Welcome to the North American Subaru Impreza Owners Club Thursday August 5, 2021
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 06-30-2016, 01:15 PM   #76
lpxltt
Member#: 395574
2007 OBS
That one is a 220v unit. All of the MIG/Flux units are that way it seems. The 110 units are only flux (which is weird, from what I read flux usually requires more juice to run).
This weekend I plan on cutting up an old WRX sedan shell I have to take the whole strut towers out. That way I know I will have whatever material I need and the sheet metal will be as close as possible.
I will probably be tackling this some time after NEFR.
BTW, what is the best way to get all of that undercoating off? I'm assuming sand blaster is my best bet?
lpxltt is offline   Reply With Quote
Old 06-30-2016, 01:21 PM   #77
norcaltuna
Member#: 286686
2003 WRX EJ207 VF36
Just saying.... I LOVE my 120v Lincoln "handy mig." Available all day at Home Depot, flux or gas, pos or neg and lays a stack of dimes on 1/8 steel on a 30a socket, and welds sheet metal on the end of any orange cord. Get an auto dimming hood : )
norcaltuna is offline   Reply With Quote
Old 06-30-2016, 01:41 PM   #78
lpxltt
Member#: 395574
2007 OBS
That unit looks like a pretty solid choice. Not that much more than the HF specials and I'm sure is a better product.
Old 06-30-2016, 03:58 PM   #79
Snowphun
Member#: 1800
Doh, sorry about that, I was looking at the price and the amps. The low end Lincoln is the way to go, either the HD special model or the HD3200 I have off CL or Ebay. Mine is ten years old, rarely gets used but I used it this week for 3+ hours and it's a champ.
Snowphun is offline   Reply With Quote
Old 09-01-2016, 01:18 PM   #80
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
My car came from up north and I just discovered this on both sides I've never welded so I've gotta find someone willing to help. Thankfully the holes aren't as big as some of the others I've seen here.
codesoccer is offline   Reply With Quote
Old 09-24-2016, 12:13 AM   #81
ChuckNorris2344
Member#: 455203
05 STi
Voila my 02 wagon lol
See the fabulous wall ripping at the top plate lol
..actually still on the road this car!!
Multiple hours and beers and redneck welder.
ChuckNorris2344 is offline   Reply With Quote
Old 05-02-2017, 09:48 PM   #82
lpxltt
Member#: 395574
2007 OBS
So bringing this back from the dead a little bit.
After two friends found the same issue as displayed here and I haven't had the time to repair the car yet, I figured I would shoot them an email.
Long story short, Subaru doesn't care if this might kill someone some day. But they are willing to throw $500 "Loyalty" coupons at you to stay quiet, only for the purchase of new vehicles of course.
Old 08-13-2018, 02:13 PM   #83
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Zombie thread, I know. However, just moved to PA from the Southwest (AZ and CA), so this kind of scares me.
What kind of preventative maintenance can help mitigate this?
And I assume that this will be an issue for any MY subaru, not just the early oughts?
SirBrass is offline   Reply With Quote
Old 08-13-2018, 03:28 PM   #84
Snowphun
Member#: 1800
This is a know issue for GG chassis cars (MY02-07 Impreza wagons, 9-2X) due to the boneheaded design Subaru used for the folding rear seat brackets. Maybe it's also an issue on other wagons but I haven't heard of it.
Seam sealer on the exposed bracket hardware in the wheel well, hose the bottom off frequently in the winter, that's about all you can do. And get snow tires.
Old 08-13-2018, 03:46 PM   #85
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
We've got the Outback listed by my name, so I'll check the next time I have a chance to take a look. And I'll make sure the '19 WRX I'm going to get doesn't have the same issue either.
Old 08-15-2018, 09:58 AM   #86
lpxltt
Member#: 395574
2007 OBS
I think the more modern cars are designed a little better... kinda... Our 2018 Crosstrek has a rear wheel well protector that the older cars didn't/couldn't have due to suspension design. The best bet is to use some kind of seasonal rust preventative. Fluid film or New Hampshire oil company are bother good choices.
I haven't taken a look at the newer Outbacks yet but I'm assuming they are designed like the Crosstrek with the plastic plates all over the bottom. I would hope that helps prevent at least a little rust...
With that being said, you are living in a state that salts the earth because people are too stupid to use proper equipment on their vehicles. Eventually, you are going to develop some kind of rust because there is always that area that can't be cleaned well enough or is a hidden issue like the one in this thread.
With that being said, in regards to the specific issue in this thread - you don't have to worry. It's a specific 02-07 Impreza wagon issue. To my knowledge there isn't the same kind of crazy hidden danger like this in the your car - at least not one that has been found yet.
Old 02-15-2020, 07:47 PM   #87
Swed-Ish
Member#: 369168
2005 92X Aero
02 WRX, 06 OBXT
Angry Joining the club
Well I'm officially joining this sad crew. Pulled the rear suspension to install a new set of coilovers, and noticed a small orange rust spot showing through the undercoating.
Remembered reading this thread a while back and decided to pull the rear interior to check...
Rusted right through on the drivers side.
