11-30-2002, 05:33 AM | #1 |
Member#: 24625
BAIC
Removing HVAC bulbs
I want to change the bulb condoms on my HVAC bulbs, however I can't get the little bitches to pop out. is there a trick i am not seeing?
thanks! chris
11-30-2002, 12:51 PM | #2 |
Member#: 24964
Vehicle:2oo2 WRX PSM |
Once you have the trim panel out, remove the hvac knobs. Next you'll see 4 clips (2 on the top, 2 on the bottom). Gently pry each one and remove that piece. This will expose the bulbs. Then you can swap 'em out.
Here's the finished result. I did mine with blue led's. I'm planning on upgrading the stereo soon so I didn't bother doing that . |
11-30-2002, 01:02 PM | #3 |
Member#: 24625
BAIC
My problem is I can't get the bulbs out. How do they pop out? Do I just pull them straight out, or do I need to turn them? Also, did you do it with the LEDs from Radio Shack or from LEDTronics?
Thanks! Chris |
11-30-2002, 04:50 PM | #4 |
Member#: 24964
I just pulled them straight out. I used the ledtronics bulbs. If you use the condom colors the final color is more of a aqua then blue...
HVAC bulbs= where did you buy? | MaddMax | Legacy Forum | 2 | 06-03-2004 04:06 PM |
HVAC bulbs?? | gelgel | Vancouver Impreza Club Forum -- VIC | 16 | 02-25-2004 03:10 AM |
GC/GF HVAC bulbs? | redwagon | Electrical & Lighting | 0 | 02-18-2004 10:12 PM |
2000 Legacy HVAC Bulb Replacement | Acejam2k | Electrical & Lighting | 0 | 11-22-2003 09:19 PM |
Instrument and HVAC bulb quantity and sizes? | jin psu | Electrical & Lighting | 0 | 09-22-2003 12:13 PM |
