Welcome to the North American Subaru Impreza Owners Club Thursday September 12, 2024
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 07-20-2016, 12:35 PM   #2126
lethies91
Member#: 393980
Default 2011 WRX Hatch DS Swaybar
Many people are saying the swaybar change you are allowed in DS class must be the front swaybar. I've read the rules a couple times and have not seen this specified. Can someone point me to where this is stated?
That being said, I have a 2011 WRX hatch. Is having the larger front swaybar better then having the larger rear swaybar? What is the largest diameter you can comfortably go in the front? I live in SC and we have lots of pot holes.
lethies91 is offline   Reply With Quote
Old 07-20-2016, 12:51 PM   #2127
Xian_1
Member#: 97029
The rules used to be "only the front swaybar" can be changed.. this was revised to "either swaybar" a couple years ago (when Stock became Street and went from R-comps to 200TW tires).
I'll let someone else with GD experience in Stock/Street chime in on the choices available.
Edit:
Yeah, GR... I've got a GD. lol
Xian_1 is offline   Reply With Quote
Old 07-20-2016, 01:40 PM   #2128
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
You mean GR?
I'd go with the biggest bar I can get in the rear. I ran GS with a 22mm rear set to the stiffest setting. I don't think a 24 would have hurt. I just happened to find a deal on the 22.
JourdanWithaU is offline   Reply With Quote
Old 07-20-2016, 10:55 PM   #2129
99GC
Member#: 199207
1999 impreza
white
A rear bar will cause you to 3 wheel when turning, real bad for handling in subarus.
99GC is offline   Reply With Quote
Old 07-20-2016, 11:42 PM   #2130
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Sparkly
Lollerskates
subydude is offline   Reply With Quote
Old 07-21-2016, 05:55 PM   #2131
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
My results say otherwise.
Old 07-27-2016, 05:03 PM   #2132
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
Ive been looking around and have 2 questions if anyone would be kind enough to help me with an answer.
Does Prepared allow for ecu retuning?
Does Prepared allow aftermarket engine and drive train mounts?
Im trying to find out what class I fit into.
86Dreams is offline   Reply With Quote
Old 07-27-2016, 05:03 PM   #2133
subydude
Member#: 80649
Sparkly
Prepared allows both of those, as does SM and SP.
Old 07-27-2016, 06:20 PM   #2134
Thorium06
Member#: 254372
As does ST
Thorium06 is offline   Reply With Quote
Old 07-27-2016, 06:49 PM   #2135
99GC
Member#: 199207
1999 impreza
white
As long as they aren't solid, don't contain more metal than stock, and weigh the same, then yes mounts are legal in ST
And most forms of tuning are legal in ST too
Old 07-27-2016, 07:24 PM   #2136
silverhks
Member#: 242402
Yes, BUT most tunes increase boost and waste gate duty cycles. Both of which are illegal IN STU.
silverhks is offline   Reply With Quote
Old 07-28-2016, 11:29 AM   #2137
99GC
Member#: 199207
1999 impreza
white
True off the shelf maps are usually illegal
Old 07-28-2016, 11:52 AM   #2138
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
Thanks for the answers.
There is definitely a higher metal to rubber ratio for my mounts than the stock ones. Im using Cusco mounts http://www.rallysportdirect.com/fits...smission-mount .
I run significantly more boost than stock ~20psi vs 13.5 at WoT
Old 07-28-2016, 12:06 PM   #2139
subydude
Member#: 80649
Sparkly
Welcome to SM.
Old 07-28-2016, 01:22 PM   #2140
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
Originally Posted by subydude View Post
Welcome to SM.
Thanks, Nice to be here.
Old 07-28-2016, 04:10 PM   #2141
silverhks
Member#: 242402
Welcome to SM.
Ignore him, he just wants to swell the SM ranks.
Ok, don't ignore him but don't jump to SM without thought and a large parts budget
You might still fit in SP. Both boost and the mounts are legal there. What else do you have?
