12-31-2019, 09:47 AM | #4901 |
Member#: 220816
Vehicle:2018 Exotruck |
05-06-2020, 11:30 PM | #4902 |
Member#: 366122
E. Canada
Vehicle:2015 STi DGM |
275/35/18 - 18x9.5 +38
-2F, -1.8R |
05-11-2020, 09:47 PM | #4903 |
Member#: 514663
05-14-2020, 02:03 PM | #4904 |
Member#: 366122
E. Canada
05-15-2020, 07:59 PM | #4905 |
Member#: 111450
RMIC
Vehicle:06 WRB_STi |
05-15-2020, 08:37 PM | #4906 |
Member#: 111450
RMIC
05-25-2020, 09:13 AM | #4907 |
Member#: 220816
07-07-2020, 09:25 AM | #4908 |
Member#: 307359
South East
Vehicle:'05 STi Stage II OBP |
Hey guys, looking for some input on my rubbing situation. Used to run 245/40R17 Michelin PSS on my XXR 527 (17x8.25 +35) wheels. Had a little rubbing in the rear with this setup going over highway dips but nothing major. Recently changed to the same size tires but Michelin Pilot A/S 3+ tires, and am getting some pretty serious rubbing in the rear. Especially with suitcases or other people in the car.
Suspension is brand new Feal Fixed-Perch Struts, Tanabe GF210 springs, Group N tophats all the way around, stock swaybars (if that matters), and Kartboy endlinks. There is not much of a lip to roll in the rear... think I could remedy this by pulling the rears? Do I need higher spring rates in the rear? I'd like to avoid running more camber in the rear, if possible. Thanks guys. Pics: https://imgur.com/a/XpuocdR |
07-09-2020, 03:05 PM | #4909 |
Member#: 151814
SCIC
Vehicle:2014 WRX SWP |
A rear roll of the rear and dial in a little bit of camber and you should be good.
On my old bugeye. Had 17x9 245/40 set up on coilovers. Only time it rubbed, was on family trip to the airport. |
08-12-2020, 05:48 PM | #4910 |
Member#: 339923
Vehicle:2006 Impreza WRX STi grey |
This may have been covered but i dont really want to read 197 pages of fitment to find out.
i have found a set of LIC rear flares for my 2006 sti. I track the car and i know the rears will accommodate 275s with ease. however, i am trying to decide what size wheel and tire to pickup for the fronts. I would like to pickup RPF1s. and run them in 18x9.5 or 18x10 with a 265-275 tire. I do track the car, so I will need to pickup a set that will be functional. How wide can I go up front (willing to run -3 ish deg camber) on my sti? and should i be looking at the 9.5+38 (will need 10mm spacer to clear brembos, so effectively +28) or should i look at the 10s+38, which will only need a 3mm spacer. or will the 9.5+15 be able to fit properly (no spacer required) |
09-24-2020, 10:09 AM | #4911 |
Member#: 339923
bump for info
10-14-2020, 10:52 AM | #4912 |
Member#: 519147
SWIC
Vehicle:2005 WRX STI Aspen Silver |
11-07-2020, 11:03 PM | #4913 |
Member#: 357191
SCIC
Vehicle:2016 WRX ISM |
nankang ar1 275/35/18 weds tc105x 18x9.5 +25 Last edited by kaeknows; 11-07-2020 at 11:13 PM. |
11-09-2020, 09:02 PM | #4914 |
Member#: 476041
Vehicle:2014 WRX Black |
That looks amazing.
11-09-2020, 11:23 PM | #4915 |
Member#: 519656
255/35R18 on INDY 500s. Absolutely love this setup
11-11-2020, 07:03 PM | #4916 |
Member#: 520231
11-24-2020, 02:39 AM | #4917 |
Member#: 393021
Vehicle:2011 WRX STI Lightning Red |
11-28-2020, 03:58 AM | #4918 |
Member#: 517597
Vehicle:2002 Wrx wagon White |
12-03-2020, 11:08 AM | #4919 |
Member#: 513293
Love the setup!
I just put Nitto NT01 275/35/18 with 18x10 +41 wheels Tucking a hair of tire with -4.2 camber in the front and -3.5 in the rear. It doesn't rub in normal driving but in the canyons it's horrendous. Do you experience the same thing? I probably need to raise the car a little bit but just wanted to see your experience |
12-03-2020, 12:41 PM | #4920 |
Member#: 373868
Vehicle:'04 STi WRB |
I tried searching but couldn't find much.
Anyone here successful in fitting: 265/35/18 or 275/35/18 on a stock body line (no flares/widebody) GD chassis (02-07). |
12-03-2020, 02:06 PM | #4921 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 EJ207 S204 Wagon |
12-03-2020, 03:35 PM | #4922 |
Member#: 373868
12-03-2020, 03:45 PM | #4923 |
Member#: 82745
SCIC
Will rub (on bumps, dips, etc.) unless you do some crazy level of rolling on top of excessive negative camber. Also, you may need spacers if the tire rubs on the body of your coilovers.
12-03-2020, 04:46 PM | #4924 |
Member#: 373868
Thanks man, yeah I figured that. The 255s currently rub fender on deep dips. Looks like 265s may be out of the equation unless I downsize to 18x9s
12-03-2020, 06:46 PM | #4925 | |
Member#: 357191
SCIC
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? | REX8 | Tire & Wheel | 8 | 11-08-2009 11:53 AM |
Post you stock height/meaty tire pictures | patricksmith04 | Member's Car Gallery | 18 | 01-21-2008 01:42 AM |
The Rally Tire Thread | Rallycarperson | Motorsports | 45 | 04-11-2005 07:52 PM |
