08-19-2011, 01:36 AM | #1 |
Member#: 252352
Vehicle:2000 Impreza L BRP |
Emanage injector question
I was looking through the diargrams in the engrish manual and i see the diagram for channels 1-4 injectors then the sub injectors are listed down below it along with a ground. Is this ground just for the sub-injectors or does it need to be grounded regardless for the normal injector channels?
07-03-2014, 09:47 AM | #2 |
Member#: 395257
as far as i know there is nothing said about have to ground the pin 9 on injector harness from blue manage into ground in the manual instruction
but as long as i wire the emanage, i am connecting the ground wire if there is miss reading data log for duty cycle injector on the emanage tool |
Similar Threads | ||||
EJ22 emanage blue question HELP | DILL_JDA_RALLY | Other Engine Management | 9 | 06-01-2009 10:37 PM |
Emanage install questions | srs14 | Engine Management & Tuning | 5 | 12-20-2006 12:32 AM |
Emanage injector and timing tuning | subachad | Engine Management & Tuning | 5 | 06-30-2004 09:34 AM |
Car won't start. Emanage, injectors, pump | GTR STI | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 04-06-2004 12:08 AM |
emanage install question | GregBolby | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 03-30-2004 05:07 PM |
