01-21-2005, 03:27 PM | #1 |
Member#: 926
South East
I need an ej25 ignition map, NA preferably
With the emanage and bigger injectors I am going to have issues withe the stock ecu advancing the timing thinking there is a lower load than there is.
If I had any sort of base map of what the ECU was doing, or close to that, ie what some other EMS base map was set to, I could compare the load values, and use the difference for my map in teh emanage, basically getting me back to the point where timing would have been with the stock sized injectors. Make sense at all? Any maps are welcome, or a link to some place with maps anything.. thanks.
01-21-2005, 04:41 PM | #2 |
Member#: 5349
someone posted this a while back and I saved it for the same thing you want it for
(removed) Last edited by Joncas; 02-01-2005 at 11:34 AM. |
01-21-2005, 04:59 PM | #3 |
Member#: 926
South East
that gives you one row of the ignition table.. the 0 psi boost row.
We need a table of advance at load vs rpm |
Need an ECUTEK stock map | Kastley85891 | Engine Management & Tuning | 3 | 10-24-2007 01:01 PM |
need some fuel/ignition maps | Pi7467mp | Engine Management & Tuning | 1 | 01-27-2004 11:21 PM |
Do I need an ECU re-mapping? | RICKY | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 11-22-2002 09:14 PM |
Need an EJ25 or Long block in portland metro area, OR | Cusco | Normally Aspirated Powertrain | 0 | 01-18-2002 05:31 PM |
Need an EJ25 Intake Manifold | gaylemd | Mid Atlantic Impreza Club -- MAIC | 2 | 04-17-2001 07:50 PM |
