Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Old 08-24-2018, 06:32 AM   #1
MeechWRX
Member#: 487746
Default Low boost
I drive a 2002 WRX and since Iíve had an AP my car hasnít been hitting target boost. I feel like Iíve checked everything there is to check and Iím still only hitting 11 psi at most. I have been running Cobb stage 1 91 map since I got it back in May and I havenít hit target boost once since then. I have new gaskets from the exhaust manifold to the downpipe, new intercooler hoses, silicone hoses, Cobb bcs. Iím waiting on a new turbo inlet and post maf hose to see if they might fix the issue. I donít have the money to take it to a shop right now so Iím trying to figure this out myself.
Also, I tried removing the BCS line going to the WG to see if I would hit target boost and I actually made <0 boost. Not sure what this means but it definitely seems off. Somebody help please Iím tired of driving a slow Subaru.
MeechWRX is offline   Reply With Quote
Old 08-24-2018, 06:39 AM   #2
Cdextraze
Member#: 424221
1997 Outback imprez
My first tip would be to start running 93, second did you have a boost guage in the car to tell you what you were hitting before that? And third get a protune instead of using the Cobb OTS maps
Cdextraze is offline   Reply With Quote
Old 08-24-2018, 07:00 AM   #3
MeechWRX
Member#: 487746
Iíll have to look around for 93 but how will that help with low boost? I didnít have a boost gauge, but Iím sure it was boosting fine before I re-tuned because it actually felt faster and did pull harder. I have plans to get a protune but with mods I can afford down the road, I was hoping the AP would make my car more fun but itís just been depressing to drive it
Old 08-24-2018, 11:15 PM   #4
MeechWRX
Member#: 487746
Bump.
Old 08-26-2018, 03:09 PM   #5
MeechWRX
Member#: 487746
If anyone seeing this was wondering, I pulled the WGDC logs on my AP and found that my wg only cycles at 51% at WOT... so Iím losing pretty a chunk of boost and Iíve decided to just buy a used TD04 and pray for the best. Iíll report back for anyone that might be reading this LOL
