04-26-2010, 09:28 PM | #1951 |
Member#: 169479
Vehicle:2002 Hybrid WRX Pro-Tune SpeedIndustry |
This is my first year running in auto x and like alot of first timers I am unsure of which class I qualify to be in. I have read the rules book a few times but that thing is more confusing than anything especially for a first timer. I think I might be in the Street Prepaired ESP class, but I am unsure.
If someone could take the time to read over my mod list and give me there input I would appreciate it. Engine: Hybrid engine build: 1. EJ25 Short Block 2. Cometic Headgaskets 3. All new Engine Gaskets 4. Resurfaced Heads "EJ20" 5. ARP Head Studs MRT Tmic Borla Header/ Heat wrapped Slowboy TD05 18G Turbo DW 750 cc injectors Performance Kevlar Timing belt K&N Typhoon CAI Perrin Radiator shroud Perrin turbo inlet hose Perrin Lightweight Crank pulley Custom 2.25" up-pipe TBE Catless Stainless Steel, Silverline Exhaust Walbro 255lph fuel pump Prosport Oil press. /temp. adaptor Amsoil fluids Drivetrain: STi Version 6 RA gears 1-5 Exedy Stage II clutch Polyurethane shifter bushings Engine Management: Pro-Tune Speed Industry Troy, MI Innovate LC-1 Wideband Controller Suspension: Cusco Rear Strut Brace Cusco Front Strut Brace Cusco Front Sway Bar 3-way adjustable 22mm Perrin Front and Rear Endlinks Tein Type Flex Coilovers Wheels/Brakes: Rota Torque G-force 18" X 8.5" w/carbon look center caps & Muteki lugs (summer) Nitto Neo Gen Rubber 235-40-18 (summer) Custom Drilled and Slotted Rotors HP Ceramic Brake Pads
04-26-2010, 09:30 PM | #1952 | |
Member#: 216135
Vehicle:2011 |
04-26-2010, 09:30 PM | #1953 |
Member#: 28685
Vehicle:2004 FXT 4EAT very STi'd |
If you thought your engine was in any way SP legal, you didn't read the rules very closely. The turbo, the block, and the other things that fall between the intake and exhaust manifolds are all illegal. Everything else would be okay I think. You're in SM.
04-26-2010, 10:33 PM | #1954 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
The gears aren't ESP legal either.
04-26-2010, 10:47 PM | #1955 |
Member#: 28685
Whoops, I looked right at that and didn't catch it.
04-27-2010, 11:48 AM | #1956 |
Member#: 169479
So am I able to run in SM with the gearset or no? Thanks for the input by the way, like I said I read through the rule book but it was very daunting.
04-27-2010, 12:51 PM | #1957 |
Member#: 28685
Yes, you can do a whole lot in SM. In fact, the only rule for the entire powertrain is that the engine block must be from the same company a the car, and same type i.e. rotary, piston IC, etc.
04-27-2010, 01:26 PM | #1958 |
Member#: 169479
oh great.... first time running and I will be up there with the big dogs huh?
04-27-2010, 01:32 PM | #1959 | |
Member#: 216135
Vehicle:2011 |
Example: 06 WRX with VF39 & TBE & tune....all suspension is stock. He runs TIR class and the PAX kills! him. Example: EVO IX with 4 point chassis brace and a stage1 tune....all else stock. Even if he removed the brace, he'd still be BSP. Does your club have a street tire category? Without rcomps, you have no chance in open SM, so that might be a good mediation, but PAX is going to be hard on you. |
04-27-2010, 02:58 PM | #1960 | |
Member#: 169479
07-01-2010, 10:54 PM | #1961 |
Member#: 248583
Vehicle:2009 WRX Dark Silver- very hot ;) |
BIG thanks to "TheWRX" for posting this thread!! I'm learning SO much! The racing bug has bite me hard, and I'm wanting to do everything that I can to do this right!
07-10-2010, 01:48 AM | #1962 |
Member#: 237978
South East
Vehicle:02 WRX PSM |
can you add intercooler spayers in ESP on an 02 bugeye?
Right now I have a JDM scoop/splitter (illegal in ESP) but if I put the stock scoop/splitter back in and drilled holes, is that legal? (I dont think it is, but you can always just pop the hood and spay it by hand between runs....) |
08-13-2010, 01:15 AM | #1963 |
Member#: 254715
HIIC
Anyone thinking about running FP or XP? Thoughts?
