Welcome to the North American Subaru Impreza Owners Club Saturday September 14, 2024
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 11-26-2016, 10:16 AM   #1126
quickag
Member#: 238812
Originally Posted by 96accord View Post
Yes they are.
2008-2014 STi BBS
Offset: +55
Bolt pattern: 5x114.3
Wheel Weight: 20.5 lbs (forged)
OEM-equipped tire size: 245/40R18
Source: http://forums.nasioc.com/forums/show....php?t=2239019
I was under the impression 8 was the max wheel width in DS...but I'm still a noob so maybe I'm confused.
quickag is offline   Reply With Quote
Old 11-26-2016, 10:25 AM   #1127
96accord
Member#: 145105
2015 Honda Accord
Wait for Fraser to reply. I is a n00b also.
96accord is offline   Reply With Quote
Old 11-26-2016, 02:59 PM   #1128
jprice130
Member#: 288225
2014 BRZ
The Premium and Limited trims of the 2016/2017 WRX come with 18x8.5 wheels, so you can use the 8.5" wheels in DS if you have one of those cars. All trims for 2015 and the base trim for 2016/2017 is limited to 8" wheels. I assume Dr Fraser must have a Premium or Limited from 2016/2017. The downside with those trims is they all come with a sunroof, so that extra weight up high is kind of sucky.
jprice130 is offline   Reply With Quote
Old 11-26-2016, 08:33 PM   #1129
DrFraserCrane
Member#: 302272
16 WRX
That is correct, I have a limited trim level. Wider wheels, but at the cost of super soft shocks, a sunroof up high, and a heavy power driver's seat. But then again, if I start moaning about the weight disadvantage, I should hit the gym and lose 20lbs before I blame the car
DrFraserCrane is offline   Reply With Quote
Old 11-27-2016, 07:16 PM   #1130
96accord
Member#: 145105
2015 Honda Accord
So you are saying a '17 WRX Limited can run 18x8.5" wheels but my '15 WRX Limited can't? SMH :-/
I know rules are rules but same car just different year.
Old 11-27-2016, 09:12 PM   #1131
DrFraserCrane
Member#: 302272
16 WRX
thats correct. but they also fooled with the shocks from 15 limited/premium to 16+ premium/limited along with the wheel sizes
Old 11-30-2016, 05:33 PM   #1132
JasonS82
Member#: 452012
I just had an alignment done at a well known performance shop in Tampa, Fl. They claimed they could only get -.8 degrees negative camber. It seems most say they can get -1.5 or so. My car is a bone stock 2016 wrx. Am I missing something? Are people over exaggerating? Did they shop not know what they were doing? Is there something different with my car? They said it did not have eccentric cam bolts and they tried every thing else to eek out as much as they could.
JasonS82 is offline   Reply With Quote
Old 11-30-2016, 05:51 PM   #1133
wiUFsh
Member#: 296667
2011 Forester 2.5X
Dark Grey Metallic
I suppose there is a possibility that your car may be different but I was able to get -1.5 from both front wheels, not an exageration.
The tech was able to get -1.7 out of the front right but he set both at -1.5 since that's all he could get from the front left. My alignment was performed on bone stock suspension hardware.
wiUFsh is offline   Reply With Quote
Old 11-30-2016, 05:57 PM   #1134
JasonS82
Member#: 452012
The only thing that throws me off is that this is a reputable performance shop that has been around a long time. I just don't get it. Paid 80 to get an additional -.3 of camber. I looked at the bolts and the has the tick marks on it and I was under the assumption that was an eccentric bolt. Dont know what to think...
Old 12-01-2016, 07:42 AM   #1135
DrFraserCrane
Member#: 302272
16 WRX
The top bolt of the 2 strut bolts that hold the strut to the knuckle is eccentric.
see this post for adjustment description: http://www.iwsti.com/forums/4005830-post38.html
You can also eek out a little more by loosening all the bolts (2 on strut at knuckle, and 3 on the top mount) and push the whole assembly to gain camber through whatever tolerances are in the mounting points.
Old 01-15-2017, 08:57 PM   #1136
wiUFsh
Member#: 296667
2011 Forester 2.5X
Dark Grey Metallic
I'm chompin' at the bit to get back out there this year.
