06-01-2009, 09:04 PM | #1151 | |
Member#: 6850
Vehicle:1996 Camaro Z28 1LE, '23 WRX & '19 XV |
You understand that the DS "no diff" thing is new to me, right? I am used to replacing the stock diff every year, just before Nationals, in my FS Camaro. I also had the unfortunate experience of almost running Stompy into a light pole one of the first times I drove it when it was still on stock diffs. Joel told me after the fact that it was prone to shooting off in seemingly random directions if it lifted the inside rear wheel (really, once the wheel came down, it would take off in whatever direction the car was currently facing, not necessarily what direction the wheels were pointing). It was infinitely more controllable with diffs. I didn't have any weird stuff happening like the STi experience yesterday, but neither did I have any problems with wheel spin. So... we'll see. The lack of wheel spin issues could simply be that I'm not pushing the car hard enough.
06-01-2009, 10:21 PM | #1152 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
06-03-2009, 02:27 PM | #1153 |
Member#: 60566
SCIC
Vehicle:2005 XT 5sp, 02 WRX 01 Legacy 95 Impreza L |
I always assume people interested in esp have seen this but I was told that some have not.
Esp Project |
06-03-2009, 02:40 PM | #1154 | |
Member#: 6850
I'm wondering if I should do one for the '06. |
06-04-2009, 01:09 PM | #1155 | |
Member#: 60566
SCIC
I just did it cause it was winter time and I was bored. Also some people search the conversions for 255 swaps. I thought it may help with that process. Plus I wanted to share set-up with anyone else interested in what the car has in it/on it. I don't think I'm going to request it be moved to autocross however. I have a feeling mine will be the STX, ESP, SM, to XP build. |
06-04-2009, 06:16 PM | #1156 |
Cowabunga!
Super Moderator Member#: 185
South East
Vehicle:2014 Impreza Sport Ice Silver Metalic |
I just got the rears professionally rolled (and still the Subaru Paing cracked a bit (but fixed it with a touch up brush).
Should enjoy this weekend down in Sebring! |
06-05-2009, 09:08 AM | #1157 |
Member#: 25243
SCIC
Vehicle:2006 Legacy Outback Blue |
Pro Roll ... did they pre heat the paint with a hair dryer/heat gun?
06-05-2009, 05:50 PM | #1158 |
Cowabunga!
South East
he did, yes. BL/BP Legacies have a little rubber trim on the fender. For it to look flush, they gave the fender a slight crease and there apparently the paint was thin.
Funny that in the new 2010 Legacy/Outback they are back to a normal fender. |
06-15-2009, 08:12 AM | #1159 |
Member#: 6850
I got Tommy Pulliam to drive the car with me yesterday at Turner Field (Atlanta points event). I'd had a new clutch put in on Friday, along with a lightweight flywheel, and while the car was in the shop, I had them disconnect the front swaybar. The car didn't feel much different than the previous weekend, and Turner Field has about the same level of grip as FedEx Field. I'm probably going to mess with some shock settings (again!) before runs at the DC Pro. I'm finally getting comfortable with the car -- which is saying a lot, since Turner Field has this big, scary blue wall of death around most of the course. Tommy PAXed 6th (ST's Tim Smith was 1st overall), and while I PAXed 13th, I was only 0.2s back from him. The course wasn't very conducive to my car, with one turn that was too tight to leave it in second, but too fast for first to be very effective. Overall, I was pretty happy. Karen |
06-15-2009, 08:51 AM | #1160 |
Member#: 60566
SCIC
^^^^^Nice.
I'm getting pretty antsy for the DC pro...... |
06-15-2009, 09:20 AM | #1161 |
Member#: 6850
06-15-2009, 01:37 PM | #1162 |
Member#: 71634
Vehicle:In hibernation... |
Stompy Jr. looks great in that pic!!!!
Glad you're getting more comfortable in the car. The DC Pro will definitely be a blast! |
06-15-2009, 03:33 PM | #1163 |
Member#: 60566
SCIC
Have you had yours weighed yet Karen?