08-18-2010, 10:22 PM | #1964 | |
Member#: 152298
NWIC
Vehicle:2011 WRX Premium 5dr WRB |
Based on the first two sentences in 12.4, the shifter is considered a "standard part" since it is an available port installed option that could have been ordered with the car. It seems like a dealer installed shifter would also be acceptable since it "could have been ordered with the car". I take the "dealer installed" to mean items that aren't available through the factory or port and are only installed at the dealer facilities. I don't know how the same parts (a factory option) are considered legal in one case and not the other, all depending on where it is installed? |
08-18-2010, 10:58 PM | #1965 |
Member#: 65699
Vehicle:15 WRX WR Blue |
If it is a factory/port installed option, it is legal to add it to the car if yours didn't come with it. Dealer installed options, not available factory or port installed are not legal. So say I wanted the GroupN engine and tranny mounts from the SPT catalog and I ordered the car with them, they'd be installed at the dealer and therefore, not legal.
08-18-2010, 10:59 PM | #1966 | |
Member#: 39086
NWIC
Vehicle:2004 STi White |
It is a bit of a conundrum for the scrutinizers. This would not be cart blanch to install a Kart Boy, Perrin short shifter though. |
08-18-2010, 11:08 PM | #1967 | |
Member#: 65699
08-18-2010, 11:59 PM | #1968 | |
Member#: 39086
NWIC
"APPENDIX F - CLARIFICATIONS STOCK CATEGORY CLARIFICATIONS SUBARU WRX OPTIONS The following items are port-installed options on the Subaru WRX, are listed when installed on the vehicle’s window sticker, and pending evidence to the contrary are considered legal: carbon fi ber trim, turbo boost gauge, titanium shift knob, short throw shifter, rear diff protector, spoilers, arm rest extension." |
11-09-2010, 09:22 PM | #1969 |
Member#: 94615
Vehicle:2017 VW GTI S1+ 2006 STi 341WHP/356TQ |
good info here. thanks for the writeup!
11-17-2010, 01:29 PM | #1970 | |
Member#: 17256
South East
Vehicle:18 Outback on the road.... |
You cannot spray when running (or in grid, I believe) anyway, so you are actually better off just using a pump-up hand sprayer between runs. You can use it on your tires too.
12-07-2010, 08:12 PM | #1971 |
Member#: 266353
Got the guts and skills to race an Evo on TV?
We are looking for a driver & car in Houston Texas to go head to head against an Evo 8, 9 or 10 from EvolutionM in The Forum Wars Season 2 1/4 Mile, Autocross and 0-100-0. A detailed post will be forthcoming.
12-07-2010, 08:41 PM | #1972 |
Member#: 28685
You should put this in its own thread in this forum and maybe also in the blanket Motorsports forum. Unless of course there's already a Forum Wars thread around here somewhere...
01-20-2011, 11:20 PM | #1973 |
Member#: 203065
Vehicle:2016 Golf R Lapis Blue |
I've petitioned SCCA about this, and they're discussing it. An 06-07 WRX has little chance against Evo's and STi's, even with a far better driver than myself. Power isn't everything, but turbo lag and terminal understeer make a huge difference. Unless someone has figured this out . . .
01-21-2011, 11:06 AM | #1974 | |
Member#: 193756
NWIC
Vehicle:2005 LGT Wagon Silver |
01-21-2011, 07:37 PM | #1975 |
Member#: 216135
Vehicle:2011 |
I personally think that all 2.5l wrx should go to stx. All 2.5l wrx can get sti like power but on only 245mm street tires NO wrx has a chance against an STi or evo without real LSDs.
Rules & Regs For Using This Forum **READ This First** | Ferg | NWIC Private Classifieds | 0 | 01-13-2006 04:44 PM |
New Local Forum Classified Rules *If you want to buy/sell something, read this first | redobs | New England Impreza Club Forum -- NESIC | 0 | 11-16-2005 10:17 AM |
WTB: K&N or equivalent flat filter PLEASE READ THIS FIRST | kaisersouse | Private 'Wanted' Classifieds | 2 | 06-13-2005 04:47 PM |
Thinking about an APS catback for your STI? Read this first. | WRXIN | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 02-24-2004 09:36 PM |
Looking for M2 Performance exhaust? Read this first! | DailyDriver | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 11-11-2003 09:16 PM |
