05-21-2002, 02:04 PM | #101 | |
Member#: 8069
South East
Vehicle:2016 Fiesta ST Kona Blue |
I think the links would either put you into DSP or straight DP...
05-21-2002, 02:14 PM | #102 |
Member#: 7492
South East
Vehicle:No race cars www.tomhoppe.com |
We get all this info straight from the rulebook
http://www.scca.org/news/index.html#comp_regs The endlinks for the swaybar should be ok to use for SP class. The Sti links should be ok for SM as long as you are not changing geometry. I think SM would be the class for you! -Tom |
05-21-2002, 03:19 PM | #103 | |
Member#: 4181
Vehicle:2003 Lancer Evo 8 It's Blue, ok? |
Anything that cannot be ordered on the car from the factory will put you out of street touring or street prepared. If you can order it and demonstrate that the part is on the factory build sheet or invoice then it is legal for street prepared or street touring. the aluminum lower control arms and STI suspension bits should be good for street mod. The kartboy endlinks should be SP and ST legal. |
05-21-2002, 03:56 PM | #104 | |
Member#: 442
NESIC
Vehicle:25 Mazder CX70 00 S2k |
The car is delivered with lower control arms, just not with the specific aluminums ones. What you just said above as such a blanket statement is totally untrue for the person just reading this thread and want's to get into STS and auto-xing. Your phrase "Anything that cannot be ordered on the car from the factory will put you out of street touring or street prepared." would invalidate any modifications done at all on a car... because no car comes from the factory with things like adjustable coilovers, endlinks, etc.... You may want to make that a little clearer. --kC |
05-24-2002, 02:38 PM | #105 |
Got the F out
Moderator Member#: 4797
Vehicle:05 05, 01, 98, 95 CGM |
Has anyone asked about the legality of the Samco Turbo Inlet hose for STX? I'm not 100% certain which way it falls. It's after the MAF, but before the turbo.
05-24-2002, 03:12 PM | #106 | |
Member#: 4181
If you could order a WRX with aluminum lower control arms installed at the factory, then it would be legal. Basically, if it can't be installed on the car while it's built on the assembly line, you can't install it on your car and call it a "factory item" even though it has factory part numbers. Now when ever we get the STI over here, and assuming the STI has the aluminum lower control arms along with the other suspension bits that we all want to use in STX, STS, or ESP, then these parts would fall under the update backdate rules. I am not sure how the update backdate rules apply to the stock classes. OrionF, the samco turbo inlet hoses might be considered part of the intercooler system. I checked my service manuals and it's not clear to me if the inlet hose is considered part of the air intake or intercooler system. If it is part of the air intake, then it should be legal as part of a cold air intake. The following rules are in question 13.10-a The engine air filter element may be removed or replaced. A replacement element which is taller than standard may not be used to hold the air cleaner cover open. No other components of the air induction system may be removed, replaced or modified. and 17.10-b Alternate air cleaner enclosures up to carburetor or throttlebody. This does not allow any changes to intercoolers. If you have put on the samco Y pipe for the intercooler, then your definately out of ST and into SP or SM. |
05-24-2002, 04:12 PM | #107 | |
Got the F out
05-29-2002, 12:46 AM | #108 |
Guest
Member#:
autox class question for wrx
can i use a alk in esp/stx/sm if i DONT use the "square gold pieces" that changes the controller arms angel? i thought just using the circular bushing would help a bit since the stock ones are squishy...yah im talking like im 5, sorry. |
05-29-2002, 01:15 AM | #109 |
Member#: 1841
NWIC
Vehicle:1999 Impreza RS Silver |
Yes, replacing just the bushings in the stock control arm mounts is perfectly legal.
It's the replacement brackets that are illegal, not the bushings. Sean www.subrew.com |
05-29-2002, 10:51 AM | #110 |
Member#: 9848
Vehicle:2002 WRX Platinum Silver |
1) How about DIY Intercooler Water Sprayers ? If not allowed, is pulling the fuse enough to satisfy? 2) How about Icing of Intercooler before run?
05-29-2002, 11:10 AM | #111 | |
Member#: 4181
Icing the intercooler is Ok, but takes lots of ice. |
05-29-2002, 03:05 PM | #112 |
Member#: 2918
Vehicle:2002 Impreza WRX Silver Sedan |
Revisiting the Aluminum Control Arm(ACA) issue. In Suspension forum:
http://www.i-club.com/forums/showthr...postid=2020557 We've been discussing how this affects AutoX classing and he's saying the ACA is just as bad as the ALK since the pieces that come on it are basically an ALK. If the ALK is not legal in SM, that pushes on into prepared right? Is prepared like SM without seperation or is there actually D Prepared? P.S. Great rules site here if only the SCCA site filled the gaps better. Guess it's all about selling their rule books. http://www.moutons.org/sccasolo/index.shtml |
05-29-2002, 04:12 PM | #113 |
Got the F out
I'll be contacting a couple people to resolve the differences in the ACA mount and the OEM CA mount tonight.
