10-22-2000, 08:24 PM | #1 |
Member#: 123
TXIC
Vehicle:2005 WRX STi Blue and gold |
UR Pulley questions concerning torque specs
Recently picked up a pulley/belt set from Trey, and started to install it. Got everything off the front and ready to undo the crank pulley, and started to it. Per the instructions I set the car in fifth, had someone hold down the brakes, and started to use the breaker bar to remove the nut.
Ha. We BROKE a brand new breaker bar trying to unbolt (double checked the directions and everything) it, and promptly decided to set a time to take it to Trey for his magic touch. Anyone else have this slight problem? Phil (Back from the Future, so to speak)
10-22-2000, 09:14 PM | #2 |
Member#: 1997
Vehicle:2006 Acura TL 6spd STMGM6 alumni |
That nut is a #$%# to break. needed at 3ft extension to get mine off. its 95ft/lbs supposedly, but over torqued from the factory.
10-22-2000, 09:54 PM | #3 |
Member#: 242
Vehicle:MY05 PSM GGA !STOCK MY99 RS-RIP / MY95 MX-5 |
Also, be very carefull when retensioning the belts.. Ya might strip the tensioner bolts.. Right Midwayman?
You broke a breaker bar??? (And I thought I had a bad reputation) What size? [This message has been edited by Revision (edited October 22, 2000).] |
10-22-2000, 11:44 PM | #4 |
Member#: 2181
SCIC
Vehicle:2003 Forester XS |
All crank pulley bolts are done up real tight, and they self-tighten too.
A trick I was taught was to put your thickest breaker bar to it and rotate until it met with something solid, like the frame rail or the subframe. Next, with the plug leads off, give it a quick hit on the starter...best torque wrench there is. Just don't stand there with your head over the thing looking at it... |
10-23-2000, 03:49 PM | #5 |
Member#: 1559
Vehicle:2004 Sierra Denali Black |
I got mine off today fairly easy using a 1/2 drive breaker bar...
you have to shock it or you'll push all day long... I had the car in fifth....and my brother hammer on the bar while I pulled it... hurt the hands but worth it |
10-23-2000, 04:09 PM | #6 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
Starter idea is a good one. After 22k miles mine wasn't that bad though, 1/2 breaker bar + 2 ft pipe and it was off.
10-24-2000, 11:51 AM | #7 |
Member#: 188
Vehicle:2004 Forester XT 24k gold on white |
I just used a pipe and a lot of yelling. Once you start hearing that metal squeaking sound, you know you're getting somewhere! Don't quit and use $%&*@# power! I had to give up the first time doing it by myself when I had the car in 5th and the brake was held down by my "The Club". It was wedged between my brake pedal and the seat.
nizz |
Similar Threads | ||||
Question on torque spec on exhaust manifold | gopsu | Newbies & FAQs | 7 | 05-20-2006 06:30 PM |
Question on Torque specs and more... | mdurbahn | Brakes, Steering & Suspension | 0 | 03-17-2006 11:28 AM |
Another pulley torque spec question. | Corn-Picker | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 11-08-2001 09:08 PM |
UR Pulley questions, Need help quick | ATX25RS | Transmission (AT/MT) & Driveline | 7 | 10-19-2001 03:30 AM |
UR Pulley Questions | Narso | Technical Forum Archive | 2 | 07-11-2000 12:24 AM |
