Welcome to the North American Subaru Impreza Owners Club Tuesday January 26, 2021
Old 09-29-2020, 09:19 PM   #26
snow_bound26
Member#: 395793
2005 92x Aero
Beige
And now I can upload photos again even though I haven't been able to sign up for the image thing. Go figure.
Here's the damage to the front bumper and it being repaired. I'm not going to color match it yet, just apply a clear over the primer for the time being. I'm going to wrap it in satin white until I decide what color I want to paint it.
It's not perfect but it's not bad. I'll touch it up when I get around to painting the final color.
snow_bound26 is offline   Reply With Quote
Old 09-29-2020, 09:21 PM   #27
snow_bound26
Member#: 395793
2005 92x Aero
Beige
EJ207 in place with an 05 STi trans, CF DS, and R180 Suretrack rear diff.
Old 09-30-2020, 11:08 AM   #28
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Wohoo, progress been made, awesome.
What lip is that ?
D-Rodman is offline   Reply With Quote
Old 09-30-2020, 08:03 PM   #29
snow_bound26
Member#: 395793
2005 92x Aero
Beige
What lip is that ?
Just an eBay V limited style. Doesn't take too much effort to fit.
Got a fender today so hopefully I can have all this wrapped up in about a week.
Old 10-01-2020, 12:25 AM   #30
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
V limited for what year model Impreza ?
Old 10-01-2020, 08:24 AM   #31
snow_bound26
Member#: 395793
2005 92x Aero
Beige
04/05 should've thought to included that
Old 10-06-2020, 11:16 AM   #32
hotshoe_32
Member#: 519166
2019 GTI
Cool project. Cheers!
hotshoe_32 is offline   Reply With Quote
Old 10-06-2020, 05:56 PM   #33
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Thanks. It's a slow process but it's coming along. Will have another update soon
Old 10-10-2020, 03:23 PM   #34
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Had to order new wheels today as the Titans don't clear the Brembo calipers even with 5mm spacers. They will be going up for sale once this forum allows me to post pictures again. For some reason one day it will let me and the next it won't. Can't figure out this technology crap to save my life.
New wheels are Enkei TX5 in gunmetal 17x9 +45.
Old 10-14-2020, 06:58 PM   #35
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Got the turbo in today. 20g XTR
Wheels will be here tomorrow. Brakes just need to be bled and coilovers adjusted for height.
Lots of rain the last couple days so there's a film of rust on things but it will clean up easily at least. Should have it on its wheels this weekend and get the cooling system back together. Fingers crossed it goes smoothly.
Old 10-14-2020, 08:09 PM   #36
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Yes!!!!!
Old 10-23-2020, 06:43 PM   #37
snow_bound26
Member#: 395793
2005 92x Aero
Beige
New wheels on. Enkei TX5 Platinum Grey 17x9 +45 concave face wrapped in Nitto 555g2 235/45-17 rubber.
Next up is setting ride height, installing rear sway bar and end links, and getting the exhaust back on.
Once I figure out why ECUFlash isn't reading my base map, then I can get that loaded and start her up. So damn close now.
Old 10-24-2020, 02:30 AM   #38
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Looking good.
Old 11-19-2020, 06:52 PM   #39
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Default Project Lucy
Tune was finally done about a week ago and she feels good. I asked for a more linear power band and this is what they came up with. There's a little more in the table but I prefer keeping the tune safer rather than wringing out every last drop of power. Tuned on 91.
Old 11-20-2020, 09:22 PM   #40
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Torque curve hits up early on the rpm range, must feel good. Who at EFI did the tune ?
Congrats, guess you’ve been driving it.
Old 11-20-2020, 10:54 PM   #41
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Yeah it comes on nice and strong. But it's definitely a dog under 3000. We were all pretty surprised that it was able to hold almost 21psi all the way to redline.
Calvin. I had planned on having Stephen at iA Tuning do it, but I was having issues with EcuFlash and decided to have them do it. There's just one little dip at 7100 that we can't figure out. He said it's acting like a misfire but not registering as one. So it might be some electrical interference of some sort. It goes a tad rich right at the same moment as well. No knock detected. I'm going to have to check all my wires and make sure there's no exposed copper or corrosion.
Old 11-21-2020, 01:53 AM   #42
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Do you have all new coil packs ?
Old 11-21-2020, 08:06 AM   #43
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Pulled them from my last car because I replaced them less than 10k miles ago. If I can't find anything else as the problem then I'll probably get one coil pack and start swapping it around to see if it makes a difference.
Old 12-03-2020, 01:21 PM   #44
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Forgot to update the build as where it stands right now.
