Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 08-21-2008, 04:15 PM   #1
White_Rice
Member#: 160049
Question iDLE AND AFR ISSUES.
Ok basically my passenger side injector o-rings broke...I replaced them and now my car idles like ass and my idle afrs are anywhere between 16-18.lean lean lean.
Any thoughts?
White_Rice is offline   Reply With Quote
Old 08-21-2008, 04:56 PM   #2
Cocoa Beach Bum
Member#: 17355
No trouble codes?
Cocoa Beach Bum is offline   Reply With Quote
Old 08-21-2008, 05:22 PM   #3
White_Rice
Member#: 160049
yes but at this moment I do not have a reader...or a tactrix cable. til tonight.
Old 08-21-2008, 05:47 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
did you get any debris in the injector?
Old 08-21-2008, 06:01 PM   #5
MasterKwan
Member#: 98961
2003 WRX
Forget to put the donut seals back in? Sounds like a vacuum leak. Get some gumcutter (Carb cleaner) and spray it at the base of the injectors, if your idle smooths out, you found your leak.
Old 10-07-2010, 09:53 AM   #6
Bizko1288
Member#: 151260
2011 BMW 135i
__________
Has anyone else tried/proven this method? I was unaware that a vacuum leak could occur around the injectors.
If anyone has some more insight please chime in......
Edit: After a search I found this : http://forums.nasioc.com/forums/show...=injector+leak
Great info on that thread.... thanks for the followup on the OPs part.
Bizko1288 is offline   Reply With Quote
Modified '08 STI - AFR issue. Logs and chart squashman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-16-2009 03:57 PM
Bad IDLE, Bad AFR, but no CELL. CyborgX_CZ Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 03-05-2009 01:19 PM
odd issue with idle and driving rigpin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-24-2006 12:50 AM
odd issue with idle and driving 03 WRX rigpin South East Region Forum 10 10-15-2006 08:57 AM
idle issues and boost issues jdgrimm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-05-2006 09:45 PM
