Welcome to the North American Subaru Impreza Owners Club Monday February 19, 2018
Old 05-31-2010, 11:37 PM   #1
PSSSHHH
Member#: 227187
2004 WRX Premium
Default LC1 low AFR issue
im running into an issue where logworks will read my lc-1 properly at 14.7 afr, and rom raider is only logging 4-5 afr, has anyone had this issue or know how to fix it?
Have already tried refreshing definitions
PSSSHHH is offline   Reply With Quote
Old 06-01-2010, 08:46 AM   #2
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Yes; it has something to do with it being set up right. Check your settings in the setup utility; make sure you have it set for gas and AFR instead of Lambda.
Zackbo is offline   Reply With Quote
Old 06-01-2010, 09:22 AM   #3
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
I believe you have to use LM Programmer to set the gas type. Your ignition needs to be on when doing this.
scoobystas is offline   Reply With Quote
Old 06-01-2010, 11:07 AM   #4
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
All you need to do is set LM Programmer and LogWorks to gasoline. That should be it.
Wil
wil06STI is offline   Reply With Quote
Old 06-02-2010, 01:12 PM   #5
02RexWI
Member#: 165141
^What these guys said.
02RexWI is offline   Reply With Quote
iDLE AND AFR ISSUES. White_Rice Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-07-2010 10:53 AM
Modified '08 STI - AFR issue. Logs and chart squashman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-16-2009 04:57 PM
Wierd AFR Issues. Swinging almost a full point. simon021 Open Source Reflashes 4 02-25-2008 04:06 PM
Low RPM Low Load Issue xolosis Commercial ECU Reflashes 1 11-01-2006 01:52 PM
Will Auxiliary Boost Controller fix Cobb AccessECU/AccessPort low boost issues? ImportVenom Engine Management & Tuning 2 06-23-2004 01:22 AM