We'll get to the bottom of this yet! I want to find out for myself as I'd LOVE to get the STi kit and install everything but the metal bushings. |
05-29-2002, 10:50 PM | #114 |
Member#: 2918
It looks like the matter has been cleared up. The ACA does not include an ALK. The part it replaces is identical, but the bushing is different(much harder). As explained in the thread I linked to immediatly above.
The Whitelane ALK is the only ALK. |
05-30-2002, 11:28 AM | #115 |
Member#: 4181
Zahnster,
the next question is: Are there any changes to the gemoetry of the suspension? If there are changes to the caster, camber then you might not survive a protest in STX or ESP. Assuming you have installed the ACA, and there are no changes to the alignment settings (from the ACA replacement) then it looks like a good SM upgrade. |
05-30-2002, 11:32 AM | #116 |
Member#: 2918
The Metal piece highlighted in the thread is identical. The only difference is the bushing inside. As far as the ACA itself. Again I think it's all about stiffness. It does not offer any more castor than stock. The only camber changes are whatever you can wring out of the eccentric bolt on the front struts.
-So I guess a question is with the ACA are you in SM or can you still be in STX? |
05-30-2002, 01:49 PM | #117 | |
Member#: 4181
Since you can't order it as a factory option, my first reaction would be no; for the same reasons we can't use STI suspension bits in STX or SP. Hopefully I am wrong. |
05-30-2002, 01:58 PM | #118 |
Member#: 2918
We need an STi so we can update/backdate :-)
SM it is then. Forgot that we already covered that earlier. |
05-31-2002, 02:25 PM | #119 |
Member#: 746
South East
stupid autoX question
I read the faq thing first, but I saw no mention of camshafts.
I ordered the cobb tuning street camshafts. What class will that put me in? my other mods are: 17X7.5 in rims Intake rear anti-roll bar |
05-31-2002, 06:08 PM | #120 |
Member#: 19173
Vehicle:2002 WRX VW GTi Rally Car - G2 |
Subaru Short Throw legal in DS?
Is the Subaru made short throw kit legal for the stock catagory?
05-31-2002, 06:19 PM | #121 |
Member#: 2883
Vehicle:2004 STi Silver/Gold |
The cams will put you into SM. Cams are an item that are quite restricted in SCCA Autocross. Can't even change them in Street Prepared classes.
Chris H. www.subrew.com |
05-31-2002, 08:56 PM | #122 | |
Member#: 7089
NWIC
Vehicle:2016 STi |
Re: Subaru Short Throw legal in DS?
06-02-2002, 04:07 AM | #123 |
Member#: 13540
Vehicle:2006 MKV GTI Black |
I thought this had been resolved. Its installed at the PORT, which is owned by SoA - thus is FACTORY installed. And is also on the window invoice from SoA. Its the Kartboy that is for sure not legal.
06-02-2002, 11:38 AM | #124 |
Member#: 4181
port installed options are considered the same as dealer installed options.
06-02-2002, 01:46 PM | #125 |
Member#: 13540
Has anyone ever gotten an actual verdict from Howard, or seen this in print in Fast Track???
port employees = SoA dealer mechanics = dealer So where does port installed have anything to do with the dealer? Not one dealer's folks have touched the car. The cars are shipped here pretty much bare bones, and what is missing from the factory invoice is installed here. Part of this is to conform to the National Content laws requiring X amount of parts being from the country it is being shipped to and sold in (USA in this situation). |
Rules & Regs For Using This Forum **READ This First** | Ferg | NWIC Private Classifieds | 0 | 01-13-2006 04:44 PM |
New Local Forum Classified Rules *If you want to buy/sell something, read this first | redobs | New England Impreza Club Forum -- NESIC | 0 | 11-16-2005 10:17 AM |
WTB: K&N or equivalent flat filter PLEASE READ THIS FIRST | kaisersouse | Private 'Wanted' Classifieds | 2 | 06-13-2005 04:47 PM |
Thinking about an APS catback for your STI? Read this first. | WRXIN | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 02-24-2004 09:36 PM |
Looking for M2 Performance exhaust? Read this first! | DailyDriver | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 11-11-2003 09:16 PM |
