08-24-2012, 10:31 PM | #26 |
Member#: 260046
Vehicle:2011 WRX Hatchback WRB |
Definitely a test mule. I would think that the transmission and exhaust fill well just because it is a Subaru and they have great parts interchangeability.
This could also just be for testing the engine, but I would have thought they would be more stealth and do it in an older model.
08-24-2012, 10:37 PM | #27 | |
Member#: 259611
08-24-2012, 10:45 PM | #28 | |
Member#: 291264
Vehicle:2015 WRX Limited Ice Silver Metallic |
The new impreza will evolve differently and the wrx will do its own thing also... thats been my guess since the beginning, they will split like neanderthals and homo sapiens. =p |
08-24-2012, 10:45 PM | #29 | |
Member#: 45190
SCIC
Vehicle:2014 Impreza Sport L Black |
08-24-2012, 10:51 PM | #30 |
Member#: 10139
Vehicle:WRX 09 Outback 15 Miata 93 |
Doesn't look like a shortened Impreza to me. Could it be a turbo Impreza being brought out just to placate those wanting turbo power and Impreza practicality?
08-24-2012, 10:51 PM | #31 |
Member#: 324810
Vehicle:2013 STi DGM |
Guys...it's a Legacy
08-24-2012, 11:00 PM | #32 |
Member#: 90597
Vehicle:2011 WRX Premium SWP |
08-24-2012, 11:01 PM | #33 |
Member#: 1305
AKIC
Vehicle:2000 Impreza |
4 Door AWD BRZ turbo.
08-24-2012, 11:16 PM | #34 |
Member#: 329797
Vehicle:2007 Outback |
I still think it's going to be a 2015 model. When did we start seeing BRZ/FR-S mules? Like 2 years prior to their release. This is obviously a mule since it's a complete chop job. You also have to consider that the first concept was only revealed a few months prior and nobody picked up on it. You also have to consider that they have to be running behind schedule because of the earthquake last year.
This car here is probably just an early mule with regular Impreza cladding on it because they haven't finalized anything. There were a whole slew of mules for the BRZ/FR-S and I'm sure this is just the first one that we've seen which means that they've still got to test it a bit more before they release it to the public. |
08-24-2012, 11:17 PM | #35 | |
Member#: 153088
Vehicle:2005 Baja Turbo 95&96 Sambar 06 Forester |
I thought the diesel had a six speed...in this body style. I would say that would perfectly fit. And that exhaust if far from perfectly fitting. I have said this before in another post a while back. I went to the Corvette Museum back when the C5 had just come out. In the entrance lobby they had a bunch of the different test cars set up to show it's development stages. One of those cars was a C4 with a C5 interior. Another was a C4 with the full drivetrain of the C5. I believe this Impreza(with it's obvious chopped hood) just has the next drivetrain in it for testing. I am thinking Subaru is getting away from hood scoops like they have done with the diesel. They are just using one here because this is NOT the new body, so they need it because this body doesn't allow for the proper airflow under the hood. Also, I am sure you have been on here long enough to have made that "this confirms" statement. Last edited by JustyWRC; 08-24-2012 at 11:26 PM. |
08-24-2012, 11:22 PM | #36 | |
Member#: 153088
I don't think the earthquake would have had much affect on development. Production? Yes, but not development. Why would it? Nothing Subaru got damaged, and I don't think they need power to drive a car around a test course. |
08-24-2012, 11:48 PM | #37 |
Member#: 329797
I don't see how a 9.0 magnitude earthquake that rattled the entire nation couldn't cause at least some delay with development. The production was heavily delayed for the 2011/2012 model years for nearly all Japanese manufacturers. While development and production are two separate entities, I would figure that they would need additional time to get things rolling with the production of the new cars due to the fact that they were behind on the other ones. They might have it down on paper since they were directly affected by the quake, but they need to do more than just that to get a new car out there which may or may not have been pushed back in schedule due to the unforeseen forces of nature.
08-25-2012, 12:54 AM | #38 |
Member#: 36015
Vehicle:2014 Grand Cherokee White |
Also, if you look at the exhaust cut-outs, they look too big/ half assed. Don't think this is the finished product but close to it.
08-25-2012, 02:06 AM | #39 |
Member#: 120244
Vehicle:2006 Legacy SE Sedan 2006 Legacy GT Ltd Wagon |
WRX mule. Or Impreza GT.
Could it be a mule for BRZ STI guts? Probably WRX mule, considering the car it's running with. No way Subaru's going back to sharing standard Impreza body style with WRX, though. |
08-25-2012, 02:06 AM | #40 |
Member#: 184390
BAIC
Vehicle:1999 Forester GREEN |
For anyone that says it's not a mule, you've fallen out of your tree again.
08-25-2012, 04:48 AM | #41 |
Member#: 60913
SCIC
Vehicle:2006 WRX Sport Wagon Stage 3 WR Blue |
Yeah, like they can't do a short run of hoods for a test mule. I'm sure that's no problem for them since they can pump out concepts here and there.
08-25-2012, 05:28 AM | #42 | |
Member#: 220305
the BRZ (black) mule in the photograph. If the driving dynamics (of the WRX) are such that it can be simulated very very well with a 2012 Impreza, then the WRX is going to be based on the 2012 Impreza. Hence, its not a Frankenstein mule. The hood scoop alone is an EXTREMELY strong marker for my conclusion - y'all know the importance of the hood (shape) and scoop design on intercooler efficiency, right? |
08-25-2012, 05:37 AM | #43 |
Member#: 220305
08-25-2012, 07:00 AM | #44 |
Member#: 190420
An early test mule for sure, and while I don't think it will use the current Impreza bodies, these shots seem to confirm that the wheelbase isn't changing much, if at all. The body differences will probably similar to the styling differences between the Outback and Legacy; while you can tell them apart easily, it's easy to see that they are related. I think that's how it will be between the Impreza and WRX/STI, although the changes will make the WRX/STI look more aggressive compared to the standard car.
08-25-2012, 07:01 AM | #45 |
Member#: 190420
Oh, and fingers crossed for a six speed in the standard WRX!
08-25-2012, 09:17 AM | #46 |
Member#: 26248
Vehicle:2018 Crosstrek Ice Silver |
I'm going with an Impreza GT, small turbo making 200-220hp and 30mpg.
08-25-2012, 09:48 AM | #47 |
Member#: 89967
Vehicle:2020 Volvo S60 Gray |
Really looks like a mule with parts hacked/thrown on. The cutout for the exhaust looks like it was hacked with a dremel.
08-25-2012, 11:12 AM | #48 |
Member#: 67960
Question... when was the last time anyone saw a virtually undisguised Subaru in the wild any length of time before it was due to be released?
08-25-2012, 11:33 AM | #49 | |
Member#: 67960
and the "perfectly fitting twin tip exhausts" are in obvious hand made bumper cut outs |
08-25-2012, 11:50 AM | #50 |
Member#: 154828
TXIC
Vehicle:04 & 12 WRX 06 STI |
I seem to remember a black '12 base Impreza sedan that was caught several months before any official info was released. But yes, you are correct. FHI is notorious for leaving us hanging.
