Welcome to the North American Subaru Impreza Owners Club Sunday September 15, 2024
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 01-28-2009, 07:56 AM   #251
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Sparkly
Originally Posted by Patrick L View Post
Brand new STI crank. BTW, the RS and STI crank are the same part number.
http://members.cox.net/pdlip/crank.jpg
ORLY?? I never knew they were the same part. Do you mean to the USDM STi? If so that means the redline should be 7,200 instead of 6,200 (assuming of course the valve train could take it). It's good news to me since I was wondering how high I could spin the 2.5 once I swapped a set of cams in.
subydude is offline   Reply With Quote
Old 01-28-2009, 09:29 AM   #252
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue racecar
My redline is set at 7000.
Patrick L is offline   Reply With Quote
Old 01-28-2009, 11:27 AM   #253
neilschelly
Member#: 94902
1989 Porsche 944S2
Beige
As is mine (EJ22) and Storm's EJ22 too I think. Not that we have any power up there, but presumably the EJ25 breathes a bit better up that fast.
-N
neilschelly is offline   Reply With Quote
Old 01-28-2009, 04:20 PM   #254
wagonman
Member#: 971
Mine is at 7200, and it doesn't do anything but make noise. I have heard rumors that the valvetrain in very similar between the RS and WRX, but the oiling issues is what holds us back from using that redline continually. I know mine never sees it but for a split second, just to avoid the shift to 3rd.
I could be ( and probably am ) wrong about the valvetrain, so don't take my word for it. It is good to know that the crank is the same though
wagonman is offline   Reply With Quote
Old 01-29-2009, 12:22 AM   #255
subydude
Member#: 80649
Sparkly
Not sure about the valvetrain, but I'm glad to know the oiling is good up to 7k. Mine sits at the stock redline at rallyx events for about 30-40 seconds per run. I was thinking of raising the redline with the i-speed reflash and wanted to be sure that it wouldn't hurt anything. Looks like I'll be making more noise
Old 01-29-2009, 12:32 AM   #256
neilschelly
Member#: 94902
1989 Porsche 944S2
Beige
It gains you some top-speed in gearing, which can save you from a shift. It's better than bouncing off a low rev-limiter, but it's not going to give you a ton of power up there.
-N
Old 01-29-2009, 06:48 AM   #257
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^ Exactly.... My limiter is at 7500. I know I don't make any more power up there, but the car continues to pick up speed and I avoid the need to shift and lose time in doing so. It's not much use for anything but avoiding that shift.
I found valve float at around 78-7900 on the phase II EJ22 (iirc, have same springs as the EJ25). Our DOHC EJ25 will run right up to and beyond 8k with zero valvetrain modifications.....fresh springs/retainers only. We surely don't keep it up there too long and we're usually not up there mid corner. So far, we've had no issues other than the need for a catchcan.
Jay
Old 01-29-2009, 11:56 AM   #258
subydude
Member#: 80649
Sparkly
Jay
Interesting. I know I'm not making power up there, but I stay up there just so I don't have to shift. When you're playing in the mud (rallyx) wheel speed is sometimes more important than power. And the time it takes to shift can drop your wheel speed dramatically.
Do you know if the DOHC EJ25 has the same valvesprings as the SOHC? I doubt they do, but I'm just curious.
Old 01-29-2009, 12:13 PM   #259
whiltebeitel
Member#: 201514
1989 BMW 325i
Zinno (red)
Wow, very impressive car. Have you tried to make it to an autocross in College Station with TAMSCC? We've got a nice big concrete site, so you can get some NATS practice in with the recent switch of venue from asphalt.
whiltebeitel is offline   Reply With Quote
Old 01-29-2009, 03:33 PM   #260
Storm
Member#: 5218
96L Most Over-
Developed Beater
I know for a fact that they are not the same. DOHC heads have more options as far as springs go, since EJ257 springs/retainers are a direct fit. I had them in my Brighton when it had the EJ25 in it. I've talked to folks who have had their DOHC heads built with 'busa springs, though I didn't get an answer on required machining or direct fit. Alternate springs aren't legal for DSP, but I believe rallycross rules are different in that regard.
Jay
Old 01-29-2009, 06:38 PM   #261
subydude
Member#: 80649
Sparkly
Jay
Well poop. Good info though.
Rallyx rules are very simple (at the moment). SA is like stock classes in autox. PA is like ST classes in autox, and M4 is like A Mod in autox. Pretty simple
Old 01-30-2009, 12:59 PM   #262
solo-x
Member#: 37624
Yes that is the plan for them to clear the WRX brakes 4 ad 2 pots
Nate, yes dual pattern.
or if you want a seperate sets with a 6" BS.
I'm a definite for 2 wheels with a 6" BS and the 5x114.3 bolt pattern. Not sure where to find someone to buy the other 18 wheels though. I could probably make the neon fitment work if that is a dual bolt pattern though. .25" won't kill me and these won't be my primary wheels anyhow.
solo-x is offline   Reply With Quote
Old 02-01-2009, 12:55 AM   #263
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue racecar
well I got back this afternoon from OKC after completing the engine. Should be able to put her in next Saturday. I just need a few last minute parts like the thermostate and a new bearing for one of the timing belt sprokets. Other then that, everything else is on the old engine in the car.
http://members.cox.net/pdlip/longblock4.jpg
Old 02-01-2009, 07:25 PM   #264
solo-x
Member#: 37624
Looking good man. My motor is still in pieces. I did just drop it off at the machine shop with the new pistons and crap, but it'll be at lest 2 weeks before I start final assembly.
