Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 12-24-2003, 12:24 PM   #1
Steroid500
Member#: 49550
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default blown speedometer cluster & HVAC lights
Does anyone know how to get to the lights behind the speedometer cluster & HVAC controls? I blew the illumination fuse last night, I dont know how, so I replaced it this morning, still doesnt work, I called Subaru, the guy said I probably blew the lights when I blew the fuse, he said itll cost upwards of $200 to replaces the lights "because it was so time consuming" he said the parts cost around $10, if anyone can tell me how to get to the lights, Ill do it myself, and greatly appreciate it.
Steroid500 is offline   Reply With Quote
Old 12-24-2003, 12:32 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That fuse shouldn't just blow for no reason. Were you doing any wiring in the car, or do you already have gauges or other accessories connected to that circuit?
I highly doubt that all of your lights are blown, or even if any of them are. Even if they are replacing them won't fix whatever problem is causing the fuse to blow. At this point you're wasting your time removing the cluster to replace bulbs.
I believe your car has an illumination control module that drives the dimmable lights inside the car, it's possible the problem is with that unit.
Old 12-24-2003, 12:38 PM   #3
Steroid500
Member#: 49550
2000 Impreza 2.5 RS
Blue Ridge Pearl
I dont know, the thing is, I turned the car on, lights worked fine, then I needed 2 run inside my house 4 a while, so i turned it off after it was warmed up, then i went back out to start it up 2 go, lights were out, I have no aftermarket guages or anything else wired to that circuit, and I havent done any electrical wireing in the car since July when I put a deck in. Do you know where that dimmer control unit is located? Its not the switch on the steering column is it?
Old 12-24-2003, 01:14 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No, not the switch on the column, that is just the control for it. I can't say for sure where it is without looking at the service manual for your car (which I don't have), but if you do have one it's probably located under or behind the dash somewhere.
I'd say at this point your best bet is to have a competent shop take a look at it. Don't go to the dealer you called because what they said makes no sense.
Old 12-24-2003, 01:30 PM   #5
Steroid500
Member#: 49550
2000 Impreza 2.5 RS
Blue Ridge Pearl
thanks alot i really appreciate it
Old 12-24-2003, 03:55 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Did also check all your fuses? More than one could be blown.
The same ckt can run off a number of fuses.
Check, the fuses under the hood as well. I doubt you blew out all the bulbs in the cluster.
Jay
Old 12-24-2003, 11:16 PM   #7
Steroid500
Member#: 49550
2000 Impreza 2.5 RS
Blue Ridge Pearl
All the fuses under the hood were fine, I only checked a few in the cockpit, those that would most likely be connected to it, I didnt bother pulling my abs, airbag ect fuses
Old 12-25-2003, 11:45 AM   #8
avk
Member#: 17252
'06 WX8
59E
Taillights and parking lights are on the same circuit. If they're still working, the fault has to be with the illumination control.
avk is offline   Reply With Quote
Old 12-29-2003, 01:31 PM   #9
Steroid500
Member#: 49550
2000 Impreza 2.5 RS
Blue Ridge Pearl
Well I took my car to a specialist, he put a voltimeter? on the circuit that the illumination fuse kept blowing on, he said it was pulling 25 amps on a 10 amp circuit, so now he has to disconnect everything connected to that circuit to find out whats shorted out, should be a nice sized bill
Old 09-19-2004, 03:25 AM   #10
wrxer12
Member#: 50259
2004 WRX
Can you tell me what happened here? Im having the exact same problem....
Thx
wrxer12 is offline   Reply With Quote
Old 09-24-2004, 10:09 AM   #11
Steroid500
Member#: 49550
2000 Impreza 2.5 RS
Blue Ridge Pearl
well, the specialist i took it to found out the illumination wire in the back of my stereo got loose and grounded to the body, shorting everythying on the circuit, he fixed, & it works fine
if u got an aftermarket stereo, check the wireing behind it, or if u got subs or something, check that wireing, trust me, it cost me $360 for this guy to tell me a wire was loose, which, if i had checked it b4 i took it to him wouldve takein me a whole 2 minutes to fix and cost about 25 cents
Old 09-24-2004, 10:15 AM   #12
Eaglesfan2422
Member#: 26445
When my illumination fuse kept blowing, I disassembled sections of the wiring one at a time and a used new fuses. I bought something like 100 of the small blade ones for $8, so I didn't mind wasting a handful. Disconnect the cluster harnesses, fuse still blew. Disconnect radio harness, same thing, disconnect HVAC, fuse still intact. So I looked at the HVAC stuff, narrowed it down to one harness. Found out when I did the bulb color change, the wire crossed over to the other side and shorted it out.
Eaglesfan2422 is offline   Reply With Quote
Gauge Cluster & HVAC O2Bug-i Newbies & FAQs 5 05-03-2010 01:05 AM
Gauge cluster and hvac controls no lights? 2.5guy Electrical & Lighting 0 10-18-2009 10:24 PM
v6 cluster & HVAC in 02 WRX WReXd Subaru Conversions 5 09-15-2009 10:36 AM
Lots of red bulb condoms for anyone that wants to do both Cluster & HVAC mods prototypeWRX Texas Impreza Club Forum -- TXIC 10 05-16-2006 01:46 AM
Cluster and HVAC blue lights from autolumination Slamsitin Electrical & Lighting 2 01-26-2006 09:17 PM
