03-07-2009, 05:44 PM | #1 |
Member#: 203652
E. Canada
Vehicle:2009 Impreza 2.5i Satin white |
DIY: Painting tail lights Impreza 08-09 5 door
I take no responsibility if anything happens, diy are always to use at your own risk.
Alright, after looking around for some vinyl to put on my tail lights and found that it was almost impossible for me to find this weekend, I decided to paint the lights instead. To begin with, you will need: -Flat screwdriver -Ratchet -10mm socket -8mm socket -Extension for ratchet -Painters tape -Exacto knife -Stained glass paint (Can be found in hardware stores) First you start by removing the 2 screws for the outer tail lights. When those are removed, you slide the light towards you. Once the outer tail lights are removed you can remove the inner ones. By using the 8mm socket remove the screws located on the side of the lights when you open the trunk.(forgot to take a picture) After those 2 screws are removed, you need to remove the interior panel of the hatch. You will need to pull hard in order to remove the cover, don't worry you wont break anything. Once the panel removed the last bolt for the inner tail lights is located next to the reverse light bulb, make sure to not drop the bolt. All lights removed. Now for the paint, cover the blinker and reverse part with painters tape. Make the contour with exacto knife. All of this is pretty straight forward. Take the spray paint and paint the lights... You can put as many coats as you want to achieve the tint of your choice, you can also add some clear to protect even more. Once everything is dry, reassemble everything. Hope all of this was of any help sorry if some steps were skipped, this is my first written diy. Last edited by Mr.Durden; 03-07-2009 at 06:14 PM. |
03-07-2009, 05:48 PM | #2 |
Member#: 203652
E. Canada
The paint to use |
03-07-2009, 05:55 PM | #3 |
Member#: 99102
South East
Vehicle:17 BMW M2 Long Beach Blue 6MT |
Good job, thanks for the writeup!!
03-07-2009, 06:28 PM | #4 |
Member#: 96944
MWSOC
Vehicle:2005 SAAB 9-2X AERO 4eat Stage 2 Protuned |
Looks awesome!!!! Much better than vinyl!
03-07-2009, 06:29 PM | #5 |
Member#: 192098
Vehicle:2009 2.5i Impreza 5DR/SWP/5MT |
nice job! too bad my car is leased...
yur rear seats are brown?? |
03-07-2009, 06:32 PM | #6 |
Member#: 203652
E. Canada
03-07-2009, 07:07 PM | #7 |
Member#: 201789
VIC
Vehicle:2008 Impreza 2.5i Satin White Pearl |
Great job! About how long did it take?
03-07-2009, 07:13 PM | #8 |
Member#: 203652
E. Canada
03-07-2009, 07:08 PM | #9 |
Member#: 120152
MWSOC
Nice! I like it!
03-07-2009, 07:10 PM | #10 |
Member#: 183874
MAIC
Vehicle:95 Integra SE w/ 01 ITR exterior!? |
looks flawless, and yes is much better than tint
03-07-2009, 09:34 PM | #11 |
Member#: 195424
Tri-State
Vehicle:2015 WRX |
Good job.. They look much better to me honestly
03-07-2009, 09:41 PM | #12 |
Member#: 128643
Tri-State
Vehicle:2022 WRX White |
do you know if this paint is removeable... lets say you don't like it... or you make a mistake
03-07-2009, 11:06 PM | #13 |
Member#: 204200
BAIC
Vehicle:2008 Impreza 2.5i DGM |
soon to do this to my nasty-altezza-style 08 tail lights too haha
03-08-2009, 09:15 AM | #14 |
Member#: 203652
E. Canada
03-08-2009, 10:12 AM | #15 |
Member#: 194826
Tri-State
Vehicle:'09 WRX 5dr PP DGM '07 VTX1300c, '03 VFR800 |
Wow, that looks fantastic - thanks for the write up and pictures!
You achieved that look without sanding at all?? This is definitely worth a shot! is this an enamel or lacquer paint? EDIT: How many coats did you use to get this degree of tint? Last edited by elwray; 03-08-2009 at 10:19 AM. |
03-08-2009, 07:31 PM | #16 | |
Member#: 203652
E. Canada
I know this one is enamel |
03-08-2009, 07:32 PM | #17 |
Member#: 194826
Tri-State
Cool, thanks for the info! I'll be getting to this soon!
03-08-2009, 12:19 PM | #18 |
Member#: 165121
VIC
Vehicle:15 500 White |
looks good man. here's mine I did a while back pretty much with the exact same steps and material. 4 coats I think, held up nicely to all the washes, rain, and pitiful snow BC gets haha.
03-08-2009, 07:33 PM | #19 |
Member#: 203652
E. Canada
03-24-2009, 12:48 AM | #20 |
Member#: 205509
Vehicle:2009 WRX Silver |
Hey Zordos, lights look great. Did you use the candy apple colour too? Looks darker to me...
03-10-2009, 09:14 PM | #21 |
Member#: 203652
E. Canada
Bump. Sweet cheap mod to do!
03-24-2009, 01:17 AM | #22 |
Member#: 165121
VIC
exact same stuff Mr.Durden used. Krylon stained glass stuff. I used roughly 4 coats
07-09-2009, 04:42 PM | #23 |
Member#: 59036
Vehicle:2016 Forester XT Venician Red |
That looks so much better i'll have to tackle that job to
07-15-2009, 06:42 AM | #24 |
Member#: 59036
I can't find that Krylon paint anywhere around here May have to resort to the Testor's paint.
07-24-2009, 04:50 PM | #25 | |
Member#: 216362
SCIC
Vehicle:2012 WRX Limited SWP |
That krylon stained glass stuff is hard to find in the stores. usually only available through special order. However i was able to find the trust transparent candy apple red. Going to paint my tails by this weeked . I was talking to the guys at the hobby place where i got it and they sed that its not going to be necessary to shoot my tail lights with a clear.. Can anyone here confirm this? |
Similar Threads | ||||
08-09 5 Door Tailight setups | austyg243 | Member's Car Gallery | 31 | 03-05-2010 09:14 PM |
08-09 5 Door Spt Catback | 09subihatch | MWSOC Private Classifieds | 6 | 11-19-2009 06:58 AM |
SPT catback for 08-09 5 door | 09subihatch | Engine/Power/Exhaust | 2 | 08-13-2009 07:47 PM |
WTB: Stock WRX exhaust 08/09 5 Door | Debevemos | NWIC Private Classifieds | 0 | 07-29-2009 12:17 AM |
08/09 WRX Tail Lights vs. 08/09 STI Tail Lights | elscoobie20 | Interior & Exterior Modification | 2 | 07-22-2009 05:11 PM |
