#126 | |
Subtly Outspoken
Moderator Member#: 238
Vehicle:OG05 STi 51E |
![]() Quote:
![]() Bill
#127 |
Member#: 94890
Vehicle:03 wrx |
![]() My strategy (read laziness) is to just rest the back seat up and buckle the seat belts....
#128 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
#129 | |
Member#: 442
NESIC
Vehicle:25 Mazder CX70 00 S2k |
![]() Quote:
--kC |
#130 |
Member#: 35313
Vehicle:Spry Forester Silver Spark |
![]() I put the bolts in their repective locations, rotate the heads of the bolts so the seat attachments fit over the bolt head but not underneath it. This way the seat is completely loose in there. I have had it this way for 2 seasons and the seat has never budged during a run.
#131 |
Member#: 93301
NWIC
Vehicle:06 CGM STI SM#17 Now with alot less verve! |
![]() Ohlins has a nice rear compression adjustment knob that is connected through a cable from above the rear seat to underneath. I've heard of a couple folks locally doing the same with their KWs (cept for its rebound) with some fabricated stuff. I don't adjust rebound as much as compression, so having inverted struts makes is a tid bit less usefull, but its nice to leave the seat hooked in all the way. So it's possible to be convenient and legal, you just have to be crafty or have a heavy wallet too.
#132 |
Member#: 94890
Vehicle:03 wrx |
![]() Ok, I'm back with another annoying proposition!
I was reviewing the SP rules and noticed something. 15.1c pretty much says you can interchange parts from different year/model cars as long as it was stock equipment on that car. Therefore I have to come to the conclusion that bugeyes can have JDM STi hoodscoops! Now, tell me why I'm wrong... |
#133 |
Member#: 71634
Vehicle:In hibernation... |
I'm not following your logic? Was the USDM bugeye ever sold in this country with the JDM STi hoodscoop? If the answer is no, then you cannot use it in SP. |
#134 |
Member#: 94890
Vehicle:03 wrx |
![]() My thinking is that it doesn't specify that the model from which your replacing parts has to be from this country (or maybe it does somewhere else?). And since the STi scoop is stock on the JDM STi from 01-02 then it should be allowed.
#135 | |
Member#: 71634
![]() Quote:
Someone made a post a while ago about where an imported Skyline GT-R would be classed in SCCA autox. The answer was AM. |
#136 | |
Member#: 117505
Vehicle:2005 RX8 05-08 SCCA BS Natl Champ |
![]() Quote:
15. STREET PREPARED CATEGORY Cars running in Street Prepared Category must have been series produced with normal road touring equipment, capable of being licensed for normal road use in the United States, and normally sold and delivered through the manufacturer’s retail sales outlets in the United States. Cars not specifically listed in Stock or Street Prepared Category classes in Appendix A must have been produced in quantities of at least 1000 in a 12 month period to be eligible for Street Prepared Category. |
#137 |
Member#: 94890
Vehicle:03 wrx |
![]() Damn... I really want the stupid scoop but having to change it every event will drive me nuts. Oh well...
#138 | |
Member#: 442
NESIC
![]() Quote:
--kC |
#139 |
Member#: 94890
Vehicle:03 wrx |
![]() Even still, does it say that parts used from other cars have to be from US cars? Obviously I'm not using a JDM car, just a part off of one...
These rules are starting to get really annoying... |
#140 | ||
Member#: 442
NESIC
![]() If you're going to "swap" parts from one car to another through update backdate, both the donor car and car you're modifying must have been available through dealers in the US AND Listed in Appendix A on the SAME line.
Any updating or backdating of parts has to be from US cars as listed in Appendix A. Again, the 1st sentence. Besides, An STi and a WRX are on different lines in different classes ANYWAYS. It *STILL* wouldn't be legal even if you *could* update/backdate JDM cars. WRX != STi. 2 Different classes. (And at that, the STis listed in BSP are '04+ so even further making what you want to do... not doable.) Quote:
--kC Last edited by KC; 04-04-2007 at 02:16 PM. |
#141 | |
Member#: 71634
![]() Quote:
IMHO, the only way you can run a larger hood scoop legally in SP is to do a full exterior conversion to the '04-'05 front end or the '06-'07 front end. |
#142 |
Member#: 442
NESIC
#143 |
Member#: 71634
#144 |
Member#: 2230
Vehicle:2000 2.5RS Silverthorn, PGT #671 |
#145 |
Member#: 71634
LMAO! ![]() ![]() ![]() |
#146 |
Member#: 442
NESIC
#147 |
Member#: 94890
Vehicle:03 wrx |
![]() Ugh, well I know now you guys are right, but you can't blame me for trying! As for the rule book, simple and annoying are two entirely different things
#148 |
Member#: 27305
SCIC
Vehicle:2008 Impreza STI Aspen White |
![]() Not sure if anyone tried this angle yet.
The hood scoop is a functional part of the intake system, intakes are pretty much wide open in SP classes. Just because our intercoolers are on top of our motors doesn't mean we should be limited in the amount of air getting to it based on the scoop being deemed a JDM body mod. EVO's with front mounts are able to get better cooling by swapping in a bigger intercooler. Why should TMIC's be penalized? I know, I know, this is a bit weak, just trying another angle.... And yes, I put my OE one back on. Last picture around here showed me with the JDM one. |
#149 |
Member#: 2230
![]() does air through the hoodscoop go anywhere other than into the engine? Its clearly part of the hood, not the intake.
#150 | |
Member#: 117505
![]() Quote:
Explain to me how a hood scoop that only feeds are to an inter-cooler has anything to do with induction? Does that air some how find its way into the intake system as well? This is the reason the rule book is so big and full of crap now, they have to cover every angle for guys that cant work with the rules and think they need an edge. ![]() |
ESP-The 2002 WRX Project | Butt Dyno | NASIOC Project Cars | 803 | 05-08-2022 07:15 PM |
The Competition (strictly by the numbers) | R Diamond | STi Forum Archive | 9 | 05-22-2003 04:16 PM |
The Competition is Worried..G Stock is worried | Scooby South | Motorsports | 10 | 02-23-2001 04:41 PM |
Weapon R Intakes vs. the competition | Matthew Nelson | General Forum Archive | 3 | 08-31-2000 12:19 AM |
0-50 vs the competition | bryanw | General Forum Archive | 11 | 08-11-2000 08:15 PM |
