Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 03-28-2017, 08:45 PM   #51
Angelus911
Member#: 89967
2012 Impreza Sport
Originally Posted by k7alo View Post
I would start a new thread, but I'm brand new to the forum.
Has anyone found a way to run power through the firewall yet in the 2017 Impreza? I'm trying to wire up my ham radio. I guess this would classify as a mod!
Look in the engine bay - theres a bunch of grommets in the firewall, you should be able to pick one. On our 2012-16 there was one that had 4 points, almost like a trapezoid. I used that to run the power line to my amp under the passenger seat.
Angelus911 is offline   Reply With Quote
Old 04-04-2017, 04:22 PM   #52
Cptxbig
Member#: 380906
2007 Legacy gt
Anyone do any exhaust work to the hatch yet?
Cptxbig is offline   Reply With Quote
Old 04-05-2017, 10:22 AM   #53
2.5~rs
Member#: 158794
xxxx wrx
I did a muffler delete/ turn down pipe for a minute. It was really loud, go figure, sounded decent but it was too much for my daily driver.
2.5~rs is offline   Reply With Quote
Old 04-05-2017, 06:55 PM   #54
EDKEdwin
Member#: 361912
2013 Imp GP Touring
Satin White Pearl
looks like Subispeed will be supporting the 17+ Impreza as they now added its own section: http://www.subispeed.com/more/2017-impreza
Theres nothing much yet, but at least its a start.
EDKEdwin is offline   Reply With Quote
Old 04-15-2017, 06:37 PM   #55
Cptxbig
Member#: 380906
2007 Legacy gt
I saw that too
Old 04-15-2017, 10:27 PM   #56
Stopbreakindown
Member#: 454351
Looks like the mud flaps are up, wonder how they look on the 5dr.
Stopbreakindown is offline   Reply With Quote
Old 04-16-2017, 02:56 PM   #57
oldstiffy
Member#: 463508
Originally Posted by JCD02 View Post
1. Is there anywhere to get custom badges for the front and rear? I want to put black on black, or black on white star badges. I searched around but not finding them for this car
Here you go:
http://emblemoverlays.com/t/emblem-overlays
oldstiffy is offline   Reply With Quote
Old 04-18-2017, 03:01 PM   #58
GuyLR
Member#: 21811
2017 Impreza 5 Door
Crystal White Pearl
Default Sport Stabilizer Bar Question
I'm thinking about adding the rear swaybar from the Sport to my 2017 5 Door Premium. The Sport comes with front and rear bars while the rest of the models get the front only. Has anyone with the Sport measured the diameter of their bars. If the front on the Sport is the same size as the one on my Premium then I know adding the rear bar won't be too much for it.
The bar itself is only like $80 or so but you have to add the links, bushings and clamps too.
I'm also considering going up to the Sport 11.6" front brake rotors. The other cars have 10.9" front rotors. 16" and 17" alloys have enough room to do the swap just by changing to the Sport caliper supports. The knuckles, calipers and brake shields appear to be the same ones used on the Sport. It should be an easy mod like I did to my old Forester going from 10.7"up to 11.4" WRX rotors.
GuyLR is offline   Reply With Quote
Old 04-18-2017, 04:02 PM   #59
erfergo
Member#: 466267
Originally Posted by ptrout View Post
So base I think comes with 17" and sport 18" rims
But sport has lower profile tires, so if I wanted to swap out the 18" for 17" ones what size tire should I get to make sure all the instrument reading are correct. I am looking to do 17" + bit higher profile tires as roads around me are sinkholes with spikey sharpened spears in them.
definitely
erfergo is offline   Reply With Quote
Old 04-19-2017, 03:42 PM   #60
rossia
Member#: 466316
Originally Posted by vertrkr View Post
I like them, fit is excellent. They are small little things but they get the job done protecting the paint.
Install is easy, took me about 30 minutes. The hardest part is getting the clips off, almost need 3 hands. Use a phillips to turn the center part until it pops up (about 1/8 of a turn) while holding the the outer part with needle nose then use a flat head to pop the center part out. Removing the 2 rear clips facing the ground I had to destroy to get them out but those aren't reused so no biggie.