I haven't finished pulling the passenger side yet, but I'm assuming it will be identical. I'm going to try and tackle the repair myself and buy a welder (always knew there would be a need). Anyone have any tips for keeping the seat locking bracket in the same spot, or is it just a matter of measuring your distances and marking the new piece of metal?
Also seems like Subaru used to sell the entire piece... https://www.subarupartsdeal.com/part...1650fe020.html
Swed-Ish is offline   Reply With Quote
Old 02-15-2020, 09:13 PM   #88
Snowphun
Member#: 1800
The seat back bracket is the easiest part: once the repairs are done clip the brackets into the seat, then put the seat into the upright position. You'll be able to see the bracket, position it and mark the repaired towers. A few tack welds and good to go.
Plasma cutter makes this much more manageable, you'll need to cut a lot more than it appears, and it looks like yours has crept around the sides as well. There's a welder/fabricator in central CT that repaired my most recent wagon for ~$700, can be done in less than a day. The stock metal is soda can thin, it's tricky to do a clean job.
Old 02-15-2020, 10:15 PM   #89
Swed-Ish
Member#: 369168
2005 92X Aero
02 WRX, 06 OBXT
Thanks for the tips on the rear seat, and placing it in the upright position! Also mind DMing me the fabricators info? Always helps to know more skilled people.
Old 02-17-2020, 06:29 AM   #90
Snowphun
Member#: 1800
I'll leave it here in case anyone else needs it:
Brian Goetz
60 Belamose Ave Rocky Hill CT
(860) 841 0245
Good dude, easy to work with. He has a shop at that address, that's where we did my car. He is also mobile so depending on location having him come to you may be easier as you can have the car on stands, struts and interior removed, ready to go. Then you don't have to rush the primer and undercoating.
Old 05-06-2021, 10:01 PM   #91
Swed-Ish
Member#: 369168
2005 92X Aero
02 WRX, 06 OBXT
News Updates
Part 1
Sorry for not posting the updates of what I ended up doing about the rust. Last year shortly after my previous post on this thread I took the plunge and bought a cheap flux welder from harbor freight, a few cut off wheels for my angle grinder, some Por15, and sheet metal to tackle the job.
I started out by making sure all of the interior was out of the way and removed the back seats.
Once that was done I marked out the area that I wanted to cut away (It's going to be more than you think), and chopped out that area leaving a clean hole.
At this point I needed to check inside the wheel well to see what type of rust was hidden on the other side. You'll notice a small spot on the right of the main hole that I began to worry about.
I cut a piece of sheet metal to test fit and begin the process of tack welding it into place.
Little gap here on the right that I end up filling with a new piece.
Old 05-06-2021, 10:06 PM   #92
Swed-Ish
Member#: 369168
2005 92X Aero
02 WRX, 06 OBXT
Default Part 2
Part 2
Finally decided to cut out another square that had rusted in between the two pieces of metal that make up the strut tower. Put a thicker single piece of metal there and welded it in.
Down to the end! I covered everything with Por15 inside and out and reattached the seat bracket with a bit of marine epoxy. Once that was dry I covered the wheel arch with automotive undercoating
My welds are ugly as sin, but are water tight and should stay protected with the coating of por15. This was a VERY time consuming job, but I'm glad I did it and saved the car from a slow death.
I checked the other tower as well and it looks factory new. Not going to complain.
Old 05-07-2021, 10:13 AM   #93
WhiteZombie
Member#: 338863
PSM 05 WRX WGN 5MT
95 Caprice 6spd Track Rat
Part 2
Not bad! I feel like this fix can be ugly since hardly anyone will ever see it. Still worried about mine, maybe this will be the year I pull stuff out to check. Rest of the car is very clean for a NE NJ/PA car, also pretty low miles, and I've washed the whoe thing almost every time it's seen salt. Been spraying Fluid Film and Boeshield T9 frequently over the winter too. Fingers definitely crossed though.
Which side was rusty and which side was factory fresh on your car?
WhiteZombie is offline   Reply With Quote
Old 05-07-2021, 12:17 PM   #94
Swed-Ish
Member#: 369168
2005 92X Aero
02 WRX, 06 OBXT
WhiteZombie,
On my car, the drivers side was the rusty one while the passenger side was factory fresh. Not sure if that was luck or something in the manufacturing.
Keeping these cars out of salt in the NE is tough, but regular cleanings certainly help. Good luck on your upcoming project.
Next for me to check are the frame rails, pinch welds, and replace a very rusty rear bumper beam.
Old 05-07-2021, 02:05 PM   #95
WhiteZombie
Member#: 338863
PSM 05 WRX WGN 5MT
WhiteZombie,
Thanks for the reply.
My car has the tiniest little 1/8" rear quarter rust bubble spot on the driver side, while the pass side is mint still. I swear driver side rust seems more prevalent from all the threads I've read and cars I've seen over the years, even outside of Subaru?
Old 05-07-2021, 08:34 PM   #96
Snowphun
Member#: 1800
Nice work, should outlast the rest of the car. Seam sealer is a good step on the wheel well side to seal up the machine circles and weak areas on the other strut.
