring or the WRX wiring depending on what you want to do.
05+ auto HVAC in 02 WRX. im doing it and it WILL work. but i need help! Loomin Electrical & Lighting 103 03-27-2016 04:12 PM
Gauge Cluster & HVAC O2Bug-i Newbies & FAQs 5 05-03-2010 01:05 AM
04 STI HVAC in 02 WRX? alwrxwu Interior & Exterior Modification 5 04-01-2008 03:56 PM
Lots of red bulb condoms for anyone that wants to do both Cluster & HVAC mods prototypeWRX Texas Impreza Club Forum -- TXIC 10 05-16-2006 01:46 AM
blown speedometer cluster & HVAC lights Steroid500 Electrical & Lighting 11 09-24-2004 10:15 AM
