03-07-2019, 10:22 PM | #1351 |
Member#: 488796
We run a 25mm Perrin rear sway. Would try something bigger if it was available. Still spins the inside front wheel on corner exit.
03-08-2019, 01:54 AM | #1352 |
Member#: 391014
Vehicle:'22 Premium ISM |
I have Eibach 25mm front, KartBoy links, & happy handling.
03-08-2019, 11:34 AM | #1353 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
04-17-2019, 01:41 PM | #1354 |
Member#: 295970
Vehicle:2019 STI CWP |
Looking to run some swift Spec R springs, with a 255/35/18 on Pilot as4's, and some option labs wheels (18x9.5 +35mm offset)
How much negative camber in the front should I be trying to dial in, as opposed to rear? If I'm trying to reduce understeer, I should be trying to max out negative camber in the front, and add some positive in the rear correct? without modifications, can I adjust camber slightly? Also, this set up will put me in street modified correct because of the wheel width? Last edited by vlad11591; 04-17-2019 at 03:19 PM. |
04-17-2019, 05:34 PM | #1355 | |
Member#: 2272
BAIC
Yes you would wind up in SM. |
04-17-2019, 05:47 PM | #1356 | |
Member#: 5691
BAIC
Vehicle:2001 2.5 RS Silverthorn |
It's not about max one or the other it is about having somewhat more camber and therefore more grip in the front. If you max the front and go positive in the back you will be wildly tail happy |
04-17-2019, 05:55 PM | #1357 | ||
Member#: 295970
In order for me to stay in STX, max would be 245/40/18 and 8.5 wheel width. I could go STU and run 255, with the 9.5 wheel width. My offset would still have to be within 7/mm of stock wheels? In that case, i could get by by running spacers, if i wanted that +35/38 offset..... Then i have to spend more money ... blehhhh Quote:
To give a bit more insight... This will also be my dd. I'm assuming I'll probably be around the first specs with the drop. Probably a bit less. It'll be my first event, and i have absolutely no experience. The only reason i might get a new set of tires/wheels is because my OEM tires have low tread. (Dunlop sport maxx) I might just run stock for the first season, or until they're cooked. |
04-18-2019, 01:50 AM | #1358 | |
Member#: 2272
BAIC
BS prepped Type-RA STX suspension/brakes/wheels/tires BRZ FS prepped Chevy SS As for springs, I've been there and done that with running "just" springs. Either run your stock suspension and stay in stock class, or get coilovers. Don't waste money going on the "in-between" setup and then wind up buying coilovers later anyway. Wheels are the same, buy the wheel size/setup people are running for competitive setups in your class right off the bat instead of buying 2 or 3 sets of wheels trying to figure things out. If your car is your daily, run TWO sets of wheels/tires. Running the VERY expensive pilot super sports you mention for tires are a total waste for Autox as not only will you wear out good expensive daily driver tires, but you also won't be competitive. Run whatever setup you want for looks (BTW I recommend Firehawk Indy 500's over PSS if you really are concerned about money as they are 95% as good as the PSS but almost half the price) and run a second set for Autox. Swap out the day before the weekend, only takes 30 minutes or less to swap wheels. |
04-18-2019, 12:03 PM | #1359 |
Member#: 134005
Vehicle:2004 WRX Premium PSM |
Can backup the claims above.
Stock suspension for street class or coilovers in touring, period. I'm running STI pink springs on KYBs and it's incredibly hard to be competitive, even with RE-17Rs. I'll be buying a BRZ in the future and plan on going to a solid coilover setup when I modify. No monkeying around. Also ran RE-71R's as daily tires. Slight toe out in front, so the insides are all worn and will probably fail first. Not to mention the tires themselves are probably heat cycled out at this point, mainly from the daily aspect. Get a $125 impact gun, extra set of wheels, swap um. I've gotten it down to about 7-10 minutes to do the entire swap each event. Worth it IMO if you daily it at all or if the event if more than 30 minutes away. If you're goofing around with anything other than RE-71Rs or the BFG Rivals, you're putting yourself at a huge disadvantage. There is no compromising on tires. You're either running competitive ones or you aren't competitive. |
04-18-2019, 12:15 PM | #1360 | |
Member#: 498642
Vehicle:'19 WRX Ltd 6M dgm '08 Mustang GT (the toy) |
It's very much a case of "beauty is in the eye of the beholder", where they look just right to you and enthusiasts with similar car activity interests because you know exactly why they look the way they do (and that impressing those who don't know anything about autocross or track day driving isn't part of it). In a way, it's like being privy to "insider knowledge". I haven't pushed the new WRX past 6 or maybe 7/10ths yet, but I do notice the EPAS. More accurately, what I notice is what it isn't letting me feel. Norm Last edited by Norm Peterson; 04-18-2019 at 12:34 PM. |
04-18-2019, 02:37 PM | #1361 |
Member#: 295970
Thanks for all the helpful insight fellas....
If I want to stay in Street, i'll have to keep my tire size at 245. I have an AP and some shifter upgrades so that will take me out of DS. I have enkei Kojins, for the winter set up, so I could use those (not super light weight, but better than stock) for now, or just pick up some Enkei RPF's, (18lbs a wheel). As for the tire.... I might go to a couple events on stock and get a feel for everything (non competitive) before I go balls out on some new tires. Indy hawks are dirt cheap, and it doesn't seem like I would compromise too much with going with those tires. I'm running swift Spec rs with possible LCA's, to adjust camber, so that will also put me out of DS. |
05-14-2019, 02:48 PM | #1362 |
Member#: 295970
Update: Went with Enkei TS10's (lightweight 18lbp wheel) 18x9.5 +38 mm offset, wrapped in indyhawk 500's , on Swift spec r springs.