Do you guys have any plans for new car bits? I'm getting new tires, brake pad/rotor/lines upgarde, and thinking about coilovers.
Old 01-15-2017, 09:12 PM   #1137
_brian_
Member#: 337626
2015 WRX
Crystal White Pearl
GTWorx bilsteins/RCE yellows/Whiteline top hats. should be fun. just the -2.2 front camber alone will help.
_brian_ is offline   Reply With Quote
Old 01-15-2017, 09:24 PM   #1138
wiUFsh
Member#: 296667
2011 Forester 2.5X
Dark Grey Metallic
Old 01-15-2017, 10:02 PM   #1139
96accord
Member#: 145105
2015 Honda Accord
Nope stock 4 lyfe.
Old 01-16-2017, 12:24 PM   #1140
_brian_
Member#: 337626
2015 WRX
Crystal White Pearl
yup. i got them off a member here for like $100
Old 02-07-2017, 08:07 AM   #1141
mball19
Member#: 322749
Originally Posted by DrFraserCrane View Post
1). Driver aids -- I've run with the TCS full off and in TRAC mode. TRAC mode takes some getting used to the brake pulsing that pulls the car back on line, but the system works well. I would feel both out personally.
2). Can't help, I swapped by brake fluid before my 1st event in this car
3). Ive not had any overheating issues, but I usually pop my hood between runs, spray the intercooler, and leave the car running to cool down the charge temps and to keep the oil circulating
I just bought a 17 and am going to autocross it in a couple weeks. How do I turn off all the traction control? Hold down the button for 2 seconds until all the lights come on?
mball19 is offline   Reply With Quote
Old 02-07-2017, 08:10 AM   #1142
wiUFsh
Member#: 296667
2011 Forester 2.5X
Dark Grey Metallic
Yes. If you continue to hold it for another few seconds past the initial dash lights that turn of TC then TRAC mode will turn off too.
Old 02-07-2017, 08:13 AM   #1143
wiUFsh
Member#: 296667
2011 Forester 2.5X
Dark Grey Metallic
I just installed these, RCE yellows, and SPC camber bolts last weekend. The car feels completely different now. Very pleased with the results.
Old 02-07-2017, 08:24 AM   #1144
96accord
Member#: 145105
2015 Honda Accord
Good Luck!
Where do you live? Autocross here won't happen for another 2ish months..
Do you know how is the competition in the new class you are in?
Old 02-07-2017, 08:38 AM   #1145
wiUFsh
Member#: 296667
2011 Forester 2.5X
Dark Grey Metallic
I've been racing in STX ever since I've been autocrossing. The competition is tough (those damn BRZ/FRS) but I've been holding my own pretty well.
My new RE-71R tires, Hawk HP+ pads, and Stoptech stainless lines will help out nicely too.
Old 02-07-2017, 07:07 PM   #1146
mball19
Member#: 322749
Thanks. I will try it
Good Luck!
Savannah, GA. We had an autocross 10 days ago and the next one is the last weekend of February. It was 80 here today.
Probably not that great. I have another stupid question. Can I use 5mm spacers with the stock wheels and lug bolts? Forget the last question, I found my answer. I was thinking that a little extra "poke" with the stock wheels may help for autocrossing but, I don't think it is worth it.
Old 02-07-2017, 08:12 PM   #1147
wiUFsh
Member#: 296667
2011 Forester 2.5X
Dark Grey Metallic
I've known a couple of guys that race 15+ WRXs in Street with spacers. The stock studs and lugnuts have worked for them. Making your stance wider won't hurt. What made you second guess your idea?
Old 02-08-2017, 05:32 AM   #1148
mball19
Member#: 322749
I read some posts on the internet that made it seem potentially dangerous. Do you know how thick of spacers that they were using. I wouldn't mind throwing some 3mm or 5mm spacers on the car.
Old 02-08-2017, 05:33 AM   #1149
wiUFsh
Member#: 296667
2011 Forester 2.5X
Dark Grey Metallic
To be within Street rules, they were using 5mm spacers on the stock wheels.
Old 02-09-2017, 05:41 AM   #1150
mball19
Member#: 322749
And they haven't had any issues Autocrossing with the 5mm spacers?
