Welcome to the North American Subaru Impreza Owners Club Thursday June 17, 2021
Old 02-28-2021, 12:25 AM   #4951
iriemark
Member#: 404616
2015 WRX Limited
CWP
Originally Posted by hcosteveo View Post
Not sure this qualifies, but was very happy with the end result
265/35/18 on Work ZR10s, 18x9.5 +38
This looks good! I'm waiting for the pilot sport 4s restock in this size but after seeing your pic I might get the all seasons.
iriemark is offline   Reply With Quote
Old 02-28-2021, 03:01 AM   #4952
White out
Member#: 46277
** LP640
575M DMC-12
Originally Posted by T-37 View Post
275/35r18 I'm not sure if I've pulled the rear quarters enough yet...
I love that.
White out is offline   Reply With Quote
Old 04-11-2021, 11:14 AM   #4953
MZWRX
Member#: 253130
2006 WRX TR
Red
I have wanted to post in this thread for 10 years...
275/35/18
Loaded up to head over for a brake bleed and an alignment to try and get this all to fit
MZWRX is offline   Reply With Quote
Old 04-11-2021, 09:09 PM   #4954
stikid2005
Member#: 76228
2005 STI
Aspen White/Seibon carbon
From my build thread.... But like the MZWRX, I too wanted to post in this thread for years. Glad to see it back.
295/30/18 R888R on 18 x 10.5 RPF1s
stikid2005 is offline   Reply With Quote
Old 06-03-2021, 04:41 AM   #4955
FlatFourRoar
Member#: 482353
Default 255/40/17 - ET42 -17x9
Hey guys, well after spending most of the week looking through this thread and dozens of others.
I was convinced 255/40/17 on a 17x9 ET42 would fit.
They will be fitted to a 2005 Impreza WRX. I currently use 235/40/17 ET42 17x8 on the car. The rear wheel would catch the inner arch lip under hard compression on track until I rolled it a little. (6/5k springs then)
I took some measurements from my car last night using the 215/45/17 ET55 OEM wheel. I have around 12-15mm gap to the strut and 38-40mm to the now agressively rolled wheel arch.
Moving to the 255 set up, it will sit 12.4mm closer to the strut and 38.4mm closer to the arch. So as good as a dead size. I doubt this will be ideal for heavy loaded track use... I have some 3mm spacers I could use and pull the arch even more, but I'd rather not use spacers on track at all.
I found this thread: https://forums.nasioc.com/forums/sho....php?t=2629019
I know he shows a ET45 on Tein Coilovers (I use BC Racing RM Series), but even ET42 seems to close seeing that. (Also don't know what camber he had)
I know I can reduce the amount of camber the camber bolt provides to help increase the distance between the strut and wheel and then use more of the top plate camber to get the desired camber I want. (plenty of movement left)
I'm beginning to think this wheel fitment isn't as simple as people make it out to be, and especially not on a track setting...
Spring Rate 10/8k
Lowered 25-30~mm
24mm ARBs front and rear
BC Racing RM Series Coilovers
Rolled Rear Arches
Any help would be greatly appreciated. Any pictures of clearance would be excellent!
Thanks!
FlatFourRoar is offline   Reply With Quote
Old 06-03-2021, 08:03 AM   #4956
Karlot
Member#: 339923
2006 Impreza WRX STi
grey
Spring Rate 10/8k
Lowered 25-30~mm
Rolled Rear Arches
Thanks!
I dont see why that would be all that hard to fit. even what you measured fits in the range you listed.
also, spacers arent some terrible nightmare or unsafe. I run spacers and ive tracked my car both with autocross and on a road course plenty of times. ive never had any issue, not sure why people think you will (15mm hubcentric slip on spacers w/ extended studs)
Karlot is offline   Reply With Quote
Old 06-03-2021, 09:00 AM   #4957
FlatFourRoar
Member#: 482353
I will soon find out, I hit my deadline for ordering to be ready for the upcoming event... I'll see how it all sits and report back
Thanks for the info
Old 06-03-2021, 01:44 PM   #4958
Karlot
Member#: 339923
grey
Thanks for the info
anytime. post some pics when you get it setup. and good luck in the upcoming event
Old 06-03-2021, 09:14 PM   #4959
BootsJunkie
Member#: 322862
05 STi
Loving yours, I'm on the same exact spec's.
What are you other wide-bois running tire psi-wise? 35 all around?
https://i.imgur.com/eph3W6l.jpg
BootsJunkie is offline   Reply With Quote
Old 06-03-2021, 11:01 PM   #4960
07imprezRS
Member#: 164302
11 20 STi, 11 STi
07 WRX, 02 WRX
What are you towing with that thing?
07imprezRS is offline   Reply With Quote
Old 06-04-2021, 12:54 PM   #4961
onibanshu
Member#: 523961
Originally Posted by kaeknows View Post
nankang ar1 275/35/18
weds tc105x 18x9.5 +25
Hi are you on stock suspension?
onibanshu is offline   Reply With Quote
Old 06-07-2021, 09:34 AM   #4962
BootsJunkie
Member#: 322862
05 STi
Jetski, altho nowadays it just pulls it outta the garage since it sits behind the subie, then the Acura takes over towing.
Old 06-11-2021, 04:05 AM   #4963
FlatFourRoar
Member#: 482353
I did add a fairly comprehensive post yesterday with a dropbox link to multiple fitment photos, but it seems the post isn't going to get approved for some reason...
Old 06-11-2021, 11:46 AM   #4964
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Host them here. https://img.nasioc.com/
Nobody can see embedded dropbox links on the forums
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 11:53 AM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 01:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 07:52 PM
