09-03-2003, 10:16 AM | #1 |
Member#: 40621
Vehicle:2000 Impreza 2.5 RS Silver - Coupe |
signal question...
on my '00 RS coupe, my right turn signal will sometimes (more often than not) blink faster than usual and make a louder blinking noise than usual. At other times it won't do it at all. The left turn signal never has this problem. Anyone else ever have this issue, and how would I go about fixing?
Thanks, Josh
09-03-2003, 10:19 AM | #2 |
Member#: 518
NESIC
Vehicle:762 PGT Impreza L, Elantra GT Sport |
The fast turn signal is an early warning that you have a faulty bulb, blown bulb or loose connection on the bulb. Basically, if the system senses that there's no continuity on a bulb it will flash that side faster.
Team Updates | FAQ | NESIC News | NESIC Calendar | Gallery | Birth |
09-03-2003, 10:29 AM | #3 |
Member#: 40621
thanks for the reply...time to replace
09-03-2003, 10:39 AM | #4 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
Check the ground on the front bulb/socket. Often gets corroded. Clean it off and use some silicone grease.
jack |
09-03-2003, 11:40 AM | #5 |
Member#: 40621
thanks jack, will try that first
09-03-2003, 01:07 PM | #6 |
Member#: 20315
NESIC
Vehicle:1997 Impreza L hunter green |
09-03-2003, 11:12 PM | #7 |
Member#: 9686
Vehicle:00RS 05 lgt Silverthorn, Silver |
It means that a shortbus is behind the wheel!
-Ben |
09-04-2003, 09:21 AM | #8 |
Member#: 40621
Ben,
Thanks dirtbag -Josh |
09-04-2003, 07:01 PM | #9 |
Member#: 9686
I was trying to bring some light onto the situation. That has happened to me when i was switching my rear lights with the red/whites and forgot to plug them back in! Check connections, replace bulb, check fuse. See you in a this weekend if not next. Hope everything is going well, hopefully you'll be sportin some Solomon equipement this winter, freebee's are welcome my way!
-Ben |
09-04-2003, 08:42 PM | #10 |
Member#: 8725
NESIC
Vehicle:2013 Black Company Annalist |
Being a Massachusetts driver, how exactly did you figure out that the turn signals were broken? Did you lend the car to an out-of-stater?
09-05-2003, 09:15 AM | #11 |
Member#: 40621
Good call jamz...but I am a born and raised New Hampshirite...just in MA for a job....so I am one of the few that use the turn signal!
-josh |
CHARGESPEED KIT (GC8) turn signal question | jkjersey | Interior & Exterior Modification | 1 | 03-11-2005 12:00 PM |
Electrical Signal Question (EE nerds, please) | Lachlan | Electrical & Lighting | 8 | 02-07-2005 02:09 AM |
Newbie - Turning Signal Question | MTImpreza | Newbies & FAQs | 4 | 10-10-2004 04:14 PM |
Turn signal question | TeeWReX | Interior & Exterior Modification | 6 | 10-09-2002 01:10 PM |
