Welcome to the North American Subaru Impreza Owners Club Monday April 15, 2024
Old 11-03-2003, 12:48 AM   #1
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
Default Is it possible to bridge 4 channels of sound into 2 for more total power?
I only plan on installing 6.5" components in the front of my STi with no rears or subwoofer. Therefore I was hoping I could bridge a standard 4 channel HU and avoid having to purchase an amplifier.
FWIW, I am looking at an Alpine 9805, 9807, or 9813 and using Reference 6000cs for speakers.
Anyone do this before? Let me know what you think.
-Nick
Uber Wagon is offline   Reply With Quote
Old 11-03-2003, 01:21 AM   #2
surfer.tech
Member#: 39842
2003 WRX wannabe
no man you cant brigde the HU.. your goin to need a seperate amp.. plus itll sound sooooo much better
surfer.tech is offline   Reply With Quote
Old 11-03-2003, 05:07 PM   #3
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
O.k. thanks.
Old 11-03-2003, 06:02 PM   #4
Legacy
Member#: 10188
2007 Forester XT
I'll go one further , bad idea & you'll damage the HU in a day. I have the 9815 myself which is very simular to the 9813. My biggest complaint is they did away with a POWER button and you have to hold the SOURCE button for 4 seconds to power it off. Very bad idea when you need ot turn the stereo off in a hurry. Yes you can just turn down the volume but in an emergency I like to kill the power to the deck in an instant.
Why don't you try to start out with powering the speakers from the front channels of the HU. Its not going to be awe inspiring but it may just be enough for you. That said, having an external amp, nearly any amp will be an improvement over the HU as in reality its about 7 watts rms x 4.
Legacy is offline   Reply With Quote
Old 11-03-2003, 06:33 PM   #5
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
Legacy,
Thanks for the additional feedback on bridging the HU, just thought I would throw it out there.
The power loss you are indicating from a non amped headunit seems really high. The alpine units I am looking at all are rated at 23W rms x 4. That seemed high enough to power component speakers in the front, but if loss through wiring and connectors are that bad then maybe not.
Care to comment?
Old 11-03-2003, 07:05 PM   #6
Legacy
Member#: 10188
2007 Forester XT
No probs, I believe my Alpine is rated for the same power , all the HU manufacturers tend to be VERY optimistic with the output of their decks. To keep things in perspective. A CD deck is about 10 inches long and 7 inches wide. Inside there's the cd player ,its motor and all the mechanisms. Then you've got the ciricuitry for the radio etc.. How much room do you think is in there for the amplifier ? Compare that to say an older RF Punch 30 rated for 15 x 2, the amp is about 8x5 inches.... now it doesn't seem quite possible that you could cram this amp inside an HU does it ?
To address your other concern I don't think you're going to loose a significant amount of power through the wiring, its more the power isn't there to begin with. What I would suggest is you go to your Alpine dealer with the deck you have in mind. Make sure its not playing through an outboard amp and see if gets loud enough for you. Don't forget that a car has road noise, rumbling tires, reving motor so you'll loose a bit of volume with the background noise.
Is it possible to swap an 04 STi console into an 02 WRX? adrive43 Interior & Exterior Modification 21 07-17-2009 04:36 PM
winTV(watching tv on pc), is it possible to watch other channels like overseas? enozto Off-Topic 0 08-31-2005 08:33 AM
Is it possible to change the date of an e-mail? GooseMan Off-Topic 5 02-17-2004 11:30 AM
Is it possible to get the benefits of a lighter crank pulley without the negatives? Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 07-02-2003 01:44 AM
Is it possible to fit 4 16inch rims w/tires in wrx? PaulRex Tri-State Area Forum 18 12-29-2002 11:34 PM