Alignment- Got some SPC front camber plates to get a little more negative camber but basically was able to get -1.5 front and the rear was obviously not able to be adjusted without lower control arms. Sat at about -2.4/-2.2 . AS close to zero toe all around. with the wheels/suspension I should still be at STH. I know I won't be awfully competitive, but I want to do a couple of runs on this set up to see where I can improve in (the driver). Then i'll get some coilovers/lca's/end links to adjust suspension/camber a bit |
05-15-2019, 05:59 AM | #1363 |
Member#: 501606
NESIC
Vehicle:2005 Impreza WRX STi |
Does your car have camber plates? Last autox I went to, a cool guy showed me a trick he does on his '06 STI. He has his alignment set so that when his camber plates are set to max, he has like -3.5 degrees of camber and a little toe out. But when he needs to drive the car to and from the autox, he slides the camber plates to a marked position near the middle where he has 0 camber and 0 toe. Saves his tires from wearing on the street. I'm not sure if the newer Imprezas have the steering on the same side of the knuckle as the GD tho. It would have to for this trick to work.
08-24-2019, 11:41 AM | #1364 |
Member#: 149715
I'm thinking of running 275 bfg 1.5 on either the front or all around.
Anybody try 275/35 18 on front with the 245/40/18 in back ? I've got two of each so I was thinking of trying this. Any idea if the .1 diameter difference will beat the crap out of the diffs ? This is on a 2018 WRX performance package. Thanks ! |
08-28-2019, 08:37 AM | #1365 |
Member#: 485903
Vehicle:2018 WRX (Retired) White |
If you can get the 275's on 8.5 rims, I'd say go for it. The 275 front / 245 rear might be a better choice for the rotation necessary for AX. It has been my experience than whenever adding overall general grip to a WRX (i.e. better tires or wider tires), the rear tends to get more of it making the car unwilling to turn. I think that's why fast DS WRX's run massive rear sway bars. I don't think a rear bar is available to balance a WRX with (4) 275's, but there is only one way to find out. The Street rules don't allow the lateral cross bracing of the rear sway mounts which I think might be necessary with a 24mm+ bar on full stiff.
09-03-2019, 04:32 PM | #1366 | |
Member#: 79547
Anyone know if Dennis had issues in the Pro finale? Maybe he will give us an update at some point. |
09-08-2019, 03:31 PM | #1367 |
Member#: 452012
Spring Rates?
Going to be picking up some Fortune Auto 510's for the WRX and looking for advise on spring rates. Current set-up is 255/40/17, -2.4 up front and zero toe all around and a stage 1 tune from MAPerformance, and hawk pads. I race in a local club with pretty open rules for the "modified" class. Plan is to get the 510's with swift spring 8k fr and 9k rear. Any opinions?
09-09-2019, 09:47 PM | #1368 |
Member#: 443043
Spring rates are very much personal preference. Many seem to prefer a rear bias (RCE for example runs 9/10k on their Tarmacs). Despite coming from a RWD background, I'm not terribly keen on oversteer in the WRX as the rear is so light. Increasing front grip is better than directly inducing oversteer, IMO. I'm happy with the 9k/7k my Ohlins came with - I get handling neutral via adjustable sways, relatively less rear camber than front, and tire pressure.
Besides the basic high temp brake fluid and bleed - consider adding brake ducts to the front. Search for the Porsche GT3 ducts that are popular with the BRZ/FRS crowd. Cheap, effective, and easy install. The back of the WRX dust shields are already slotted for airflow to the center. I've had mine on year round for several years in New England without issue. |
09-10-2019, 11:45 AM | #1369 | |
Member#: 498642
In general, fix front grip first before trying to fool the car into thinking it's neutral or oversteerish by throwing away rear grip. Norm |
09-10-2019, 12:11 PM | #1370 |
Member#: 254372
In general yes, but you need to do some math. Even starting with just the motion ratios front to rear, you need a stiffer spring in the rear than the front to even be neutral.
09-10-2019, 12:28 PM | #1371 | |
Member#: 498642
You still want to fix the 'weak' end as much as possible first. Norm |
09-10-2019, 08:46 PM | #1372 |
Member#: 443043
Yeah, I did the math before installing the coilovers and thought I would need stiffer springs in the rear (something like 9k/10k or 8k/9k) with the constant for the motion ratios being about 0.96 front and 0.67 rear, IIRC. But - the grip level is excellent and I can't even get close to 10/10th's on the street.
It's art as much as science (coming from someone with a hard science background). To the OP, 8k/9k will work. Depends on exactly what you are after. If you don't hit it off the bat, there's are multiple ways to dial it in to your liking. Last edited by gtsilver944; 09-10-2019 at 08:51 PM. |
09-11-2019, 12:34 PM | #1373 | |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
09-11-2019, 12:59 PM | #1374 | |
Member#: 498642
Apparently if you can stay on top of the compromised response and precision you can gain more from increased peak grip than the compromises cost you. Fortunately, the Tire & Rim Association rim width guidelines are not inside-you-pass/outside-you-fail in nature. Lots of autocross tire to wheel fitments are outside T&RA guidelines, but reasonably do-able because autocross runs are of such short duration and because tire life under autocross conditions is pretty short. That makes outside-T&RA-guideline fitments OK only for autocross; they're still a poor idea for any other driving. Norm |
09-12-2019, 01:50 AM | #1375 |
Member#: 506276
Has anyone driven a 15+ WRX and a 15+ STI on track/autocross - i'm keen to understand just how much the DCDD/Diffs on the STi make to the amateur track day entrant.