Engine/Trans:
-EJ207 v7 w/big port heads
-JDM ECU
-Cobb EBCS
-Perrin 2.4" turbo inlet
-NGK 7EIX plugs
-Injector Dynamics 1050x injectors
-Perrin fuel rails
-Process West TMIC w/custom splitter
-Walbro 255 fuel pump
-2005 USDM STi 6 speed trans
-Blouch 20g XTR w/8cm turbine housing w/T28 style blanket
-KS Tech big MAF 73mm intake
-OEM exhaust manifold w/Cerkote ceramic coating
-GrimmSpeed up pipe w/blanket
-Stromung shorty down pipe w/Cerakote ceramic coating and blanket
-Turbo XS street style exhaust and high flow cat
-PST carbon driveshaft
-R180 Suretrack rear diff
-Group-N engine mounts
-Group-N trans mount
-Billet aluminum pitch stop
-TiC trans crossmember bushings
-TiC shifter linkage
-Kartboy rear stay bushing
-Kartboy front shifter bushing
-Kartboy shifter pivot bushing
-Kartboy rear diff hanger bushings
-Whiteline rear subframe bolts
-GrimmSpeed short SS shift knob
-Custom shifter boot
-DCCDpro diff controller
-Mishimoto radiator
-VEMS cyl 4 cooling mod
-GrimmSpeed radiator hoses
-Mishimoto ancillary hose kit
-various iWire pieces to make it all work
-VEI custom boost/AFR gauge that replaces OEM clock
-Innovate LC-2 wide band O2 sensor
-Odyssey PC925 battery
Suspension/Steering:
-Cygnus X-1 long travel coilovers by Fortune Auto w/7k front and 6k rear springs
-Whiteline 22mm adjustable front sway bar
-Whiteline adjustable front end links
-Whiteline 22mm adjustable rear sway bar
-Whiteline rear end links
-Super Pro aluminum lower control arm kit w/ALK
-Cusco type OS front strut tower brace
-Whiteline rear strut tower brace
-Super Pro steering rack bushings
-MSI trailing arms w/Karboy bushings
-Whiteline adjustable lateral links
-Super Pro roll center kit
Wheels/Brakes:
-Enkei TX5 17x9 +42 platinum grey
-Nitto NT555 G2 235/45-17
-STi front Brembo calipers
-FHI 2-pot rear calipers
-Stoptech braided SS brake lines
-Stoptech street pads
-KNS solid rotors
-Motul RBF600 brake fluid
-GrimmSpeed master cyl brace
-Project Kics R26 lug nuts
Sound System:
-Pioneer NEX 2660 head unit
-Rockford Fosgate 6.5" component speakers in front doors w/custom mounting bracket
-JL Audio 10w0 sub, custom sealed box in spare tire well
-Alpine 300x1 mono amp
-T spec 4awg amp kit
There will be more in the future. This is sort of phase 1 of this build. I'll be installing a satin white wrap in the spring once it warms up a bit. The interior and stereo will be getting upgrades as well.
Old 12-05-2020, 12:25 AM   #45
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Didn’t realize TurboXS make a catted mid pipe that bots on to the shorty. I always split the oem down pipe and bolted the cat to my shorty, do they still make it ? Stromung no longer makes that part, they still sell the shorty.
You have all good quality parts on your build.
Do you plan on installing the wrap yourself ?
I’m considering buying material and giving it a try on my bugeye because the car really needs a complete paint job. Had 2 body shops quote me stupid money to paint my car, it’s not like the body is rough or rusted, the body is mint. I’m thinking a wrap is a fraction of the price but also less durable. I realize wrapping paper now has longer life, maybe 5 years. What material do you plan to use ?
Old 12-05-2020, 09:25 AM   #46
snow_bound26
Member#: 395793
2005 92x Aero
Beige
I cut the flanges and welded the cat to the shorty. When I bought my first 9-2x, the previous owner had the shorty but never installed it so I figured I'd give it a try.
I'll be doing the wrap myself. Haven't tried it before but was quoted a min of $3500 to get it done professionally. At that price I might as well do it myself or save a couple grand more and get it painted. I'm using Avery Dennison satin white. Decided on Avery as most professionals say it's the easiest to learn with and doesn't show glue lines as much as 3M. If applied and cared for properly, the life span should be 5 years. Apparently you don't want to leave it on longer than that from what I've read. Tools and wrap cost me about $650 including shipping.
Old 12-11-2020, 11:53 PM   #47
CrimmasAcc96
Member#: 520899
Gotta love Frankenstein builds. Defines built not bought fr!
CrimmasAcc96 is offline   Reply With Quote
Old 12-12-2020, 09:19 PM   #48
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Thanks. It's all about creativity and intended goals. Hoping this combo will be a blast on track days
