Brakes & Suspension Forum sponsored by The Tire Rack |
05-18-2008, 12:51 AM | #1 |
Member#: 165104
SCIC
Vehicle:E85 SoCalPorting Owner |
03 wrx brakes on 04 STI rear end?
Hey whats up people. I had a question, could my 03 wrx rear single piston calipers fit on to the STI rear end? I recently did the sti transmission swap and took the whole rear end.. Unfortunately I couldnt get the Brembos.. if they dont fit what could i do to make them fit?
05-18-2008, 03:06 AM | #2 |
Member#: 71875
they don't fit and there are no adapters. You can use 06/07 wrx 2-pots though. There are rotors that work with them and the parking brake that you can get from places like rallispec
05-18-2008, 09:49 AM | #3 |
Member#: 98961
Vehicle:2003 WRX Black |
How about if he switches the backing plates to the 03 WRX backing plates?
05-18-2008, 10:24 AM | #4 |
Member#: 165104
SCIC
Most of these forums say that you can mount the sti brakes on a wrx but you would need an adaptor, or change the backing plates, so wouldnt you think it would be the same? Anyways im about to go try it out and ill let everyone know what the out come is.
05-18-2008, 11:41 AM | #5 |
Member#: 125739
South East
Vehicle:2007 1500HD Need Brakes? 919.420.0021 |
The parking brake is bigger on the STi knuckles and the back plate has different hole spacing.
You could do 2 pot rears - but you'd need the 'gravel' rotors. |
05-18-2008, 04:06 PM | #6 | |
Member#: 71875
You can't use 02-05 wrx brake rotors with those parking brakes anyway. There are only two rotors that will fit - Brembo rotors, and 290x18mm 2-pot/lgt rotors with the 190mm parking brakes. That means there are only two calipers that will fit. |
05-18-2008, 04:36 PM | #7 |
Member#: 98961
The parking brake is part of the backing Plate. If you switch backing plates, you might as well switch E-brakes too. He's trying to use wrx brakes with STI spindles and it seems like the only issue is the backing plate. I'm just looking for confirmation on this too since I intend to do the same thing.
05-20-2008, 08:51 PM | #8 |
Member#: 165104
SCIC
Well I know this took long, but ive tried everything that their is and their is no possible way to mount wrx brakes on a sti rear end. So now im stuck. anyone got advice
05-20-2008, 08:55 PM | #9 |
Member#: 165104
SCIC
My problem was that the wrx backing plate center hole was 1/2 in too small to fit over the hub. and even if it did fit, i would have had too change the location of the wheel speed sensor to pick up the sti reluctor wheel.
05-21-2008, 08:54 PM | #10 |
Member#: 165104
SCIC
ok i found a pare of rear 04 sti rotors, now would i be able to use the 06 07 wrx 2 pot calipers. 0n the 04 sti baking plates
can i use 02-03 wrx struts on 04 sti? | JDMmanny | Brakes, Steering & Suspension | 3 | 03-17-2009 11:02 PM |
ABS question 04 STi rear end on an 02 WRX | overlord | Rocky Mountains Impreza Club Forum -- RMIC | 0 | 07-25-2008 02:21 PM |
06 wrx ---> 04 sti rear end conversion ?'s | rendog24 | Transmission (AT/MT) & Driveline | 10 | 05-14-2008 03:28 PM |
02-03 WRX Struts on 04 STI | stirocker | Brakes, Steering & Suspension | 3 | 08-24-2007 08:04 AM |
02/03 wrx springs on 04 STi struts | jworl | Brakes, Steering & Suspension | 1 | 01-22-2007 01:23 PM |
