07-25-2012, 12:15 AM | #476 |
Member#: 158933
Vehicle:2005 Subaru STi WRB |
Wheels
Seat belts Fender cut A/C Charcoal canister Driver & Pass seat OE radio I'm sure there is more..... I know my other options are: Girodisc rotors
07-25-2012, 12:58 PM | #477 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
Exaust, battery, seats, no windshield washer fluid, UP/BD to the limited trunk to remove the wing, start making custom brackets where allowed, titanium, the list goes on.
07-25-2012, 01:43 PM | #478 | |
Member#: 158933
What's everyone's car weight? |
07-25-2012, 02:09 PM | #479 | |
Member#: 211057
NWIC
Vehicle:2006 STI Matte Black |
I believe my car was around 3050 depending on scales with 3/4 tank of fuel. You could do wheels, brakes, drain the i/c sprayer, empty everything out of the trunk (the interior pieces), a/c delete/ stereo delete, steering wheel, seat belts for harnesses.. i am sure there are more. |
07-26-2012, 01:48 PM | #480 |
Member#: 102581
E. Canada
Vehicle:2006 STI-USDM SGM |
Cutting weight gets expensive, but you can be selective.
I found a 15lbs Buddy club catback. If you have lots of $$$ you can get really light weight seats and brackets, but you are looking at $2k per seat. Sub 10lbs each though. I have some corbeau's with brackets and I'm 25ish lbs. but, I paid $350 for them. Coilovers save weight VS stock struts, so that's a given. Swapping out the UP pipe and DP will save weight too. Spearco TMIC is light weight. I have the APS unit and I don't think I can curl it with one arm. I removed the speakers, but they weigh ounces, not LBS...was dissapointed. I just bought Girodisc 2pc front and rear, so a few lbs there too. I don't know what you did with the Charcoal canister, I don't remember seeing where I could remove that. One thing I was toying with was replacing hardware(bolts/nuts) with Titanium. It could get VERY expensive, but imagine how much weight could be saved by changing out even 30-40 fastners. Of course there are certain bolts/nuts that I would keep as OEM, but you get the idea. I've not had the opportunity to get my car on scales, but I can run with the Fuel light on and not get fuel cut and I generally run it that way. Good luck Eric |
07-26-2012, 03:58 PM | #481 | ||||
Member#: 80649
South East
07-26-2012, 05:28 PM | #482 |
Member#: 25243
SCIC
Vehicle:2006 Legacy Outback Blue |
Hollow Hotichkis sway bars ... Cobb uses them
small racing steering wheel Of course lightest possible wheels (remember wheels are expendables in the long run, they need to be replaced after a few years of hard use). Hoosier are lighter then Kumhos ... don't know about Goodyears? But don't save on OIL !!! :-) ... for AX always run with extra oil if you don't have a baffled sump or dry sump. |
07-26-2012, 05:38 PM | #483 | |
Member#: 80649
South East
18x10 Enkie RPF1's are in the 18lbs range and the A6 in 275-295 is around 23-24 lbs. So you can have a wheel and tire package in the 41-42 range for weight. To put that in perspective, one TIRE for my truck weighs 45 lbs. And that's not even the heavy duty tire. Those go up to almost 60 lbs |
07-26-2012, 06:09 PM | #484 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
I have a Magnaflow Ti catback forsale, the whole catback weighs around 10 lbs. I had it on my 02 WRX but it should fit the older model STIs.
You definitely quickly hit a wall on return on investment with weight reduction. |
07-27-2012, 08:05 AM | #485 |
Member#: 158933
Thanks for all the ideas. I did some more weight cutting last night.
The charcoal can may be removed because of emissions. I'm hoping to get down to 3000# for next year. |
07-27-2012, 09:22 AM | #486 |
Member#: 102581
E. Canada
I built a turn down last year, but I used aluminized steel. Also I had a resonator for the straight area to help with the dB.
It was almost 10lbs!! so, the catback being 15 is good. It is held together with springs at the rear axle, so the axle back can be removed in a snap for the extra 5-7 lbs! I'm going to look into the charcoal canister thing. Any drawbacks? Thanks! Eric |
07-27-2012, 11:07 AM | #487 | |
Member#: 80649
South East
07-27-2012, 12:57 PM | #488 | |
Member#: 162781
08-03-2012, 08:59 AM | #489 | |
Member#: 102581
E. Canada
That was an oversight on my part. I should know better. Guess I'll have to get more creative to save weight.. Last edited by Mojambo; 08-03-2012 at 09:29 AM. |
08-03-2012, 09:48 AM | #490 |
Member#: 179170
South East
Vehicle:2005 |
I weighed my car at the Dixie NT 3115 that was before everything I have done to it. But that doesn't seem right because the only thing I had done was rsb and hoosiers on stock BBS's.
08-03-2012, 10:19 AM | #491 | |
Member#: 6850
Vehicle:1996 Camaro Z28 1LE, '23 WRX & '19 XV |
I'd weigh at a race track if you have one available. Hmmmm, that makes me think of one more reason to take my WRX to Summit Point this weekend rather than one of my Camaros... |
10-24-2012, 09:41 PM | #492 |
Member#: 158933
I am getting rid of a lot of my mods for an SP car. I have quite a bit of stuff for sale:
18x10.5" wheels 14 Hoosier Tires Cusco Rear Diff DW 850cc Injectors (sidefeed) Zeitronix E85 content analyzer Let me know if you would like any of this for your build. |
10-24-2012, 10:42 PM | #493 |
Member#: 80649
South East
What size tires, and what kind of prices for the wheels and zeitronix?
10-24-2012, 11:04 PM | #494 | |
Member#: 158933
4 were ran for nationals this past year 10 have about 30-40 runs on them Wheels I bought them new for $1250 selling for $950 Zeitronix I'm selling for $400 |
10-25-2012, 07:21 AM | #495 | |
Member#: 211057
NWIC
10-25-2012, 10:25 AM | #496 | |
Member#: 158933
10-25-2012, 01:40 PM | #497 | |
Member#: 179170
South East
Vehicle:2005 |
10-27-2012, 09:06 PM | #498 |
Member#: 158933
12-22-2012, 02:47 PM | #499 |
Member#: 42645
NESIC
Vehicle:2014 Audi S4 Brilliant Black |
Who in ASP has replaced their pitch stop? What pitch stop are you running?
I'm going through the rulebook again and it's not clear to me if it's considered to be an engine mount or not, since it connects the firewall to the transmission. |
12-22-2012, 05:03 PM | #500 |
Member#: 21118
I beleive there was a clarification in FasTrack in the last 6 months. Look thru those. Otherwise wait till the 2013 Solo Rules get published and it should be in there.
The Competition (strictly by the numbers) | R Diamond | STi Forum Archive | 9 | 05-22-2003 04:16 PM |
The Competition is Worried..G Stock is worried | Scooby South | Motorsports | 10 | 02-23-2001 04:41 PM |
Weapon R Intakes vs. the competition | Matthew Nelson | Technical Forum Archive | 28 | 09-07-2000 01:32 PM |
Weapon R Intakes vs. the competition | Matthew Nelson | General Forum Archive | 3 | 08-31-2000 12:19 AM |
0-50 vs the competition | bryanw | General Forum Archive | 11 | 08-11-2000 08:15 PM |
