Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 09-18-2019, 03:31 PM   #1
segerton
Member#: 155993
18 WRX Stage 2
Default Mig vs Tig for T304 cobb exhaust
So I'm getting one of those Ultra Quiet Resonators for my Cobb exhaust system to get rid of some drone. Both are 304 stainless.
My exhaust shop says they use MIG. Should I look for another shop that does TIG?
segerton is offline   Reply With Quote
Old 09-19-2019, 12:52 AM   #2
tracknerd
Member#: 53793
02 WRX
Yes.
You can do mig well on stainless, but it's annoying and takes special (expensive) gas to do right, which a lot of places don't actually do. Which eventually results in a rusty mess. And if they do use the right gas the odds are high that they won't be purging with fancy gas and you'll eventually end up with a rusty weld. Paying someone to do tig on stainless really shouldn't cost more then paying someone to do mig correctly on stainless.
tracknerd is offline   Reply With Quote
Old 09-19-2019, 04:14 PM   #3
segerton
Member#: 155993
18 WRX Stage 2
Thanks for the advice. Last thing I want is some rusty stainless..
Old 09-19-2019, 04:36 PM   #4
JSR84
Member#: 469585
I would mark where you want them to go and take the mid pipe off. Take it to a welding shop and have them Tig it. if they ask you if you want it back purged, I wouldn't bother for that part of the exhaust.
JSR84 is offline   Reply With Quote
Old 09-19-2019, 05:03 PM   #5
rtv900
Member#: 428511
2016 STI
I can't believe anyone would even want to mig stainless that thin. That would be a nightmare.
Migging stainless sucks
Old 09-19-2019, 09:02 PM   #6
segerton
Member#: 155993
18 WRX Stage 2
Starting to think I might just get some 3" band clamp and DIY it. Bad idea?
https://www.amazon.com/TOTALFLOW-TF-...ay&sr=8-1&th=1
Old 09-20-2019, 12:10 AM   #7
tracknerd
Member#: 53793
02 WRX
I'd call that less bad than MIG with the wrong gas, you might have a little leak from time to time and you might need to figure out an additional hanger, but I'd take that over rust.
This is the actual correct answer:
Measure twice (or more) and mark it well. It will probably cost less than you expect and should last.
Old 09-20-2019, 12:23 AM   #8
tracknerd
Member#: 53793
02 WRX
I've done it twice on custom downpipes and would never wish it on anyone. Once with the wrong gas (rusted through in one Chicago winter) then once with fancy tri mix gas (still in service with no issues 4 years later). Both times were a pain in the butt. Never again.
Old 09-20-2019, 07:45 AM   #9
segerton
Member#: 155993
18 WRX Stage 2
Thanks for the advice. Are there any heat resistant blanket wrap products that would help with drone? Iíve seen pipe heat/insulation wraps in industrial applications with zippers that would fit.
Old 10-13-2019, 06:50 PM   #10
notaduc
Member#: 373327
Mig welding stainless is ok if they are using stainless wire and argon, technically it should be purged too, but doubtful any shop with just a mig would do that.
A lot of shops will just use mild steel wire and (gas argon/co2) mix to weld on stainless exhausts, this you really want to avoid since it will rust easily.
notaduc is offline   Reply With Quote
Old 10-14-2019, 01:20 PM   #11
rtv900
Member#: 428511
2016 STI
using plain steel wire to weld stainless would be the worst hack job ever and anybody who would do that should be ashamed of themselves.
plus, migging stainless can have oxygen in the mix believe it or not
straight argon is for tig
