01-07-2003, 02:41 PM | #1 |
Member#: 18068
Vehicle:2000 Impreza Aspen White |
Squeaking noise coming from...
There is an odd squeaking noise coming from my clutch under the hood. My clutch dosent actually slip thoug... so why would it be squeaking? Its constant... and dosent go away, and follows the revs of the engine.
Any help with this matter would be much appreciated!
01-07-2003, 03:15 PM | #2 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
t/o bearing...??
quite possibly... my RS does that.... i'm replacing it soon... that's my best guess at the moment... Jamie www.allsubaru.com||www.subiegalracing.com |
01-07-2003, 03:21 PM | #3 |
Member#: 6654
Vehicle:2006 Odyssey |
When my TO bearing went, it would squeak like that. If you put a little pressure on the clutch pedal the squeak got louder...but if you fully depressed the pedal it went away.
There is also another problem with the RS where the clutch fork can squeak a little....but it shouldn't vary with RPMs. There's info on Ravensblade about that. |
01-12-2003, 10:18 PM | #4 |
Member#: 18068
Bump.
Where exactly is the TO Bearing, and how much would it cost to replace. I take it the transmission will have to be ripped apart? Thanks again! |
01-13-2003, 11:05 PM | #5 |
Member#: 18068
Anyone?
01-14-2003, 07:45 AM | #6 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
The throw out bering is on the end of the clutch fork, you must remove the trans to replace and if your that deap in it you might as well change the clutch, it should come with a new throwout bearing.
does the noise go away when you step on the clutch? have you checked the tension on your belts, do you have any mods? It could also be the pilot bearing in the flywheel... If you are still under warranty take it to the dealer and have it checked. Jay |
01-14-2003, 10:58 AM | #7 |
Member#: 18068
I haven't checked the tension... but i'm pretty sure it isn't the best because the squeaking noise isn't coming from there.
When I press in on the clutch the noise does stops. My warranty is up |
01-15-2003, 12:01 AM | #8 |
Member#: 31825
Vehicle:1999 Impreza Sport Red |
clutch sqeak
I have that same problem with my 99 subaru impreza outback sport. It sqeaks and it i slight of fully put the cluth in it stops. I have had my fork and springs re-greased which helps for about 5 days. Then it starts again. I was told i have to have my tranny ripped out and have some new replaced. I think it was the TO or something. I dont remeber.
Does this noise cause any damage in making the noise ? |
01-29-2003, 04:12 PM | #9 |
Member#: 16371
Vehicle:02 WRX wagon BLACK |
same symptoms
I've had the same issues but 99% is at cold starts and the rpm is like 1k at a tick....
Is this common for Subies or an early symptom for what the original poster said. Would a dealer even bother to look into it? |
01-29-2003, 08:27 PM | #10 | |
Member#: 17193
Vehicle:1991 Legacy RS White |
noises coming from under the hood | hagood22 | Newbies & FAQs | 2 | 10-25-2007 08:14 PM |
Squeaking noise coming from wheels/ brakes? | Trigun001 | Brakes, Steering & Suspension | 6 | 12-20-2006 12:21 PM |
cluttering noise coming from under the hood | LiDrummer | Newbies & FAQs | 1 | 09-12-2006 02:02 PM |
thumping/clapping noise from under the hood | ttatsumi | Legacy Forum | 3 | 07-11-2006 10:09 AM |
squeaking noise coming from somewhere? | WejR20X | General Community | 0 | 10-31-2005 05:12 PM |
