Welcome to the North American Subaru Impreza Owners Club Tuesday January 23, 2018
Old 05-06-2008, 11:26 AM   #1
prometheum
Member#: 92003
04 bicycle!
Default car stalls whenever it wants to
i think its got something to do with my fuel pump
i'll be driving down the road and my tach will just drop down to 0 rpms even though the clutch is in and the car is moving in gear. if i'm lucky i can just turn the key to acc then on again and it will start right back up...if i'm not then it will and the car is stopped when i turn the key off then on again there is no fuel pump whine, rather a rapid click click click click coming from the fuel pump...i have to cycle the key about 10 times before i hear the fuel pump whine and only then will it start again
if you look under the hood you can see the fuel hoses pulsating along with the clicks
halp!
edit: oh yeah it did this about 20,000 miles ago; it seemed to get better when i changed the car battery but started again....took it to the dealership and they found the ground on the UTEC was in bad condition and called that the fix...worked ever sice until tonight on my way into work
edit 2: don't have a utec anymore its tuned with open ecu
mods:
modded injectors
walbro 255 fuel pump
16g
open ecu tune
prometheum is offline   Reply With Quote
Old 05-07-2008, 09:43 AM   #2
prometheum
Member#: 92003
04 bicycle!
anyone?
problems with car sounding like it wants to turn off 616STI Newbies & FAQs 16 06-16-2009 06:24 PM
car almost sounds like it wants to die. help? iRick. Normally Aspirated Powertrain 12 09-16-2008 12:14 PM
Paved Rally Car Racing, Would You Want To Try It? Market Research... Sort of... Safe Drives North West Impreza Club Forum -- NWIC 35 10-12-2007 02:40 PM
Why does my car stall when I try to start it (rarely happens) stillillmatic7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 04-28-2007 06:42 AM
Car acts like it wants to stall 03EVO8 Service & Maintenance 1 02-03-2005 10:08 PM