Old 02-07-2009, 11:18 PM   #265
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue racecar
Well the new motor is in and running. I got about 32 miles on it now. I am going to change the oil tomorrow and get about 300 miles before I change it again. All is good so far. Oil pressure is great and my Autometer gauge reads a bit lower then it acually is as I had a calibrated mechanical gauge from work it check it on the initial start up.
Old 02-09-2009, 09:46 AM   #266
Storm
Member#: 5218
96L Most Over-
Developed Beater
Got your message Pat. Good to hear! I dunno what to tell ya about the pressur gauge. If it's an electric type with a sending unit, you may have some amount of adjustment to dial in the signal.
Jay
Old 03-09-2009, 04:19 PM   #267
solo-x
Member#: 37624
teh R lives again. Started the new motor yesterday. Wider 10.5" wheels are done, interior is 90% back in, etc. Projects that are left are fab the passenger seat brackets and install, install the belts, tune the AEM EMS, and kick some BMW and Subie @ss.
Old 03-09-2009, 06:38 PM   #268
Storm
Member#: 5218
96L Most Over-
Developed Beater
pffft..... The Link ECU is now in the FSP car and I'd put it up against our DSP car as it sits! Gotta love the ability to tune the timing curve for good gas!!!! We'll have to look at times next event we run together!
Jay
Old 03-10-2009, 02:25 PM   #269
lulu007hey
Member#: 205283
lulu007hey is offline   Reply With Quote
Old 04-15-2009, 08:17 AM   #270
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue racecar
Here are the results. The old motor and the new motor. Look at where the torque is at the start and what the rpm is on both.
http://members.cox.net/pdlip/patolddyno.jpg
http://members.cox.net/pdlip/patnewdyno.JPG
I am going to need to send off the ecu to have them clean it up a bit. Runs a bit too rich on the low end and fix that lean spike in the middle.
It's not hurting anything. The clean up should give me a tad more power
Old 04-15-2009, 11:41 AM   #271
Storm
Member#: 5218
96L Most Over-
Developed Beater
That's excellent, Pat!!!! Get that ECU tuned ASAP! There's more left on the table for you.
See in Lincoln!!!
Jay
Old 04-15-2009, 12:23 PM   #272
Chiketkd
Member#: 71634
In hibernation...
Nice gains Pat! Congrats!!!
Chiketkd is offline   Reply With Quote
Old 04-15-2009, 07:25 PM   #273
solo-x
Member#: 37624
Nice job Pat! I'm still running a stock 'puter. The AEM didn't make any gains over stock, and the adapter harness was giving us fits, so since we didn't get any extra power, I kept it simple and went back to the stock brain.
The passenger seat brackets got done, and then I decided I really liked how it came out, so I decided to rework the drivers side brackets. End result, the drivers seat is nearly 10lbs lighter!
When I had it on the dyno I noticed it was still puffing a lot of oil out the exhaust, so I sprung for a pimpy catch can setup. Hopefully my guess is right and I'm sucking oil out through the PVC system. It was overfilled by half a quart so that might have been contributing to the issue as well. Plugs looked good though, and the dang thing rips. How much of that is me driving a 90hp 320k mile civic all winter and not being used to a car with power and how much is actually due to it making good power is hard to say. I was on a different dyno then last summer, so I can't compare the numbers between dyno's either, but I'm told it's making about what a car with that engine and set of modifications would make. :shrug:
Old 04-19-2009, 05:13 PM   #274
racerjon1
Member#: 43612
Well...
I am finally officially "checking in" for DSP.
Steven Rankins (pleiades) and I are campaigning my 1999 2.5 RS this year for Boxer4Racing and SubaruPartsPro.com - for those of you that may have been watching for a few years, this is a continuation of our 2005 DSP/STX effort in the 2.5 RS he had before he got his STI.
We had been planning the effort on paper for a while, and finally started throwing parts at the car in February. In March we went to the Dixie National Tour and finished 1-2 and we have continued to work on the car the past few weeks, and though it has a long way to go, it's getting better.
Rankins on his way to first place at the 2009 Dixie National Tour
I nearly captured the car's first FTD this weekend at a South Carolina Region event at the Michelin Laurens Proving Grounds, but got knocked off the top spot by an SSM 300ZX. Here is the on-board video from the event:
http://www.youtube.com/watch?v=nRHc4e7ug1Y
Next up - the SEDIV Event next weekend in Virginia.
Jon K
racerjon1 is offline   Reply With Quote
Old 04-19-2009, 08:35 PM   #275
solo-x
Member#: 37624
Hey Jon! You guys planning on sticking with the tall tires, or will you be joining the 275/35/15 crowd?
BTW, oil out the exhaust = bad, mkay? Damn oil issue persists. At least I don't have PJ's oil problem. His is the kind where the oil won't stay in the block because the block got renovated with some windows, a door, and a skylight. I think he's trying a bit hard with the weight reduction....
Squirells check in.. but they don't check out. Fish Off-Topic 13 08-19-2004 07:59 PM
Check in times for Auto-X in DC sunday KanosWRX Mid Atlantic Impreza Club -- MAIC 1 06-12-2004 06:06 PM
TXIC members who went to WRC check in, cute girls in WRB Wagon we saw you, you better shoracer Texas Impreza Club Forum -- TXIC 0 03-16-2004 01:38 AM
Check in for trade in. TFW STi Forum Archive 18 01-06-2003 10:48 PM
Subie Gal checks in... er... yeah.. STILL in the UK! Subie Gal General Forum Archive 28 05-09-2000 12:06 AM