Here's some hi-res images:
https://www.amazon.com/photos/share/...ouONC4ri0AWrJn
Very useful pictures! Thanks
rossia is offline   Reply With Quote
Old 05-05-2017, 01:53 PM   #61
brent_b
Member#: 466053
2017 Impreza 2.0i 5D
Carbide Metallic Gray
Default K&N Air Filter 33-2304 on 2017 Subaru Impreza
I was curious if anyone has tried the K&N Air Filter 33-2304 with their 2017 Subaru Impreza.
I was searching several parts retailers to see if anyone has manufactured a high(er) performance filter specifically for the 2017 yet, but haven't found anything.
However, when searching the 2016 model (at AutoZone.com, for example), the results are:
- STP Air Filter SA9997
- STP Premium Air Filter PSA9997
- K&N Air Filter 33-2304
When searching for the 2017 model on the same site, the results are:
Since the two STP filters with the same part numbers and dimensions work on both years, I'm inclined to think the K&N would work on the 2017 Impreza as well.
Any thoughts?
brent_b is offline   Reply With Quote
Old 05-05-2017, 04:13 PM   #62
TrickNipple
moon moon
Member#: 86213
Any thoughts?
You should be fine. Buy one and if it doesn't fit, return it.
TrickNipple is offline   Reply With Quote
Old 05-05-2017, 07:54 PM   #63
drpoop
Member#: 421858
2012 Impreza
lol trick wants you to destroy your engine with the cheese cloth that is K&N
drpoop is offline   Reply With Quote
Old 05-11-2017, 11:14 AM   #64
pprknight
Member#: 465013
I believe you will see a rear sway bar on all models above the base Impreza. Mounted up high. Had a pic but can't find it right now.
pprknight is offline   Reply With Quote
Old 05-11-2017, 06:50 PM   #65
GuyLR
Member#: 21811
2017 Impreza 5 Door
Crystal White Pearl
Thanks! You are correct and my reading comprehension on the brochure is not good My Premium does have the rear bar. I thought it cornered too flat not to have one. It is mounted way forward compared to the old Imprezas I'm used to working on. That's great and means I can spend my money on the larger brake rotors.
Old 05-13-2017, 03:56 PM   #66
angglev
Member#: 459160
2017 Impreza
Crystal White Pearl
Here are some photos:
angglev is offline   Reply With Quote
Old 05-13-2017, 07:57 PM   #67
angglev
Member#: 459160
2017 Impreza
Crystal White Pearl
And better photos:
Old 05-14-2017, 01:17 AM   #68
NIN8185
Member#: 299546
2006 2.5i Impreza Wg
Any pics at a better angle? Showing the whole car from the rear. Looks good but but can't really tell how they look as a whole from those angles
NIN8185 is offline   Reply With Quote
Old 05-14-2017, 12:46 PM   #69
angglev
Member#: 459160
2017 Impreza
Crystal White Pearl
Good enough for you?
Old 05-15-2017, 12:44 PM   #70
nrosenth
Member#: 461580
2017 Impreza
Originally Posted by angglev View Post
They look great! Mine are supposed to arrive today. Was the install pretty straight forward?
nrosenth is offline   Reply With Quote
Old 05-15-2017, 03:28 PM   #71
angglev
Member#: 459160
2017 Impreza
Crystal White Pearl
Super easy. About 30 min.
Old 05-21-2017, 10:51 PM   #72
oldstiffy
Member#: 463508
Default Installing fog light kit
Anytime have any idea how easy or difficult installing a fog light kit like the one linked below would be? The description makes it sound pretty simple.
http://www.subispeed.com/more/2017-impreza/lighting/fog-lights/olm-complete-oem-style-fog-light-kit-2017-impreza
Old 05-22-2017, 12:49 AM   #73
angglev
Member#: 459160
2017 Impreza
Crystal White Pearl
http://www.subispeed.com/more/2017-i...t-2017-impreza
The installation is the easy part. It's the electrical that can get tricky. Typically it's taken me about an hour for cars that needed the front bumper removed. The instructions provided look simple enough. Give it a go.
Old 05-25-2017, 01:08 AM   #74
angglev
Member#: 459160
2017 Impreza
Crystal White Pearl
Anyone know of these are the US Eyesight headlights?
Old 05-25-2017, 01:06 PM   #75
brent_b
Member#: 466053
http://www.subispeed.com/more/2017-impreza/lighting/fog-lights/olm-complete-oem-style-fog-light-kit-2017-impreza<<<
I bought these the day before yesterday. They arrive on Tuesday. Hope to install them next week - if/when I do, I'll post back and let you know how it went.
