I am offering my service of any data logging needs for wrx/stiwith wideband AFR readings. Have an opensource map from a tuner you need flashed? Want to disable codes due to modifications? I can help. I am offering 3 power pull logs, 1 idle, 1 light load with all necessary parameters for your tuner to make revisions on for $50.00. I am NOT a tuner and don't proclaim to be one (learning everyday over past 7 years) but I'm here to help anyone who doesn't have access to a tuner for logs, or doesn't have the tools to do these things themselves. I will come back to do more logs if necessary (if your tuner needs new logs or additional parameters) for only $20 per session after the initial. Again I am not a tuner but I'm here to help if you need these services.
