Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
View Poll Results: Do you have a stick throttle cable?
Yes 1 25.00%
No 3 75.00%
Voters: 4. You may not vote on this poll
Old 03-12-2002, 01:24 PM   #1
BYBYV8
Member#: 13103
2002 WRX on N20
[email protected]
Default Sticky throttle cable?
Anyone else have this problem? Any fixes? I don't want to go to the dealer because it would involve me removing my nitrous setup
BYBYV8 is offline   Reply With Quote
Old 03-12-2002, 01:29 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
I presume you've manually operated the throttle body with your hand and observed whether the return springs seem to be working OK?
ColinL is offline   Reply With Quote
Old 03-12-2002, 07:21 PM   #3
TerenceT
Member#: 9510
04 FX35
Pearl White
same thing, sometimes it became up shifting without letting the gas out, rpm would hold at say 3500 momentarily, then drop
could be the heavy fly wheel? which i doubt
TerenceT is offline   Reply With Quote
Old 03-13-2002, 01:00 PM   #4
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Post
It's an emissions thing - there is still fuel/air mixture to be burned so rather than sending the un-burned fuel out the tail pipe, the ecu tells the engine to burn it. That is why the rpms will stay steady or rise momentarily after you let off the gas, particularly if you've been on the gas hard.
It's been discussed before, which makes me think it is normal. A few people mentioned there cars (from other manufacturers) did it as well.
Stanley is offline   Reply With Quote
Detaching throttle body from throttle cable..how? jcbluescooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-03-2008 01:28 AM
Sticky throttle suby53 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-19-2006 09:53 AM
Sticky throttle plate? 04 STI euroauto Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-17-2003 04:43 PM
Sticky Throttle/Throttle Body Cleaning - Warrenty? 85258 Normally Aspirated Powertrain 7 10-17-2003 08:45 AM
Sticky throttle? Chi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-24-2003 11:21 AM