Old 07-28-2016, 04:17 PM   #2142
subydude
Member#: 80649
Sparkly
Mounts aren't legal because the metal/rubber rule still applies there. If he fit in SP I'd have said so
He's to far north to really be cannon fodder for me, but there are others in the area that could need class filler. Plus, we all started as class filler somewhere.
I was even being nice about the welcome and didn't poke any fun
Old 07-28-2016, 05:40 PM   #2143
silverhks
Member#: 242402
Wait, did they change the mount rules for SP? Solids used to be legal...
Edit:
15.10.J Engine and transmission mounts may be changed as long as it doesn't change the position. (Paraphrase)
OR am I misreading it?
Old 07-28-2016, 06:37 PM   #2144
Thorium06
Member#: 254372
The mounts would be legal in ST as well as long as they weigh at least as much as the OEM mounts and do not relocated the motor or trans.
I think you are confused with the bushing wording with the metal to rubber ratio. Engine and trans mounts are a separate line.
Old 07-28-2016, 08:09 PM   #2145
subydude
Member#: 80649
Sparkly
Ok, I must have been wrong. SP it is.
Old 07-29-2016, 11:28 AM   #2146
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
Full parts list? Umm... here goes...
Stock ECU Retuning with Accessport( not ots )
Gauges
Aftermarket radio (its lighter lol)
EBCS
GrimmSpeed AoS
Silicone Intake Piping(all of it)
Wet Panel Filter
STI TMIC
STI Scoop
STI Shroud
Turbo Blanket and heat shield
Header Back Exhaust (catted DP)
Lightweight Crank Pulley
Carbon Fiber Drive Shaft
+2 Rims (18x8 vs stock 16x6.5)
Engine mounts
Tranny Mount
Pitching Stopper
Transmission Bushings
Transmission Cross Member Bushings
Rear Endlinks
Front Camber Bolts
STI Springs
Adjustable Struts
Short Throw Shifter and bushings
Anarchy Knob
street performance break pads
slotted rotors
steel break lines
Soon to be adding an MBC in parallel to the EBCS
.028 plug gap
Old 07-29-2016, 11:46 AM   #2147
subydude
Member#: 80649
Sparkly
There's things in there that push you to SM anyway like the CF driveshaft and bigger hood scoop. You'll be fine in SM locally most likely anyway since most people end up there for little things like that.
The current normal recipe for an SM car is 18x11's with 315's, a real wing, a real splitter, lots of light weighting, 400+ whp, clutch pack diffs front and rear (assuming AWD), ZZYZX (Koni), MCS, JRZ, or the like for shocks, home made suspension bits otherwise, etc.
Where you are you should see Panda (240SX) from time to time if you travel. That car has won the last 3 years in a row at Nats in SM and should give you an idea of the speed required (down the road) to be competitive.
At this point just show up and have fun. Learn to drive, get people to instruct you, and come out to bigger events if you can. Introduce yourself and have a blast
Old 07-29-2016, 11:53 AM   #2148
subydude
Member#: 80649
Sparkly
Originally Posted by Hitler View Post
Will hood scoops increase my downforce?
Old 07-29-2016, 11:54 AM   #2149
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
I just want to have fun. Im aware that this pushes me into a category where theres a lot of much bigger fish. But I love the way the car is now and feel like after 2 years its ready.
can I just google panda 240sx to get an idea?
Old 07-29-2016, 12:01 PM   #2150
subydude
Member#: 80649
Sparkly
Should I use rivets or zip ties to install my vape vent?
Bubble gum.
Rules & Regs For Using This Forum **READ This First** Ferg NWIC Private Classifieds 0 01-13-2006 04:44 PM
New Local Forum Classified Rules *If you want to buy/sell something, read this first redobs New England Impreza Club Forum -- NESIC 0 11-16-2005 10:17 AM
WTB: K&N or equivalent flat filter PLEASE READ THIS FIRST kaisersouse Private 'Wanted' Classifieds 2 06-13-2005 04:47 PM
Thinking about an APS catback for your STI? Read this first. WRXIN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-24-2004 09:36 PM
Looking for M2 Performance exhaust? Read this first! DailyDriver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-11-2003 09:16 PM