I'd be interested in how ours would compare in weight. |
06-15-2009, 04:02 PM | #1164 |
Member#: 6850
07-15-2009, 12:39 AM | #1165 |
Member#: 130823
Vehicle:1997 Miata |
I'm switching to 285/30/18 Hoosiers on 18x10 Rota SVN-Rs (+30 offset) this week.
Old setup: 275/40/17 A6 on 17x8.5 +48 SSR Type-C Camber: -2.4 front, -1.2 rear Toe: 0 all around Ride height: 14.25" front 13.75" rear I'm running Racecomp T2s w/ 600f/500r springs. For swaybars I have whiteline the 27/29 adj front bar on the soft setting and 24 adj rear sway on the middle setting. I think the car was working nicely with that setup, it rotated well and I couldn't complain about the grip. I'm getting an alignment done on Thursday. With the old setup my front camber was limited by inside strut clearance.. With the new wheels things should be better. I'm going to shoot for -3 front -1.2 rear. I'll get as much camber as I can via the strut bolt before using the plates. Also with the wider wheels I'm concerned about the rear fender coming down on the tire. Especially with just 500lb/in springs in the rear. I think I'm going to reset the ride height to 13.75" front and 14" rear. Any thoughts regarding ride height and alignment? I had my last set of r-comps balanced. The shop I go to has Hunter roadforce equipment. Do I need to bother with balancing my r-comps or can I save a few bucks? I'm looking forward to the new setup. But I'm changing so many things.. I don't know what I'll end up with this weekend. |
07-15-2009, 07:13 AM | #1166 |
Member#: 60566
SCIC
^^^ Pics or it isn't happening
The suggested ride height does not sound out of line at all (thats near where I was, on slightly stiffer spings, pre-fender "work"). Alignment sounds like a good starting point as well. Don't waste your money balancing. G/L and see you in Toledo. |
07-15-2009, 08:39 AM | #1167 | |
Member#: 142405
Vehicle:#716 Group5 S10 |
07-15-2009, 12:33 PM | #1168 |
Member#: 130823
07-15-2009, 01:11 PM | #1169 |
Member#: 142405
I can just try what I did last year and call the day before. I'll be in the neighborhood anyway, so it's worth a shot.
07-21-2009, 01:00 AM | #1170 |
Member#: 130823
Ran the car with the new wheels and alignment this past weekend.
It's 100% more awesome. Car felt stiffer and much more planted. Turn in is quicker but seems to require a little more initial effort. Once the car starts turning it rotates very nicely. I hit a crap load of cones on my first run. I definitely had to slow my hands down and adjust |
07-21-2009, 01:11 AM | #1171 |
Member#: 142405
I am super jealous of your car still.
07-21-2009, 07:03 AM | #1172 |
Member#: 60566
SCIC
^^^^Noice!
07-21-2009, 12:03 PM | #1173 |
Member#: 42048
BAIC
Vehicle:03 WRX Wagon Sonic Yellow |
Awesome setup dodwrx! Do you think you'll see much in the way of accelerated wheel bearing wear?
07-21-2009, 01:09 PM | #1174 | |
Member#: 130823
I've got 82k miles on my car w/ the original bearings. I wouldn't complain if I had to change soon. Hopefully it can wait till winter! I made an appointment to get the car dyno tuned on Monday. I've got a larger TMIC I'm going to try out and it will be good to get some baseline numbers. |
07-21-2009, 01:22 PM | #1175 | |
Cowabunga!
South East
ESP-The 2002 WRX Project | Butt Dyno | NASIOC Project Cars | 803 | 05-08-2022 07:15 PM |
The Competition (strictly by the numbers) | R Diamond | STi Forum Archive | 9 | 05-22-2003 04:16 PM |
The Competition is Worried..G Stock is worried | Scooby South | Motorsports | 10 | 02-23-2001 04:41 PM |
Weapon R Intakes vs. the competition | Matthew Nelson | General Forum Archive | 3 | 08-31-2000 12:19 AM |
0-50 vs the competition | bryanw | General Forum Archive | 11 | 08-11-2000 08:15 PM |
